Old Dec 03, 2012, 12:15 AM
SRWitt is offline
Find More Posts by SRWitt
Joined Jan 2011
Do a search on google for draftsight. It is a free program, made by Dassault Systems. It is a very good basic 2d cad package. It is basically an Autocad clone, and their are online tutorials/manuals for it from Dassault. Dassault is one of the big names when it comes to professional CAD software.
Check out my thread http://www.rcgroups.com/forums/showthread.php?t=1780419 I'm converting an hand drawn free flight plan into CAD format, fixing errors along the way, with the intent of scaling the model to 150% when I'm done to give me a 33" span plane to build as R/C. You can see pictures of how/what I'm working on.
SRWitt is offline Find More Posts by SRWitt
Old Dec 03, 2012, 06:55 AM
BJ64 is online now
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
Originally Posted by Eclat View Post
Hello All,
After lurking for a long time I thought it was finally time to join the forum and with it post a request for help.
I am looking to restart designing my own near scale models and rather than sitting with pencil and paper in front of me I am looking at learning CAD and who knows maybe get kits cut from my efforts.
Can anyone offer advice on programmes, reading material to learn the subject and general advice etc etc.
A broad subject I know but I am all ears and genuinly wanting to update my skill set.
Many thanks in advance :-)
I'm in the same boat, Eclat.
Time to bite the bullet and learn something - but ho-li moley, is there ever some choices out there.
So far, I've learnt that whatever you design with, you still need something that will convert your drawing/3D model into something that a CNC Hotwire unit will understand so that it can actually do the cutting based on the drawing/solid form. Like Mach 3 if you're running G-code - the design software such as DevFus gets as far as producing the the code required by the machine to cut the job, but you need that extra bit in between to actually drive the cutter.
There's another Gsomething package - cant remember the acronym just now - that does it all (design, and cut from the same software without the need to output from one system and input into another (??)).
I could have that totally wrong, but I'm wading my way through a zillion Google pages at the moment - keen to learn enough to get me started.
What I'm really trying to find, though, is some software that will work back the other way around. I have some drawings with a full set of accurate cross-sections (formers, bulkeads, whatever you want to call them). Included is a half-plan view, and an elevation view - with the cross-section positions accurately marked on them.
So... in theory...all I need to do is read my (scaled) cross-sections into something, tell it where each cross-section lives in real space, and align the cross-sections to reference makers on the the drawings.
DevFus, DevFus Foam etc. look like they work by taking a 3-view diagram and going the opposite way i.e. attempting to create the cross-sections by creating a 3D image from a set of 2D drawings.
So I guess I still have a bucket-load of reading to do to find something that will accept my cross-sections/spacings/reference line offsets to create the final 3D solid form - which something like DevFus Foam ends up with, and I can finally cut the various fuselage sections using the CNC Hotwire machine.
If anyone understands what I just wrote, and knows the best way to go about converting my cross-sections and other related info into physical chunks of foam (that I can assemble and make a plug out of), I'd most grateful to hear your opinions...
BJ
PS - one other alternative is to print the cross-sections, stick them to 3mm plywood, cut/file/shape them until they're good enough to hotwire around a correct length of foam, then assemble those 'chunks' to make the plug. Which I've already started doing. But seriously, cutting 20+ of these suckers on a scroll saw, sandng/filing them is already driving me nuts. CNC Hotwire would be the go - if I just figure out how to get the friggen cross-sections back into a CAD package suitable for 3D rendering/cutting on a CNC rig...
BJ64 is online now Find More Posts by BJ64
Old Dec 03, 2012, 07:13 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
BJ,
Any 3D cad package will allow you to import cross sections from a 2D scan or print or pdf and rotate / align them and loft them into a 3D object. I do this all of the time in Rhino, importing airfoils that were created as 2D files (simple X,Y coordinates) and rotating / aligning / lofting them into complex wing structures.
I don't want to sound like a commercial for Rhino but I've really been impressed with it over the past few years and I have found that I an create just about anything I can imagine.
tom43004 is offline Find More Posts by tom43004
Old Dec 03, 2012, 07:46 PM
BJ64 is online now
BJ64's Avatar
Joined Jun 2009
Thanks Tom,
I have not had a look at Rhino yet, but I'll see what I can find.
I guess the main points regarding the use of CAD/CAM software are:
1. Does the software do what I want it to do (assuming I know what I want to do in the first place LoL).
2. Price.
3. Ease of Use.
4. Time required to get up to speed to be able to use the package fluently.
It can be so very, very confusing and frustrating learning all this stuff. You think you understand it, you go to do something, then you find out that there's a piece missing and you have to buy something else (and learn how to use it - again )
I'm a bit perplexed why you would want to use a 2D CAD if what you're trying to achieve is a 3D solid.
