F-86 box fuse construction Higher Res VIDEO AND PLANS ADDED :)
howdy all,
wasnt too sure how this was going to look when I started it, but it doesnt seem to look too bad so I decided to post the build sequence and maybe the plans... if she flies good ![]() anyhow its a box fuse F-86 that is rounded to shape by sanding. the specs: dollar tree foam (de-papered) SA 35mm fan 16" span 16" or so length hopeing to use 2s 350mah batt (should work in this one) ended up going with a 3s 460mah 35-50c NanoTech ![]() forgoing ailerons and will attempt tailerons and see how she goes ![]() other than that I still need to install the "make it go stuff" Joe
Cool build! So you just sanded the box-shaped fuse in shape? I may want to try that once.
Robert, as you're another Dutchy, do you know of any good foam over here? The stuff I've found is way too heavy to weak for rc-planes. (I'll just keep it in English so I don't Dutch all over the thread )
Depron all the way ;-)
In zwolle is quartel die 2-3-5-6mm depron can deliver so that's good to use if you need special sizes else you can use graupner depron that haven't got a grain like wood got and you can go to the praxis where you can buy yellow foam for about 7 euro/sheet or go to the carpet shop or one isolation shop and ask for some test plates to see what you can use |
yep boxed up and sanded to shape, just trying to keep it simple ![]() Joe |
ok,
everything is mounted and ready to go, as you can see I mounted the servos through the fuse sides so as not to impede the airflow,.. again wasnt sure how it would look, turns out its not too ghastly ![]() so far I'am fairly happy with how its turned out, the servos are the 5g size...probably been better with 2g'ers...but ya use what ya have ![]() Joe |
thanks KC, I'll do my best to video the flight....I'll hopefully do better than my last two video attempts.....long video, lots of sound...no jet in frame
hat cam pointed in the wrong direction....should have my daughter where it huh then she can be the dorky lookin one standin in the fieldJoe |
| Thread Tools | |
| Sold LPU San Antonio TX: JPower 50mm MiG-15, F-86, F-22 and F-35. | FoamJunkE | Aircraft - Electric - Jets (FS/W) | 3 | May 09, 2012 12:00 PM |
| Discussion F-86 Fibreglass fuse? | OhioMike | Electric Ducted Fan Jet Talk | 14 | Jul 28, 2006 10:25 AM |
| Discussion F-86 Fibreglass fuse? | OhioMike | Pusher Prop Jet Models | 2 | Jul 16, 2006 03:41 PM |
| Need F-86 Fuse Former Profiles | Ralph A. D'Amelio | Electric Ducted Fan Jet Talk | 6 | Nov 23, 2005 08:37 PM |
| Used Byron F-86 - Fuse,wings, & tail only | RTflyboy | Aircraft - Fuel - Airplanes (FS/W) | 0 | Aug 11, 2004 01:47 PM |
