Espritmodel.com Heli Air
Old Nov 06, 2012, 01:10 PM
Joined Nov 2012
Flycam - MCFC
I think its about time to start a own thread for the new Flycam board -> MCFC
Here we can discuss settings, experiences, challanges , etc
- Pepsi
___pepsi___ is offline Find More Posts by ___pepsi___
Old Nov 07, 2012, 02:36 AM
RTFM // copter damaged
warthox's Avatar
Joined Aug 2009
heres a photo of my mcfc. i hadnt the time to fly it yet...
warthox is offline Find More Posts by warthox
Old Nov 07, 2012, 03:12 AM
Joined Jun 2006
Does it multiwii bord?
titeuf007 is offline Find More Posts by titeuf007
Old Nov 07, 2012, 06:01 AM
Slovenia, Ljubljana
Joined Sep 2011
No, this is not multiwii board.
er9xuser is offline Find More Posts by er9xuser
Old Nov 07, 2012, 02:07 PM
Joined Nov 2012
First Test
I have now preformed a first test of my octocopter with MCFC.
All the calibration was done according to Minsoo's manual.
What I noticed was that first GPS fix took approx. 10 minutes. As one should be aware of is that downloading the GPS almanac can take up to 20 minutes (worst case).
Octo seemed very stable, responded well to input.
Altitude hold worked like a charm, tested it at 1,8m and 30meter. Seemed very stable.
GPS hold position was tested and found to be pretty good, somewhat of pendulum movement within 1-2 meters. I think this probably will be solved by changing PID parameters.
RTH also worked well, with a bit of overshoot, I think this also will be solved by tweaking the PID parameters.
Also tried out carefree, also worked.
I will try to change the parameters when the wheater improves, Snow and wind in Norway!
- Pepsi
Old Nov 08, 2012, 01:33 AM
Joined Apr 2008
Hi All
Thank you for supporting
it will be released soon the MCFC firmware 1.1 ver.
- Bug fixed.
- pusher copter include
please see a video for pusher copter
FlyCam MCFC Pusher Copter (4 min 8 sec)
Minsoo Kim is offline Find More Posts by Minsoo Kim
Old Nov 12, 2012, 12:23 PM
Belgium, Vlaams Gewest, Sint-Truiden
Joined Jul 2012
Hey guys , i also got my MCFC board setup,first think i want so solve is wen i take of in autolevel,take of nice and steady but wen i stay of the sticks the quad just fly to the right and a little to the back, do i have to trim this out with TX?It like auto level is -1° to the right.
or do i level the quad out and recalibirate gyros and accel?
So how about the pot meters?wen does the yaw pot has effect,becasue there is also a yaw PID attitude.or how do these work together?
The pitch/roll pot meter? have no effect in auto level only acro mode right?
Then the groundstation for gps waypoints! I connect the MCFC board to the laptop and outside i get like 8-10sats, also see the quad on google maps.So i set out some spot and click write.
Disconnect the usb cable and go to the backyard, flip the 8ch switch till 3rd position and the quad turns heading my.go back hook it to the laptop and do a read waypoint and says no waypoint hhmm, what am i doing wrong here?
grtz
GeO82 is offline Find More Posts by GeO82
Old Nov 12, 2012, 05:09 PM
Joined Nov 2012
As for trimming, this is not necessary. Do a stick calibration according to Minsoo’s manual.
However you should ensure that the frame and board is in the same plane.
Potmeters have no effect when not in acromode. However certain settings will set the MCFC in various modes (See manual).
As for waypoints, I haven’t tested those yet.
Pepsi
Old Nov 13, 2012, 01:56 AM
DVE
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
Analog resistors on the board for tuning - strange solution for 2012 year
Or its a "Kuk style", from first KK boards?
DVE is offline Find More Posts by DVE
Old Nov 13, 2012, 03:03 AM
warthox's Avatar
Joined Aug 2009
whats an easier solution in your opinion?
are there digital resistors available?
Old Nov 13, 2012, 03:45 AM
DVE
Joined Jul 2011
All Multiwii/Naza/Wookong/Arducopter/etc boards have digital tuning, btw
Is seems enough for users, and its better to save/load/analyze parameters.
Old Nov 13, 2012, 04:12 AM
warthox's Avatar
Joined Aug 2009
i know it was meant in relation to the resistor.
it wasn't meant that seriously
Old Nov 13, 2012, 04:13 AM
Joined Nov 2012
As an electronics engineer I rather use analog pots than digital pots for tuning.
PS: KK stands for Kaptein Kuk which translates from Norwegian into english as Captain Dick
Pepsi
Old Nov 13, 2012, 04:50 AM
DVE
Joined Jul 2011
Yes, analog pots of course can be used for some tuning, but for expensive board (400$ is not too cheap) it seems not serious, imho
It looks like crappy 28$ boards from Hobbyking...
Old Nov 13, 2012, 07:18 AM
Joined Nov 2012
As for digital pots, they have less accuracy than analog one's. (more noise).
As for the design I think it looks fairly good, but I will not know for sure until I have tested it over time.
Pepsi
Sold Alware flycam V2 Camera mount and landing gear NEW $25 RChelisrule Aircraft - Electric - Multirotor (FS/W) 2 Jun 20, 2012 08:34 PM
For Sale Flycam Blackboard + FlyCam Naviboard + FlyCam Sonar + Gps Plate + USb to Serial cafecubain Aircraft - Electric - Multirotor (FS/W) 2 Mar 05, 2012 06:09 PM
Sold FlyCam Naviboard Set & FlyCam Blackboard Set. Dingo745 Aircraft - Electric - Multirotor (FS/W) 6 Nov 07, 2011 07:57 AM
For Sale KKMulticopter FlyCam Naviboard Set + FlyCam Blackboard Set. Dingo745 Aircraft - Electric - Multirotor (FS/W) 0 Oct 22, 2011 08:31 AM
