Old Nov 07, 2012, 05:54 PM
Turbopropdrive is offline
Find More Posts by Turbopropdrive
Turbopropdrive's Avatar
Commonwealth of Puerto Rico, San Lorenzo
Joined Jul 2010
Help!
Should I or shouldn't I charge
Hi,
I just got a Radio Shack 22-813 model Digital multimeter. I have a bunch of 1s lipos that I have not used for a while. While checking the voltage of each one with my multimeter in the 9v range, they show between 3.8 and 4.1 volts. However when I connect them to my micro rc receivers they simply can not power the motor or the receiver led blinks rapidly. Should I recharge them this time in parallel? ;How can I tell if they have or not reached lowest cutoff voltage ?
Am I doing something wrong?
Thanks for your shared wisdom.
Turbopropdrive is offline Find More Posts by Turbopropdrive
Old Nov 07, 2012, 06:47 PM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
It's best to charge them individually. If you connect them in parallel, differences in terminal voltage will cause the higher voltage cells to discharge into the lower voltage cells, confusing the charger.
Once the individual cells come off the charger, each one will be at the same voltage (e.g., 4.2 vdc). But after each use, especially in 1s applications, they will all be different voltages again.
356Jim is offline Find More Posts by 356Jim
Old Nov 07, 2012, 06:48 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Fully charged is 4.2V so it sounds like they could do with charging. But leaving lipos almost fully charged for "a while" can seriously reduce their capacity so you may have ruined at least some of them.
Steve
slipstick is offline Find More Posts by slipstick
Old Nov 08, 2012, 01:51 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
lipo storage is said to be at 3.9 volts, or 50%. lipos do wear out and hold less charge.
nemoskull is offline Find More Posts by nemoskull
Old Nov 08, 2012, 04:19 PM
Joined Jul 2010
Ok, Thanks a mill for your replies. Now If I am not confused,and hoping that these lipos still take a charge, If they are above 3.8 but below 4.2, can I still charge them or should I scrap them and get fresh ones?
Thanks again.
Old Nov 08, 2012, 04:22 PM
Joined Jul 2010
Also, if they still hold above 4.0 volts, without being used for a while, why then, if they still show this voltage they can not power with enough punch the receiver/motor?
Old Nov 08, 2012, 05:59 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
As batteries age the internal resistance goes up. When that happens you end up with a battery that looks fine unloaded, but when you try to draw current out the voltage drops very quickly.
Petefoss is offline Find More Posts by Petefoss
Old Nov 09, 2012, 04:18 AM
Staffs, UK
Joined Nov 2003
As Pete says, because the voltage you measure with no load on the battery doesn't tell you very much about how it will behave when you ask it to deliver current to a fairly heavy load (like a motor). What happens is the voltage suddenly drops much lower....and the reason it's easy to get confused is because when you take the load back off and try to measure battery again the voltage will have bounced back up to something that looks quite reasonable .
Steve
Old Nov 09, 2012, 12:20 PM
rhodesengr is offline
Find More Posts by rhodesengr
United States, CA, Livermore
Joined Jan 2012
you can also try to cycle them. If you charger has a discharge mode, run them down and recharge a few times. If they get too low where you get a low voltage error on your charger, you can charge them as an NiMH to get the voltage up.
If you cycle them, and they still don't power your model, then you can declare them shot.
rhodesengr is offline Find More Posts by rhodesengr
Old Nov 09, 2012, 12:44 PM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
I would cycle at 1C discharge.
Old Nov 09, 2012, 07:16 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Cycling doesn't revitalize dead Lipo, and charging as a NiCad/Nimh will produce the magic smoke real quick As Petefoss noted, Lipo which have been stored fully charged degrade chemically and seems to have very low capacity because of higher internal resistance.
http://www.rcgroups.com/forums/showp...23&postcount=1
coriolan is offline Find More Posts by coriolan
Old Nov 09, 2012, 07:23 PM
Joined Jan 2012
well I guess everyone is entitled to their opinion but cycling helping a new battery that I bought that didn't work right as received. Worked fine after cycling.
Also, I used the NiMH trick just the other night on a small 1S battery I hadn't used in a while. I have it a few seconds in NiMH mode and then it charged fine in LiPo mode. Obviously you need to be careful doing anything with batteries but the trick does work if you accidently over-discharge a LiPo and your charger gives you a low voltage error and won't charge it.
Old Nov 09, 2012, 08:05 PM
Joined Jul 2010
Gentlemen!!
Thanks for your advice, I will use my B6AC charger to try to recycle them (BTW can 1s lipos be recycled in parallel? Just asking!), and see what happens. I will then keep you posted and also get prepared to purchase new 1s lipos from HK and this time, if I will store them I will only charge them for storage capacity.
Old Nov 09, 2012, 11:35 PM
Joined Jan 2012
You could cycle them in parallel but it will be harder to tell if you have improved a bad one. The way you'll gauge improvement is to either time how long a discharge cycle takes or look for an increase in the total mAh during a discharge. The test before and after must be with a single battery. Start fully charged and your charger will stop when it reads a preset voltage. Probably 3V or 3.3V for a 1S. Hopefully your charger reads out time, total mAh, or both for a discharge.
Old Nov 10, 2012, 11:24 PM
Joined Jul 2010
Will do,
Thanks again and I will keep you posted. I will take some time since the next few days I am on reserve. But I will follow your advise on my days off and give you the feedback on how the lipos are behavin'
Take care and thanks.
Help! Should I or shouldn't I? JSS4 Off-road Cars 18 Apr 09, 2012 12:00 PM
Question T-REX 500 RTF, should i or shouldn't i? D-Sci Electric Heli Talk 3 May 19, 2009 04:23 AM
Discussion Should I or shouldn't I? lrsudog Life, The Universe, and Politics 131 Aug 20, 2006 02:43 PM
Should I, or Shouldn't I? squidbait Beginner Training Area (Aircraft-Electric) 2 Jun 23, 2004 09:31 AM
Piccolo Deal, should I ... or shouldn't I johnbyrne Micro Helis 3 Jan 05, 2004 10:33 AM
