Old Nov 06, 2012, 09:14 AM
theheed is offline
Find More Posts by theheed
Joined Nov 2012
turnigy ntm 50/50 motor
has anyone had any experience with these?
whats the performance like?
looking to put one on my angel 50 running 5s
theheed is offline Find More Posts by theheed
Old Nov 06, 2012, 12:02 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
We will need some more info to help. The motors total spec, including KV! Prop size, battery size and voltage/c ratings. Plane weight estimate. Remember the 3 amps/gram of motor weight when estimating the actual watts the motor can handle safely,esp with the HK's optimistic ratings. Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Nov 06, 2012, 12:31 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
http://www.hobbyking.com/hobbyking/s...0KV_2000W.html
As Doug suggests...... HK is VERY optimistic if they expect a 347g motor to survive well at 2000W!
If we believe their prop data, 14x8 on 5s might be manageable. 60A/1100W would seem rather more sustainable than 90A/2000W.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 06, 2012, 03:22 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
I have the 50-60 270Kv, but have not put it on a plane yest. Seems well made and magnets well glued unlike the other Turnigy motors. I don't know if this means anything, but the windings wire is definitely thicker than that used in the Turnigys I already have (all Gold motors), so maybe it can handle more amps, but I agree that 90A seems awfully high. While not necessarily reliable, user reviews of this motor on HK site seem good so far, which is not always the case for their other motors.
I would take that 90A with a big grain of salt. I bought this for a 1/7 Sea Fury on which I plan to run either a 16x16 APC pattern prop or a 5-blade custom (probably 16x14) from Zinger. Both will be 8S setup at this point. I'll definitely bench test before it goes in the plane and report back on how it seems to handle high amps.
TTRotary is offline Find More Posts by TTRotary
Old Nov 06, 2012, 09:51 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
Scorpion quote ~1900W for a 310g motor so it is not too unreasonable, provided turnigy are also using high-temp magnets. As we can presume this to be unlikely since the scorpion motor in question (http://www.scorpionsystem.com/catalo...s40/S-4020-12/) costs ~$140 the numbers would seem to be exaggerated considerably.
desertstalker is offline Find More Posts by desertstalker
Old Nov 07, 2012, 12:44 AM
TTRotary is offline
Joined Mar 2010
I'm a Scorpion fan but price is not everything. All these motors are made in China, but prices are significantly different: The Turnigy G46 ($45) is a copy of the Eflite Power 46 ($95) which is a copy of the AXI 4120/14 ($139). All three perform about the same and only the AXI has truly superior quality of components. Same goes for batteries - Thunder Power will happily charge you 3X what Turnigy will for what is basically the same battery.
Now, I happen to believe that Scorpion motors do truly use exceptional components and perform accordingly. But in other cases (especially Eflite / Horizon) you're just paying more for the name. Again, I'd take the amp claims on the NTM with a grain of salt, but Turnigy has no advantage in grossly overrating their motor either. All they will get for that is bad press. For the record, I have run my Turnigy Gold motors to their maximum spec numerous times and they are none the worse for wear. As long as you check the magnets for glue and threadlock everything, their stuff holds up.
Old Nov 08, 2012, 08:49 AM
theheed is offline
Joined Nov 2012
thanks for the comments everyone.
im looking to run it on 5s, propping at about 15 x 8/10 so hopefully this should let put it around 60 - 70amp full beans.
its just arrived today, but here in the uk someone in hobbyking forgot to stock the accessory pack so i can mount the bastard!
ive got spare 50 size rear mounts, just not the prop adaptor to fit....
Old Nov 09, 2012, 02:14 AM
Dacono Air is offline
Find More Posts by Dacono Air
Certifiable
Dacono Air's Avatar
USA, CO, Dacono
Joined Aug 2009
I picked up the 50/50 back in June for a project that I just seem to keep putting off....someday I'll get it airborne
My initial impression is that this motor is pretty strong although is comes to life running on 6s (22v) but thats just my 02'
I plan on disassembling it before putting it into service just to check the welfare on the magnets....some of the later reviews on HK's website has me spooked.
The fallowing video is my testing, no 5 cells in my arsenal so forgive that.
