Old Nov 19, 2012, 11:52 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
What did you do for the LE sheeting? What's it glued to?
I'd love to see another Shrike build thread, especially one that's a little different.
I use Dave Brown Pushrods as wing joiners.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 19, 2012, 05:30 PM
Bob Hunt is offline
Find More Posts by Bob Hunt
Mustang Fever
Joined Jan 2005
Andy:
The ribs in the 40 kit are triangle notched on the front, so you can use some square balsa stick for the LE. (I think I used 3/8 or 1/2 square). That way, the balsa sticks up higher than the ribs and it's easy to butt glue the sheeting to the back of it.
I only used 3/8 CF tube for the forward and aft wing spars, as shown. Very strong, very light, and not expensive. Best part was being able to use a 3/8 Forstner bit to drill the holes in the ribs. Everything lined up perfectly over the plans. (Note the fuse hanging off the end of the bench while the wing is assembled onto the spars. Strange, but it works.)
These things come out so nose heavy, I shoved as many servos as I could to the rear, and built the horizontal stab out of solid 1/4" sheet. You can see in the pic how it's sort of inlayed into the 1/4" stick frame that Joe B. designed.
In the end, I only had to put about 1/2 oz of weight in the back, and only then after I went from a Macs muffler to the factory one on the 46AX.
The sandpaper above the wing is for underhand launching. I mix about 1/8" up elevator trim (beyond level flight) with the flap switch on my Tx, to get a positive nose up on launch. Once she's established a positive climb angle, I flip it off.
Bob Hunt is offline Find More Posts by Bob Hunt
Old Nov 19, 2012, 09:09 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
I always use a spar of some type to anchor the trailing edge of the LE sheeting. I was wondering what you did there. It looks like you don't have any.
Andy
Site Sponsor
Old Nov 19, 2012, 09:15 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Nice one Bob... Man I got to finish my B-17g
Just wanted to share and not hi-jack thread.
freechip is offline Find More Posts by freechip
Old Nov 20, 2012, 08:34 AM
Bob Hunt is offline
Mustang Fever
Joined Jan 2005
Andy:
I misunderstood. The ribs are notched for square balsa spars under the back of the sheeting. It's stuck down to that.
Nice Fort, freechip.
Old Nov 20, 2012, 08:51 AM
mejmea is offline
Find More Posts by mejmea
Always trying to learn
mejmea's Avatar
United States, IL, Batavia
Joined Feb 2011
That's pretty, there's something about a nice "skeleton"....
mejmea is offline Find More Posts by mejmea
Old Nov 22, 2012, 06:30 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by AndyKunz View Post
Right now if you look at the side view it's a rectangle. I'll be removing wood from one side only (the unsheeted side) to turn it into a right triangle. Then I'll sheet the remaining side, still keeping a right triangle.
Here you can see those steps as I finish making the elevators.
After the glue dried, I trimmed the ribs to a rough triangle with a knife. Next I took them to the belt sander and carefully created a wedge (also making a taper on the TE edge).
Next, I glued on the other side of the balsa sheet. Note that I moved it 1/8" off the LE because I will trim that back for removing the bottom of the front portion to make it able to give me down elevator. This also extends the TE about 1/8". This will be sanded on all sides including top and bottom so that we end up with a 1/32" thick TE.
The blue mark that you see on the top of the last photo is where the control horn will go.
Hopefully this shows what you were asking about.
Andy
Site Sponsor
Old Nov 22, 2012, 06:33 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
While that glue was drying, I fit the fins into the stabs. These will not be permanently attached until after covering, but they are snug fit together now. The angle is approximately 10 degrees from vertical.
Site Sponsor
Old Nov 22, 2012, 06:36 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
And now the photos I've been wanting to shoot for a couple years!
All the wood parts are done except for the main gear doors.
All you see here, which includes the nose retract, steering servo, and door weighs 24 oz.
Andy
Site Sponsor
Old Nov 22, 2012, 06:54 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Very nice man. I miss my little shrike....
Gravity sucks but it was fun while it lasted.
Old Nov 22, 2012, 06:58 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
There's a solution to that situation, Mike! Go for it!
Andy
Site Sponsor
Old Nov 22, 2012, 07:01 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
You think I can rebuild it?
Old Nov 22, 2012, 09:11 PM
mejmea is offline
mejmea's Avatar
Joined Feb 2011
Andy
It absolutely does, thanks for the detail and it looks great!
Old Nov 23, 2012, 08:43 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
I don't see why not. That damage will buff out
The plane is simple enough, especially at that size, that you can build a new one pretty easily too. I'll be building another 400-size one myself this winter if I can get down the strata to it.
Andy
Site Sponsor
Old Nov 23, 2012, 09:49 AM
Bob Hunt is offline
Mustang Fever
Joined Jan 2005
I like that elevator treatment, Andy.
Discussion Micro Shrike Build Thread (was Mystery Build Thread) AndyKunz Electric Plane Talk 101 Dec 05, 2013 09:50 AM
Build Log San Diego Slopers Shrike build party.. ORANATOR Slope 111 Dec 21, 2012 12:21 AM
another shrike question<s> sylentbob3 High Performance 2 Jun 03, 2005 09:17 AM
