Old Nov 06, 2012, 01:47 PM
TurboRacer is online now
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
Help!
Trying to fit an outrunner to old FMA Direct Razor 400
Hello! I need to start by saying I have zero experience with flying wings!
I was walking around my attic last night, and found an old FMA Razor new in the box. No electronics, just the airframe.
The airframe has mount for Speed 400 motor.. I'm guessing we're talking about 2000-2002 or so here
My question - what would be the easiest way to mount a brushless outrunner motor to this wing? I have two outrunner motors I already own and I think would be ideal to use, so I'd like to not have to buy another motor. I have lipos, ESC, servos... I really just need to build the thing, and mount the motor.. I'm also planning on adding a CF tube spar to join the wings for more rigidity. I am *hoping* to build a VERY fast wing... Is 100mph possible?! hahaa
I think I can figure out the TX programming and airplane setup, really I just want to know from you guys what you think would be the best way to mount a motor on that wing.. I was planning on getting out some scrap wood and just going to town, but I think others must have done this before and can save me some headaches!!!
Thanks for any help! Looking forward to getting this thing in the air!!
TurboRacer is online now Find More Posts by TurboRacer
Old Nov 07, 2012, 06:38 PM
Justo23 is offline
Find More Posts by Justo23
right between the batteries
Justo23's Avatar
Farmington UT
Joined Jun 2010
I would mount a piece of 1/4" ply or a piece of 1/16" metal to the back of it's built in motor mount... then you could mount the motor to that.
I would use this motor, with this prop... but you may have other products in mind
Best of luck,
...oh and i almost forgot. these wings have been known to get bad flutter at high speeds, so some extra CF spars and tweaking may be needed.
Justo23 is offline Find More Posts by Justo23
Old Nov 07, 2012, 07:52 PM
Murman is offline
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
What two motors do you have?
Murman is offline Find More Posts by Murman
Old Nov 08, 2012, 09:50 AM
TurboRacer's Avatar
Joined Oct 2002
For motors, I have a Scorpion HKII-2208-28 - http://www.scorpionsystem.com/catalo...22/HK-2208-28/
And I have the BL motor off a Flyzone FW-190 which the site lists as a 41-19-900kV motor and 30a ESC.. I was thinking the Scorpion may be the better fit because of it's size... What do you guys think?
Thanks for the help!!!!
Old Nov 08, 2012, 12:43 PM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
I think the Scorpion would be the best choice also, especially if you are wanting to make your wing fast. However, with a kv that high, you will limited to a 4" prop.
Old Nov 08, 2012, 12:58 PM
TurboRacer's Avatar
Joined Oct 2002
4"? That thing is going to scream I think with a 4" prop.. hahaa... I'm willing to try though!
I am going to go to the hobby store tonight and see if I can find a prop adapter and prop for it.. Do I *need* a pusher prop or can I use any prop and spin it around?
What about the battery - I have a bunch of 3S 1300's - think that would be a good place to start?
Old Nov 08, 2012, 01:17 PM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
You could try your 1300's but you may need larger batteries in order for the wing to balance.
Old Nov 08, 2012, 02:37 PM
Justo23 is offline
Justo23's Avatar
Farmington UT
Joined Jun 2010
a regular prop will work just fine turned to push, you will just have to swap 2 of the connections to the ESC if it tries turning backwards.
Old Nov 08, 2012, 02:42 PM
TurboRacer's Avatar
Joined Oct 2002
Perfect.. That's what I was thinking... Alright.. Hoping my hobby shop has these things in stock and I can start building tonight
Thanks again for the help.. Will post as I go..
Old Nov 08, 2012, 02:51 PM
mthomas is offline
Find More Posts by mthomas
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
Turboracer - I have one of these that flies really well on a 3s1800 and a 2409 bell type motor and a regular 7 x 5 prop. These pusher wings do not need a different prop, just be sure that the letters on the prop face forward.
Also, my Razor seems to lose almost all responsiveness at landing speeds. I tend to make sure that I am lined up for landing before I slow down too much for landing.
Mark
mthomas is offline Find More Posts by mthomas
Old Nov 08, 2012, 08:32 PM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
When a motor is mounted on the front of a plane, it produces an air flow across the control surfaces. Even when the plane slows down for landing, the motor is still pushing air across these surfaces and the plane is still responsive.
With a rear-mounted motor, there is no airflow from the motor reaching the control surfaces so the more you slow down, the less air is flowing across the wing, and the less control you will have.
Larger elevons would help to make it a little bit more responsive at slow speed.
Old Nov 14, 2012, 12:20 AM
TurboRacer's Avatar
Joined Oct 2002
Well I am trucking along.. Here's one night of work so far:
All that's left to do is attach the elevons, tape the structure, set up the radio profile, and balance it.. I spun up the motor on a battery with about 70% charge and HOLY CRAP that thing puts out some thrust!!!! I could barely hold on to the motor. Can't wait to see it in action. I hope the maiden goes well! Will probably be this weekend!!!
Old Nov 14, 2012, 05:57 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Looks great, interesting. Did you secure the prop too? It looks loose to me.
PHMX is offline Find More Posts by PHMX
Old Nov 14, 2012, 06:05 AM
TurboRacer's Avatar
Joined Oct 2002
No, the prop was loose in those pics. I may do a zip tie around the stick that the motor is mounted on. It feels pretty sturdy though, I was stressing it pretty good and it didn't even flex. We'll see how it holds up!!
Old Nov 14, 2012, 01:03 PM
PHMX is offline
Joined Feb 2011
I think the motor will be fine, but a loose prop doesn't sound like a good idea. For best thrust it'll definitely need to be fixed to the shaft, right.
Discussion trying an old futaba with the Raptor 30 cruzroy Fuel Heli Talk 0 Mar 29, 2012 09:12 PM
Question upgrading an old thunder tiger sparky 400 to a brushless setup hermanmango Electric Plane Talk 11 Mar 16, 2012 04:41 AM
Question Pulsar 2005 - F5J 400 (would an outrunner fit?) down_shift Electric Sailplanes 3 May 19, 2006 03:26 PM
Need CG for an old FMA Razor wing ptglass Flying Wings 14 Oct 24, 2005 06:41 PM
Article The FMA Direct Razor ARF - Speed 400 Version Travis Ballou Electric Plane Talk 0 May 10, 2000 12:00 AM
