Old Nov 10, 2012, 02:07 PM
Al Offt is offline
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
Stuart,
I found the article in PDF format at http://cbruder.rcmodell.hu/Strip-Plank.pdf You might be able to see the pictures in that format
Alan
Al Offt is offline Find More Posts by Al Offt
Old Nov 10, 2012, 02:55 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Originally Posted by Al Offt View Post
Stuart,
Alan
Thanks Alan,that works fine.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Nov 10, 2012, 09:25 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Originally Posted by Circlip View Post
If the strips cut in #10 are alternated as shown, you end up with a flat sheet again.
Regards Ian.
If you lay them on a flat surface, yes. It's funny how they conform to a curved surface though. You still have a small gap but it is very much less than if you had square cut strips. The small gaps are easily filled with lite weight spackle. Once you have a bunch of strips cut, it is a pretty quick process to lay them down.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: Helping a club member
Old Nov 11, 2012, 02:43 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Re fixing the planks,in the past I've used these Graupner pins.They have a really fine point and will enter a 1/16" former without splitting it.Some quick drying wood glue allows a bit of 'wiggle' time.
The pins are ideal for off the bench pinning,though they aren't strong enough to pin to the work surface.
Stuart
Question Convex hinge lines and hinge bending resistance Rogo Hand Launch 3 Apr 19, 2009 09:05 PM
Discussion Strip planking or insert planking? Jacques Flambeau Scale Kit/Scratch Built 5 Jun 14, 2007 04:09 PM
Question Robbe Gnat.. Scale Ducted-fan to Slope Soarer convex ELarsen Scale Sailplanes 1 Jul 09, 2003 10:51 AM
Idea Scale Robbe Gnat.. Ducted fan->Slope soarer convex ELarsen Scale Fuel Planes 2 Jul 08, 2003 07:09 AM
Ultracote around concave curves SheldonYoung The Builders Workshop 1 Nov 07, 2002 09:57 AM
