Old Nov 06, 2012, 03:20 PM
madphil is offline
Find More Posts by madphil
Lets get the HUEY up
madphil's Avatar
bolton england
Joined Jan 2009
NEW MOTORS for 41" FALCON
i am trying some new motors in the falcon think i have gone as far as i can with the HET typhoon EDF motors
i have gone for the TORO beast 780kv motors they are a replacement / upgrade for a 26cc gas motor all most twice the size of the HET motors can size is 57mm D x 112mm long with 8mm shaft the spec claims they are good for over 10hp on 9s ( we will have to see about that when its on the water )
i have just made some alloy cooling jackets will make water connections and mounting plates now (the small motor in the pic is a 3s motor from my trex helicopter to show how big these motors are )
its a low KV 4 pole motor should get away with running a twin 10s setup
madphil is offline Find More Posts by madphil
Old Nov 06, 2012, 07:34 PM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
That is a bunch of motor Phil. At the 10 horse level that's pretty much the same as the Castle 2028.
I'm getting ready to test the 910 kv version as a single for Dave this weekend if the weather permits. The one he got is a litttle shorter than the 2028 but was able to slip it into the 2028 mount with no real problems or even moving a mount on my rails. (Well, I will be using a zip tie to hold the motor down on the rear mount, but that's about it).
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Nov 07, 2012, 02:57 AM
madphil is offline
madphil's Avatar
bolton england
Joined Jan 2009
its the same spec, size and output as the castle 2028 have you any recomendations on prop size to start with , 2 or 3 bladers ?????
running twin motors i have found they work together so you can run slightly bigger props
phil.
Old Nov 07, 2012, 04:13 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
As a single my 2028 will spin an Octura X460/3 with no problem. Peak amps aound 205 and averaging in the low 100's over a 6 lap run. The challenge could be in finding a set of counter rotating props that big.
The motor I'm testing for Dave is the smaller, higher kv version. Not as strong as the ones you have.
Old Nov 07, 2012, 09:28 AM
brushman is offline
Find More Posts by brushman
Joined Oct 2007
hello,
you are crazy people! may be you should take a Tesla's motor next!
If the weather is fine for me next week , I will try to fry my 4092 for the 60mph mark.
I will post about!
Good luck for your tests!
Vincent
brushman is offline Find More Posts by brushman
Old Nov 11, 2012, 10:47 AM
madphil is offline
madphil's Avatar
bolton england
Joined Jan 2009
Done a bit more today made some alloy flange mounts and alloy rear caps these are BIG motors ( the original HET motor looks pathetic at the side see pic ) just enough room to clear the hatch will need to move my ESC back to get the balance right , can drill the water outlet fittings now the motors are fitted will have to offset a little to clear hatch
i have found some R/H and L/H 55mm 3 blade props hopefully that should give me a bit of lift and work on 10s
Old Nov 11, 2012, 04:45 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I like the bling effect of the end caps. That looks pretty cool.
Are you going to add a support for the wire end of the motors?
Old Nov 12, 2012, 02:40 AM
madphil is offline
madphil's Avatar
bolton england
Joined Jan 2009
Yes Bill the end caps will be drilled and tapped M4 to take the front mounting bracket
EDIT - have made alloy front support now and fitted water outlets
Old Nov 12, 2012, 11:50 PM
SARCFAN is offline
Find More Posts by SARCFAN
Joined Dec 2010
It seriously looks like overkill. But I can't wait to see it run. No shortage of power here
SARCFAN is offline Find More Posts by SARCFAN
Old Nov 15, 2012, 10:30 PM
Pseudonym is offline
Find More Posts by Pseudonym
Pseudonym's Avatar
Joined Apr 2012
Wow, that's a lot of motor for a 41" cat!
You have plenty of room on props. Those motors should be able to turn 65mm+ props in a twin setup. I have some in stock and I have compared to my 2028s, everything seems to measure the same except a slight difference in the case machining.
I'm looking forward to seeing this one run!
Pseudonym is offline Find More Posts by Pseudonym
Old Nov 16, 2012, 02:55 AM
madphil is offline
madphil's Avatar
bolton england
Joined Jan 2009
Thanks Guys , its getting close to hitting the water now ,
Pseudonym they are the same size / spec motors as the castle 2028 i have made my own alloy cooling jackets , flange mounts and bling end caps thats why they look a bit differant
just waiting for my new flex / shafts to come also i am very limited on counter rotating prop options any help or links for larger props would be a great help to me .
thanks , phil.
Old Nov 16, 2012, 08:58 PM
Pseudonym's Avatar
Joined Apr 2012
thanks , phil.
Your jackets/mount/caps look great, nice work!
What I meant by the case difference, is that the Sky motors are machined slightly different. The castle 2028 water jacket doesn't fit without an o ring swap.
I think the props you have are probably a good starting point on that hull, but if you end up wanting more pitch you could look here:
http://www.prop-shop.co.uk/
They are expensive but they have some hard to find props. Props come balanced according to them, but make sure you still balance them...they really aren't balanced that well most of the time.
Old Nov 25, 2012, 01:41 PM
madphil is offline
madphil's Avatar
bolton england
Joined Jan 2009
At last my new 1/4" struts with stainless tubes have come with RH and LH 1/4" shafts stepped down to 3/16 for better prop choice
also i have got some right / left handed heavy duty couplings much bigger than my old ones ,
the boat was fitted with 3/16 shafts i was told i could run up to 60mm props on 3/16 shafts thought i would step up to 1/4" and then its up to the job from the start i will get them fitted this week
i hope my props come soon need to get testing before the snow and ice come in the next few weeks
Old Nov 25, 2012, 07:25 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
When you're putting close to10 hp through it you really need the 1/4" drive.
I had a 3/16" drive in my 47" mono originally (when I built it with a 1527 Neu) and didn't bother switching it after putting the 2028 in it.
Until the 2028 tied it in a knot.
Old Dec 06, 2012, 11:10 AM
madphil is offline
madphil's Avatar
bolton england
Joined Jan 2009
Well its all fitted and running now but still waiting for my counter rotating props
i have changed the angle of the prop tubes and managed to get the C of G of the motors much lower and with the re position of the ESC's i have got the over all C of G where i want it with loads of adjustment FWD and AFT to get the balance right once its on the water and the slots on the strut brackets have been elongated to give loads of adjustments with prop angle etc
with the batterys fitted low down in the sponsons i can hold the boat on its side at 90 deg let go and it will still fall the right way up so this low Cog will help on corners
i have cut everything down to save weight its 1.5KG more now with the bigger motors and flexes / struts so ready to run it tips the scales at 7.5KG that should help with the power to weight and hopefully improve the run time
Discussion 41" Carbon fibre Falcon madphil Racing Boats - Electric 110 Sep 02, 2013 09:01 PM
Sold NIB 3DHS 41 Edge 540, New ICE 50, HS 5085MG, Omega motor HKC3 Aircraft - Electric - Airplanes (FS/W) 3 Jun 26, 2012 01:42 PM
For Sale Carbon Kevlar 41" Falcon Cat Kit - PRICE UPDATE RickHap Boats (FS/W) 0 Apr 27, 2012 05:41 PM
Discussion 41" Falcon catamaran pcnewman Racing Boats - Internal Combustion 9 Jan 31, 2009 10:45 PM
Choosing a New Electric Motor for my falcon IcanHover Micro Helis 8 Feb 12, 2004 09:03 PM
