Old Nov 06, 2012, 04:59 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
Hitec Sky Scout
Now shipping in all versions!
SPECIFICATIONS:
•Wingspan: 54.5 in.
•Weight: 24.5 oz.
•Length: 38.6 in.
•Wing Area: 372 sq. in.
•Wing Loading: 5.47 oz./sq.ft.
Available Models:
SkyScout R2GO
Includes Pre-Installed:
•Hitec Lite 4 2.4GHz 4-Channel Radio w/4 AA Alkaline Batteries
•Minima 6S Receiver
•HS-55 Servos
•200-watt Brushless Outrunner Motor
•18 amp ESC
•3S 1300mAh LiPo
•DC/DC Balancing Charger
Stock# 13207
SkyScout H2GO
•Minima 6S Receiver
•HS-55 Servos
•18 amp ESC
•3S 1300mAh LiPo
Stock# 13209
SkyScout P2GO
•HS-55 Servos
•18 amp ESC
Stock# 13210
SkyScout Kit
Includes:
•SkyScout Airframe
•All Plastic Components
Stock# 13211
MikeMayberry is offline Find More Posts by MikeMayberry
Old Nov 06, 2012, 09:09 PM
mickydee is offline
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi,
What is the difference between a Sky Scout and a Easy Star II?
Thanks!
Mickydee
mickydee is offline Find More Posts by mickydee
Old Nov 07, 2012, 06:27 AM
Mac Smith is offline
Find More Posts by Mac Smith
Mac Smith's Avatar
Germany, HE, Frankfurt
Joined Jun 2012
It's the same plane.
Multiplex seems to be marketing the RR and RTF versions of the ES2 under the hitec label in the US.
Mac Smith is offline Find More Posts by Mac Smith
Old Nov 07, 2012, 10:22 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Wing span is shorter,more like the Easy Star I, with optional ailerons.
Doubletap is offline Find More Posts by Doubletap
Old Nov 07, 2012, 10:51 AM
Hitec/Multiplex USA
Joined Sep 2000
It's exactly the same plane except the decals.
Pricing is as follows:
Kit: $79.99
P2GO: $164.99 Needs radio, RX & Battery.
H2GO: $219.99 Needs Hitec AFHSS capable radio
R2GO: $249.99 Ready to fly with everything.
Mike.
Old Nov 21, 2012, 06:05 PM
Rickochet is online now
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Sorry, but with all of the ES type aircraft already on the market plus the ES II I don't see the marketing wisdom here.
What Hitec needs is one of these rascals in the 36" wingspan size.
Rickochet is online now Find More Posts by Rickochet
Old Nov 22, 2012, 04:23 PM
wingz is offline
Find More Posts by wingz
Joined Feb 2012
Seems easy enough to understand. They want to market the plane with Hitec brand electronics at varying levels of completion. This has proven to be popular with Spektrum and Parkzone/E-flite, even when there were questions about DSM2.
I like Hitec stuff, but they really need to give some attention to their radios. The 4 and 5 channel Txs are unattractive and too basic (no dual rate switch even?), the Optic 6 looks and feels really dated, the Eclopse 7 "Pro" is missing features like servo travel limit, and the Aurora definitely needs a refresh. I think they're going to have problems remaining relevant in the Radio market without a different approach, and this also impacts the success of the airplanes that include the radio equipment.
wingz is offline Find More Posts by wingz
Old Nov 23, 2012, 02:52 AM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
I am all for supporting a USA company but the price your asking for this airplane makes it hard to be patriotic.
Have you looked at what similar airplanes in this category are selling for?
BGR is offline Find More Posts by BGR
Old Dec 07, 2012, 09:11 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
Considering what the E* normally goes for, as well as being filled with hitec gear, I don't think their prices are out of line. Sure, some people would rather go to Harbor Freight, strip down a Wild Hawk, dump some cheap running gear in it, and that's fine. I totally understand. Though, I've never seen one of those rip-offs thermal at my local field. They're usually all beat up. I have seen a number of E*s thermalling, doing acro, and generally outperforming those planes in nearly every aspect.
