Old Nov 06, 2012, 05:16 PM
gstierli is offline
Find More Posts by gstierli
GusCBA
gstierli's Avatar
Argentina, CB, Córdoba
Joined Mar 2010
OSD Pro Software Update Request… 65 Km distance limit!
Bill, the last weekend our local FPV team had in mind in order to try to beat our current distance FPV flight record, 45km (which at this moment was the Argentinian record), after all the preparations and hard work in the troubleshooting vibration (since we use a gasoline engine) adversely affecting the operation of the guardian and a fine tuning of the RTH settings, hoping one day to suitable meteorological conditions, at the end of the day when the wind let up, we took off toward our goal 75 km!, but our goal was not possible because we have a limitation of the OSD side, running 65.5 KM away suddenly OSD step mark of 65,535 meters to 0, great was the surprise and brief moments of despair until we realized that what was happening ... at first we thought the OSD had been hungup, but after a few seconds of watching other parameters on the screen, we saw that the OSD was still responding, except the distance values ​​and arrow which had radar located in the center of screen (attached a piece of video where you can see what happened)
Bill, it is possible to create us a new version of the software to expand the boundaries of distance with respect to the distance values? Our new goal is to try to reach 120 km away .. Also we would be useful to visualize the possibility of grardian gain values (which are currently in the servo deflections) as any other value that can stand alone position anywhere on the screen, we would be useful also a parameter that is the remainder of the speeds or ground speed of GPS speed less pitot tube speed.
This is the second time that our team is with the limitation of a OSD, made couple of months ago we also try to break the national record height at the first attempt we could not continue beyond 4000 meters, since the OSD at that time we used (DAKAR OSD) had that limit values ​​for height, for this case we also contacted the developers of it and request a new software, which helpfully broad the limit of measurement of the height to 6000 meters (after the upgrade we could reach the 5000 meters high and achieve our goal ...)
In brief will attach the full video of the flight (even what we are editing, since they were 2 hours flight) I leave a couple of pictures of the plane and our Team, together with the plane equipment specifications ...
Greetings from Cordoba - ARGENTINA
Thanks in advance
GusCBA
WWW.FPV-CBA.COM.AR
http://www.facebook.com/fpv.cordoba
EagleTree OSD Distance Limit....! (2 min 26 sec)
gstierli is offline Find More Posts by gstierli
Old Nov 06, 2012, 06:08 PM
NutBag is offline
Find More Posts by NutBag
NutBag's Avatar
Australia, QLD, Brisbane
Joined Oct 2005
Congrats on a really neat setup... Nice work!
Chris.
NutBag is offline Find More Posts by NutBag
Old Nov 06, 2012, 06:45 PM
jjsueldo is offline
Find More Posts by jjsueldo
Joined Oct 2008
Limitation on Eagle Tree
We need to free the distance count to get a new record ¡¡¡¡¡
Who Can Help?
Jojó
www.fpv-cba.com.ar
jjsueldo is offline Find More Posts by jjsueldo
Old Nov 07, 2012, 01:01 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, this is one of the items on our list to address!
billpa is offline Find More Posts by billpa
Site Sponsor
Old Nov 07, 2012, 03:00 PM
gstierli is offline
GusCBA
gstierli's Avatar
Joined Mar 2010
Bill, is there any ETA for the release of the new software whit this updates?
Old Nov 20, 2012, 02:24 PM
jjsueldo is offline
Joined Oct 2008
Any news about the distance limitation or i will to change to other osd like RVOSD
Old Nov 20, 2012, 03:37 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, sorry for the delay on this. We will get it done as soon as possible!
Site Sponsor
Old Nov 22, 2012, 07:21 AM
jjsueldo is offline
Joined Oct 2008
Thanks Bill.
We have two models ready to do 120 Kmts....we look forward to news
Old Dec 13, 2012, 02:45 PM
gstierli is offline
GusCBA
gstierli's Avatar
Joined Mar 2010
Bill, it's been a long time since our request to change the OSD distance counter, is possible to give us an estimated date of the change in the firmware? or if you intend to make it?
Because as I already discussed, a long time ago that we are waiting for this change, we have two aircraft ready to fly beyond 65 km
In the absence of answers from you, unfortunately we see the need to move to another platform OSD (we know that the RANGEVIDEO osd has no such limitation ...)
Old Dec 17, 2012, 04:48 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, this feature is being done in the context of several other changes, but we'll try to have an alpha version of this ready in the next couple of weeks.
Site Sponsor
Old Dec 20, 2012, 03:42 PM
jjsueldo is offline
Joined Oct 2008
Hi Billpa ....something new ?????????????????
Old Jan 09, 2013, 12:28 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
Wow!!!
rcimports is offline Find More Posts by rcimports
Old Jan 09, 2013, 03:45 AM
goryc is offline
Find More Posts by goryc
Italy, Sicilia, Messina
Joined Apr 2011
I would say that this problem is solvable by ET, quickly and painlessly.
The numeric variable that was declared in the software and that conveys the values ​​of distance, is a variable of type integer (or similar) that can only be a number between - 32767 to + 32767, then just 65534; simply (this is the say the software developer!!!), change the declaration of this variable as a whole should be (number in single precision or similar) so he can represent numbers much larger and not stop to 65534.
goryc is offline Find More Posts by goryc
Old Jan 09, 2013, 01:23 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi gory, nothing ever seems to turn out to be quick or painless. We have the UI changes for this, and it is displaying correctly here, but a problem is being tracked down with another feature. Goal is to get this sorted over the weekend.
jjsueldo, it looks like we took too long on this for your project. Sorry about that!
Site Sponsor
Old Mar 02, 2013, 08:11 AM
smtorrigiani is offline
Find More Posts by smtorrigiani
FPV INRIVILLE (CORDOBA)
smtorrigiani's Avatar
Joined Mar 2013
hello, here the update for increased distance? 10.44 is? I hope your answer, greetings
smtorrigiani is offline Find More Posts by smtorrigiani
Discussion Walkera Devo 7 Software Update..RIPOFF Charging owners $34.77 to update mescalinedream Micro Helis 17 Apr 07, 2013 06:58 PM
Question OSD Pro, eLogger V3, GPS V4 problems updating firmware in OSD Pro jbfoamy Eagle Tree Systems 23 Jun 02, 2012 02:59 PM
Help! Firmware update error with OSD pro ONLY Data Logger and Gardian firmware update works whosthebaddest Eagle Tree Systems 10 Mar 17, 2012 05:26 AM
Question OSD Pro Distance not displaying WTurbiasz Eagle Tree Systems 2 Aug 08, 2010 01:32 PM
Distance from you: km grymg Motorcycles 18 Jan 12, 2005 10:36 AM
