Old Nov 07, 2012, 05:52 PM
Bobj_Manchester is offline
Find More Posts by Bobj_Manchester
Manchester, England
My home built camera gimbal.
Hi.
I finally got round to building myself a camera gimbal for my Hexa.
Having a lathe/mill made it a lot easier.
I am waiting for DJI to return my Wookong M compass so I fitted the Naza (glad I kept it) and it flies great.
The weather is too windy for proper testing just now but the thing seems to work quite well.
Will post video soon.
Regards Bob.
Bobj_Manchester is offline Find More Posts by Bobj_Manchester
Old Nov 07, 2012, 06:44 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
I like it. Very simple and clean. How heavy is it? I think a few of us are going about with very similar design concepts.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Nov 08, 2012, 03:18 AM
FlyingMcCoy is offline
Find More Posts by FlyingMcCoy
Joined Mar 2010
Not using external pots?
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old Nov 08, 2012, 11:27 AM
Manchester, England
SeismicCWave
Hi, it was your thread that inspired me to make this.
The all up weight with JR servos and Gopro is 500 grams.
It is built entirely from my bits box apart from the pulleys, belts and flanged bearings.
I love building so no doubt I will sell the whole lot before too long.
Looking forward to building something bigger for the Wookong M.
FlyingMcCoy
HI, I am 64 years young, I have built loads of things in my life including early propo radio (was it called Micron?) but I dont understand electronics.
I have to be led by the hand. After that, once I get soldering I am fine!
I hope that my next gimbal resembles a Zen Moose.
It will probably be even further away than my spelling!
Old Nov 08, 2012, 11:29 AM
AMA 46133
Hawaii
Joined Feb 2003
It is built entirely from my bits box apart from the pulleys, belts and flanged bearings.<<
That is very reasonable. I love those machined metal parts. Great job!!
Old Nov 08, 2012, 04:14 PM
Manchester, England
Flight test.
In spite of the wind I had to give it a quick try. I left the 2 front arms visible so you can see I was really shaking it about. In hindsight I think I should have been a bit more gentle. I was probably going way over the limits of travel.
Hey my video wont upload! What am I doing wrong?
Old Nov 08, 2012, 04:36 PM
Manchester, England
Trying to post in the wrong area. The video is too big anyway will edit and try later!
Old Nov 08, 2012, 05:17 PM
Manchester, England
Finally!
Gimbal test1 (0 min 40 sec)
Old Nov 08, 2012, 05:39 PM
Manchester, England
Over enthusiastic testing.
Gimbal (0 min 31 sec)
Old Nov 08, 2012, 06:32 PM
AMA 46133
Hawaii
Joined Feb 2003
Originally Posted by Bobj_Manchester View Post
That is very very good. Some people think that the Naza doesn't have a good gimbal controller. Looking at your video I think it is working just fine. So what servos are you using on your gimbal?
Old Nov 08, 2012, 07:27 PM
Estiavilla is offline
Find More Posts by Estiavilla
Taka
Joined Dec 2010
May i know where you purchase those big and small timing pulleys and belt ?
Estiavilla is offline Find More Posts by Estiavilla
Old Nov 08, 2012, 08:15 PM
AMA 46133
Hawaii
Joined Feb 2003
Yeah, I like to know also.
Old Nov 09, 2012, 09:00 AM
AliB is offline
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
try filming with the gopro in a mirror. always a good test of how stable the cam is.
AliB is offline Find More Posts by AliB
Old Nov 09, 2012, 09:15 AM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Now you have my interest...
Naza gimbal control, my favorite brand of servo (JR ) simple install no pots, and you get stability like that!
Put me on the need to know for the type of belts, pulleys and servo model number. Great job on the build, I like it
power is offline Find More Posts by power
Old Nov 09, 2012, 12:02 PM
Manchester, England
Thanks for your kind remarks guys.
The pulleys and belts were from www.motionco.co.uk. I used72T 32T with 110T belt. The metal pulley does NOT bolt direct to the servo, I drilled the servo output disc and then drilled and tapped the metal pulley. Bob's bodge! The servo is a JR NES-507 that came with my JR X8310 transmitter. They have been lying around unloved for the past 11 years! As I said this was built from my bits box. I was inspired by the build from SeismicCWave and developed from there. I am a panelbeater by trade and went on to become a Motor technician finally designing and building Bugatti Type 59 replicas. I am used to working with metal. Aluminium is a good material for damping vibrations and I think it has played a part here. Having a small mill it is easy for me to turn a 14mm carbon tube through 90deg by just basically drilling a couple of holes. There is no rocket science with my work! The hexa is based on the Turnigy frame - http://hobbyking.com/hobbyking/store...ame_625mm.html
with the addition of Turnigy V2 Quadcopter extended arms - http://hobbyking.com/hobbyking/store...mm_2_pcs_.html I have made a bit of a mistake with the pitch axis. The hinge point should go straight through the lens. I should have put the shaft through the centre of the carbon tube and I have got it a little low. The roll axis is pretty much spot on.
Discussion Show us your scratch built camera gimbal bigbro3760 Scratchbuilt Multirotors 21 Feb 21, 2015 07:26 AM
Gallery My Home Built Spitfire mrexcel Foamies (Scratchbuilt) 0 Jun 30, 2012 10:41 AM
Discussion My home made camera mount - Flamewheel test DavidPDX Multirotor Talk 11 Mar 07, 2012 09:03 PM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