.......as posted on video info.......
Power Testing the NTM 50-50 580KV Motor as recieved from HobbyKing.
Turnigy 4000mah 6 cell lipo (40c)
APC 15x7
Castle Phoenix Ice Lite 75
1443 watts @ 65.5 amps. (22v)
other tests not video'd
APC 14x7 - 1198w @ 53 amps (same voltage)
APC 13x10 - 1436w @ 61amps (same voltage)
NTM Prop Drive 50-50 580KV Test (1 min 20 sec)
Dacono Air is offline Find More Posts by Dacono Air
Old Nov 09, 2012, 03:18 PM
theheed is offline
Joined Nov 2012
It was seeing your vid on YouTube that made me go for it! On 5 cells I'm expecting around 1000 plus watts which will be plenty. The motor seems fine upon inspection, so fingers crossed
Old Nov 09, 2012, 03:38 PM
Certifiable
Dacono Air's Avatar
USA, CO, Dacono
Joined Aug 2009
Yes! keep us posted, I for one would like to know how it does on 5cell....before investing in more batteries.
Old Nov 10, 2012, 07:28 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Originally Posted by Dacono Air View Post
..<snip>...
The fallowing video is my testing, no 5 cells in my arsenal so forgive that. ..<snip>...
The info in your testing is interesting but, unfortunately, it appears that you are using the same method that HK uses for getting their specs. A peak reading from a 2 second or so run without any temperature monitoring looks good but it leaves some questions unanswered...
I'm not trying to be unappreciative or criticize you, it is just that the testing needs to be more like the motor will be used as far as throttle openings and durations. And the temp rise and max temps seen are a pretty key piece of info.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Nov 16, 2012, 12:30 AM
TTRotary is offline
Joined Mar 2010
Not an oversight. For reasons known only to HK, they've decided that the accessory pack on the NTM motors is not included. You have to purchase seperately, and the site is silent on this. Pretty dumb, but that's how it is. The only reason I figured it out was people bitching in the reviews.
Old Nov 16, 2012, 12:30 PM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Information provided by HK, if true, can be deduced:
With 6s, 15 x 8 - 22.2V / 1961W / 88.8A / 6.15 kg (assuming that it is an APCe)
8,650 rpm, 60.8% efficiency, 777 watts of heat.
Impossible to use the engine in these conditions.
But with:
15 x 8 - 18.5V / 1165W / 64.2A / 4.85 kg thrust,
7800rpm, 73.4% efficiency, 316 watts of heat.
Within the limits. previous measuring amperage.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Nov 16, 2012, 05:20 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Originally Posted by manuel v View Post
But with:
Manuel V.
Great minds think alike, Manuel: This is in the ballpark I suggested earlier
Old Nov 17, 2012, 11:30 AM
Joined Oct 2008
Thanks Dr Kiwi, Manualv for confirming my suspisions on the 5050/580.
A couple of weeks ago a fellow flyer brought plans to show me. It an 84" Eurocoupe, espected weight around 13-14lbs.
He then mentioned he intended to order this 5050/580 motor. I baulked right away. When I looked up the specs it was obvious that once again HK is dreaming!
He wanted to stay with the same line of motors, after looking, I selected the 5060/380 as a more suitable choice with a 15/16 prop to try for 1400watts on 6S.
I guess your wisdoms are starting to rub off, hehe. Doug B
Discussion 4258 turnigy ntm motor on sebart angel 50 theheed Power Systems 0 Nov 06, 2012 08:54 AM
Discussion Turnigy Park480 vs NTM Prop Drive Series 35-30 NetCode Power Systems 10 May 17, 2012 05:40 PM
For Sale Turnigy NTM 42-58 500kv LICobra Aircraft - Electric - Power Systems (FS/W) 1 Feb 10, 2012 03:55 PM
Sold Turnigy NTM Prop Drive Series 35-30A 1400kv scottc39 Aircraft - Electric - Power Systems (FS/W) 6 Jan 02, 2012 07:12 AM
Question How similar are Turnigy, SK3, and NTM motors? wopachop Power Systems 5 Nov 28, 2011 12:33 PM