I'll be looking at getting a Scout, but I won't be using the graphics. I'll likely go for hi-vis orange or pink tips topside and some invasion stripes on the bottom. I trust my Multiplex Evo/Hitec 2.4 rig further than I trust my eyes to be able fly.
carlsoti is offline Find More Posts by carlsoti
Old Dec 13, 2012, 03:56 PM
VicT is offline
Find More Posts by VicT
USA, FL, Safety Harbor
Joined Sep 2000
Folding prop RPM limit
Kit: $79.99
Mike.
Hi Mike,
The old EZ Star brushed motors were replaced with the Hitec 3000 and higher KV inrunner motors and with a 6x3 APC prop they are much faster.
Rather than tell every one not to experiment with non stock motors can you or Hitec come up with a do not exceed KV for the new stock folding prop/spinner?
I would hate to see somebody get hurt when a blade separated from the hub. Hopefully a 3000 KV motor on 2 cells will not overstress the blades, spinner, and O ring parts of the new prop.
Appreciate your support
VicT is offline Find More Posts by VicT
Old Dec 13, 2012, 05:38 PM
Hitec/Multiplex USA
Joined Sep 2000
I don't think there is such a hard number. The spinner is similar to the one used on the Blizzard that we have run at well over 600 watts.
Mike.
Old Dec 14, 2012, 05:58 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Ok, let's have a look here:
the stock setup uses 3s and a 1100kV motor, that's a theoretical rpm of approx. 13.200 rpm max in a dive.
using 2s and a 3000kV motor, that's a theoretical rpm of approx. 24.000 rpm max in a dive.
7x6" Aeronaut Cam Props are limited to 16.000 rpm.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Dec 18, 2012, 04:41 PM
thumsrus is offline
Find More Posts by thumsrus
United States, CA, SF
Joined Feb 2005
Hi all,
Can anyone tell me the O-ring size on the stock prop/spinner?
thumsrus is offline Find More Posts by thumsrus
Old Dec 20, 2012, 12:43 PM
wayfaringdreamer is offline
Find More Posts by wayfaringdreamer
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
I thought hitec was Korean.
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Dec 30, 2012, 11:32 AM
SARG5 is offline
Find More Posts by SARG5
SARG5
SARG5's Avatar
10 Miles north of Russell, Ks. on US281 hy
Joined Oct 2009
SARG5 from Kansas here -- Remember the WINDY STATE
I had been out of RC for some 35 years. Never was good. But have 3600 hrs in the real planes with the Kansas Highway Patrol
A Kansas KBI Agent I knew. Directed me to the Multiples EasyStar to get re-started
HAVE NEVER BEEN SORRY. On great Trainer RC.
Do not care who ownes it. If the HITEC SKY SCOUT is the same RC as the EasyStar.
It has my vote.
Remember, Kansas winds. I can fly in 15+ with no problems.
A great learner plane
Yes, there are several outlets . I like www.headsuprc.com out of Fl.
KEEP FLYING
SARG5
SARG5 is offline Find More Posts by SARG5
Discussion Info on Hitec Sky Scout zagiflyer67 Electric Plane Talk 7 Aug 02, 2012 03:51 PM
Build Log My Sky Scout Build ** Pietenpol** StevensAeroModel** Joe Pierson Scale Kit/Scratch Built 24 Jul 17, 2012 04:18 PM
Help! pietenpol sky scout Gofer 303 Beginner Training Area (Fuel) 6 Jun 05, 2012 06:17 PM
Wanted StevensAero - Pietenpol Sky Scout (480) I need one :) Joe Pierson Aircraft - Electric - Airplanes (FS/W) 2 Apr 01, 2012 12:03 PM