Is that just to digitize the cross-sections and save them in a format that is recognized by a 3D CAD/other software down the line?
For example, a 2D CAD isn't going to let me place my cross-sections along some kind of reference line in order to make the jump to 3D (?) - or does it?
I can see I have a loooong way to go in the learning curve yet...
BJ
Old Dec 13, 2012, 02:37 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
About Rhino ... It is not the easiest program but I love it....
You rather have the very most degrees of freedom in design ... if you would be able to handle it, so it is your decision if the results pay for the expenses you will have to invest ( money and time) ... some samples...
Harpye is offline Find More Posts by Harpye
Old Dec 13, 2012, 11:42 PM
BJ64 is online now
BJ64's Avatar
Joined Jun 2009
Fast alles Luftwaffe
BJ
Old Dec 14, 2012, 01:43 AM
Harpye is offline
Harpye's Avatar
Germany
Yes, but very international!
The Hurricane is British
the Comet , too ... but civil avionics
and the SPAD is French
Also have a worksheet about an Extra 300 in rhino to offer
Old Dec 24, 2012, 08:01 AM
BJ64 is online now
BJ64's Avatar
Joined Jun 2009
Merry Christmas (or Fröhliche Weinachten) fellow "CAD"ers.
I'm slowly learning this stuff - thanks to your help...
BJ
Old Dec 25, 2012, 02:51 AM
deckert is offline
Find More Posts by deckert
Plowin Dirt
deckert's Avatar
USA, WA, Benton City
Joined Oct 2007
Hello All,
Just for the heck of it, why not try SketchUp from Google? It's a 3d program that's quite intuitive, fairly easy to learn, is totally free and isn't a resource hog. There are a TON of already made designs that you can DL and modify if you so choose to aid in understanding the program. Granted it's not the same quality as ACAD, Rhino or others and has limitations. But it's intutive interface and online help is quite extensive. There are literally hundreds of thousands of individuals world wide that utilize this pgm. to render images and perform design work that's beyond belief. It's not intended nor designed to replace an actual CAD type program but still performs things a CAD user would find surprising.
Dan
deckert is offline Find More Posts by deckert
Old Dec 25, 2012, 05:33 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
hi harpye how abbout another work shop in the new year use rhino and import from other sofware bits say wing from compufoil3D or profil and so on the Hurricane sounds good
dpot is offline Find More Posts by dpot
Old Dec 25, 2012, 06:11 AM
Harpye is offline
Harpye's Avatar
Germany
Just started a kind of common built project in a German forum ... but that is also difficult as all participants are rather new to CAD..... and two projects are too much in parallel! ( I did this within 4 days but no one of the others did start with the project!! See pic below)
( another thing is that I have two bigger projects at the job and currently don't know where to start and where to end!)
A dream which once came true with the more local situated modellers was to
gather for a CAD modelling and flying weekend , but in the current situ and with the international background, it would be impossible to do that ( more than half of the guys in here are from The States and flying overseas just for a long weekend would be a bit inefficient and expensive ( but I'd love to go there - quite for a bit longer - and even if it would not be RC related I'll go there once))!
Old Dec 25, 2012, 09:10 AM
dpot is offline
dpot's Avatar
Joined Dec 2005
i no what you mean there is all ways lots to do i have just moved from Britteny france to Allier france and am still seting up my new workshop may be later in the year.
Old Dec 25, 2012, 02:21 PM
Harpye is offline
Harpye's Avatar
Germany
We'll see! ( please let me know how far your new home is from Freiburg (Germany) ? )
Old Dec 25, 2012, 04:35 PM
BJ64 is online now
BJ64's Avatar
Joined Jun 2009
16,395 km - in a straight line.... LoL
BJ
Old Dec 26, 2012, 12:17 AM
Harpye is offline
Harpye's Avatar
Germany
Did not test it but I think I might remember where Australia is .... ( THought about dpot ... France is more or less neigbourhood compared with the Outback).
Perhaps sometime - so I decide to build a Vickers Vimmy in 1:1 scale .....
Discussion where do I start? Readability Foamies (Scratchbuilt) 5 Apr 30, 2012 10:09 AM
Help! Where do I start to search for a problem I don't know if exist? Denominator Multirotor Talk 3 Apr 29, 2012 07:24 PM
Question Where do you get your trim designs and how do you test them? dedStik The Builders Workshop 16 Mar 15, 2012 03:32 PM
Question Where do I start with CAD? Sam Dawson The Builders Workshop 64 May 12, 2009 02:28 PM
3D fusealage design in CAD where to start?? superdave42 The Builders Workshop 21 Oct 17, 2004 01:19 PM
