Old Nov 06, 2012, 10:12 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
Idea
ten cent tach
after minor issues finding good motors for my diy quad thread (http://www.rcgroups.com/forums/showthread.php?t=1710948) i decided to resurrect an old method for measuring rpm. it depends on the fact that leds are actually photovoltaic devices. basically small solar cells that can function as optical tachometer. normally i use an ohm meter to get an estimate of kv but it dont always tell exactly how the prop/pager combo will perform. the thrust stand in my indoor micro thread is obviously most accurate but not as convenient to set up as this simple led tach. and that scale dont cost 10 cents either.
i was talking about the led tach this weekend and somebody wanted to see pics. if its of any interest i can go into more detail but lets start out with the photo. ive added a couple scope traces from my tektronix 210 but you can use one of those free pc soundcard scope programs. the 1st trace shows a cheapo aliexpress motor that worked out pretty good but had .8mm shaft which required tricks to fit 1mm prop hole. the other one is of replacement motors he sent that had 1mm shaft as advertised but much weaker. looks like 1.2ms per blade for 23k rpm vs 1.9ms at 16k rpm. i was surprised a small difference in rpms made such a big difference in flight ability.
dave1993 is offline Find More Posts by dave1993
Old Nov 06, 2012, 01:30 PM
Zen09 is offline
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
http://www.rcgroups.com/forums/showt...cheap+tachomet
Zen09 is offline Find More Posts by Zen09
Old Nov 06, 2012, 02:03 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
oh MANNNNNN! (bart voice) and i thought this was my "bright" idea only. lol! thanks for that link. those programs seem perfect for this application:
http://techmind.org/audio/tuner1v3.exe
http://www.jonbondy.com/software/Setup_DYNO.EXE
i havent tried either one yet but they look to be much better than a simple soundcard scope.
btw the problems you had there may have been related to the ir sensor used. ir led was the first type i tried because they have far more output than visible ones (longer the wavelength, higher the voltage). and it worked great on the black props i started with. then a problem cropped up when switching to orange udi prop. NO SIGNAL AT ALL! turns out ir passes right through those like they arent there. switching to green solved that problem but signal amplitude was very low for reasons just mentioned. finally settled on plain ol' red which happen to be cheapest too. also note that only clear lens, not diffuse, will work.
Old Nov 07, 2012, 01:33 AM
Zen09 is offline
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
The DYNO program is much much better, it can also calculate the torque and power curve for a motor by deriving the rpms (taking into account the moment of inertia of a flywheel).
It doesn't show live rpm though
The revcounter does show live data, but it was initially developed as a frequency counter (and later modified by my suggestion) and is quite limited.
Old Nov 07, 2012, 10:27 AM
fizzwater2 is online now
Find More Posts by fizzwater2
United States, KS, Overland Park
Joined Jun 2007
23K rpm is over a 40% increase from 16K RPM - that's not a "small difference" -
fizzwater2 is online now Find More Posts by fizzwater2
Old Nov 30, 2012, 04:52 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
yes, but the difference in lift and controllability seems much greater. maybe 2 or 3 times more so idk.
Old Dec 04, 2012, 01:47 PM
midelic is online now
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
Of course because the relation between lift and speed is not linear ..it is quadratic.
It sounds better "exponential".
In fact the lift increases with the square of speed(rpm).For example if the speed doubles the lift increases 4 times.
midelic is online now Find More Posts by midelic
Old Dec 05, 2012, 01:34 PM
Zen09 is offline
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
It's not exponential either, but the second power of rpm, though I know what you meant.
Discussion 99 cent 72Mhz crystals at servocity.com! dylancoffin Hot Online Deals 0 Aug 16, 2012 04:47 PM
Rant Change- Usta's common cents plan to help save the economy Usta Bee Life, The Universe, and Politics 11 Feb 27, 2012 08:01 AM
Wanted Trade jr cent. 7 ss nib & Jr cent. 7 mode 2 radios. ldm1839 Aircraft - Sailplanes (FS/W) 0 May 12, 2010 06:06 PM
