Old Nov 07, 2012, 07:47 AM
YXmotor is offline
Find More Posts by YXmotor
RPC
Joined Oct 2008
Cool
Hey! Dr.Kiwi, come in and test our new 15g brushless motor
Hi folks here,
We developed a new motor named AP15 these days and I would like it to be tested by Dr.Kiwi and others who are interested in it.
Here is the description of the motor:
It is ideal for small electric airplanes 100-150g F3P flying. The Curved Magnets offer a perfect gap from the inside of the rotor for optimal power and efficiency, The estimated thrust with 7-8 inch prop is between 200g -250g.
The Backmount is integrated, Prop adapter for GWS, STO and APC-Props with needed O-Rings and all screws are included.
Specifications:
KV1500
Power is 50W
Idel current:0.4A 2S-3S
Recom. GWS 8043 prop on 2S(7.4V)
6-7 inch prop on 3S(11.1V)
Max current on 2S 7.4V will be better if it is less than 7A
Max current on 3S 11.1V will be better if it is less than 5A
Weight:15g
We need the following data:
Thrust, current, 2S(7.4V) on GWS 8043 and GWS 7035
Thrust, current, 3S(11.1V) on GWS 7035
Comparison data between AP15 and Hacker A10, we need to find out which one is better. We will send the motor for free and USD6 shipping cost needs to be paid which is by airmail parcel.
Thank you!
OVERSKYRC TEAM
YXmotor is offline Find More Posts by YXmotor
Site Sponsor
Old Nov 07, 2012, 07:28 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
PM sent: I could certainly conduct such a test for you, but since you are wanting to see how it performs against a Hacker A10, I would need a Hacker A10 so that I can perform tests on both....... head-to-head, using the same equipment, same test stand, at the same altitude, and the same ambient temperature. Having different people testing the two motors in different places... using different equipment, under different conditions, is like comparing apples with oranges!
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 08, 2012, 07:46 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
You are asking the tester to pay shipping costs?
hoppy is offline Find More Posts by hoppy
Old Nov 08, 2012, 07:41 PM
YXmotor is offline
RPC
Joined Oct 2008
Yes, but the better the tester needs to have a Hacker A10 for test comparison.
Thank you!
Site Sponsor
Old Nov 08, 2012, 08:40 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
One can't even begin to make this stuff up
Bare is offline Find More Posts by Bare
Old Nov 08, 2012, 09:32 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
It seems that, in addition to paying for shipping of the AP15, I need to go out and buy a $35 A10S. But there is no Hacker A10S which matches the AP15 (1500Kv).. there is an A10-12S (2900Kv) and an A10-15S (2320Kv)... so no head-to-head comparison with the designated props (see OP's Post #1) is possible.
I looked through my database of motors I've tested and there are none in the 15g-18g range which match the 1500Kv of the AP15.. the lowest Kv I see for motors this size is ~1315Kv... then the next lowest is 1645Kv....most are >2000Kv....so I have nothing to test the AP15 against!
Old Nov 08, 2012, 10:17 PM
luke352 is offline
Find More Posts by luke352
Australia, QLD, Ipswich
Joined Sep 2008
There is the AXI 2203/52 (1525kv) if you feel like spending about $70 on a 18g motor.
luke352 is offline Find More Posts by luke352
Old Nov 09, 2012, 12:31 AM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
It's amazing,
That poverty of marketing strategies.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Nov 09, 2012, 09:26 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
E-flite 250 (16g, 2195Kv) with 7x3.5 GWS HD on 2s gets 280g from 6.05A/45W
MicroDan 2003-F3P (14g, 2300Kv) with 7x3.5 GWS HD on 2s gets 236g from 6A/44W
Motrolfly 2003-1350 (18g, 1315Kv) with 7x3.5 GWS HD on 3s gets 230g from 3.30A/36W
Motrolfly 2003-1600 (18g, 1645Kv) with 7x3.5 GWS HD on 3s gets 326g from 5.40A/59W
Motrolfly 2003-2200 (18g, 2260Kv) with 7x3.5 GWS HD on 2s gets 264g from 6.10A/45W
Hyperion Z1705-11 (18g, 2300Kv) with 7x3.5 GWS HD on 3s gets 303g from 7.35A/55W
Infinite 1705 (17g, 2340Kv) with 7x3.5 GWS HD on 3s gets 296g from 7.55A/55W
Old Nov 09, 2012, 06:43 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
It's amazing,
Manuel V.
The same system is operated by these guys..http://www.rcgroups.com/forums/showthread.php?t=1733906. Louis Fourdan initially tried to help, then sensibly opted out.. I responded but indicated my unwillingness to pay for test motors.. they have yet to respond!
Maybe, if YXmotor comes to the party we can see how their AP15 matches up with the AXI 2203/52 (1525Kv)... should I camp beside my mailbox and await delivery of an AP15 and an Axi?
Old Nov 09, 2012, 07:10 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Testing just one motor, especially one of their choice, is statistically insignificant. You should buy at least a thousand of them selected at random. After they are all tested then the raw data can be statistically analyzed to come up with a close to real world conclusion about their effectiveness.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Nov 09, 2012, 08:56 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Hi Larry,
Of course I absolutely agree... n=1 is a waste of everyone's time.... but maybe 1000 is a bit over the top... maybe they'll send me 10 of each!
Cheers, Phil
Old Nov 09, 2012, 10:49 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
Originally Posted by Dr Kiwi View Post
Hi Larry,
Cheers, Phil
As long as they are sending them to you knowing you are reviewing them it is moot really 1 or 1000 they can still pick the best samples, or even do special versions to skew the results.
desertstalker is offline Find More Posts by desertstalker
Old Nov 10, 2012, 10:00 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Maybe I'll never see them.. so the whole exercise may be moot!
Old Nov 12, 2012, 08:00 PM
YXmotor is offline
RPC
Joined Oct 2008
I'm sorry for my delayed reply. It is ok for no comparison with the Hacker 15g motor, I will ship out the motor to Dr.Kiwi today, it will arrive in US within 8-10 days.
Thank you!
OVERSKYRC
Site Sponsor
Discussion looking for dealers in your region for our high quality brushless motors ,ESC, Servo jeffrey20021 Vendor Talk 3 Jul 04, 2012 09:17 PM
Cool Come check out our new T-motor brushless airplane motors! Nitro_Gary HobbyPartz.com 9 Jul 03, 2012 01:55 AM
Cool Come check out our new T-motor brushless airplane motors! Nitro_Gary Nitro Planes 0 Jun 26, 2012 02:50 PM
The Dr Kiwi Test Stand revisited Dr Kiwi Power Systems 69 Dec 14, 2009 09:34 PM
Discussion A Goldmine of Motor Test Data from Dr Kiwi hoppy Power Systems 9 Jun 03, 2007 04:33 PM
