Old Nov 05, 2012, 10:38 PM
Hot Tuna is offline
Find More Posts by Hot Tuna
Hot Tuna's Avatar
Joined Jan 2012
T37 pnmyc
This thread is dedicated to the Pacific Northwest Model Yacht Club http://home.comcast.net/~pnmyc/index.html discussion of the T37
Hot Tuna is offline Find More Posts by Hot Tuna
Old Nov 05, 2012, 10:45 PM
Fokker Ace is offline
Find More Posts by Fokker Ace
Fokker Ace's Avatar
Joined Aug 2006
We already have a dedicated Tippecanoe thread, can't you join in there?
Fokker Ace is offline Find More Posts by Fokker Ace
Old Nov 05, 2012, 10:56 PM
Hot Tuna is offline
Hot Tuna's Avatar
Joined Jan 2012
we were thinking of something more specific to T37 and local and didn't want to intrude on either the Tippecanoe or the T37 threads
Old Nov 05, 2012, 11:07 PM
Hot Tuna is offline
Hot Tuna's Avatar
Joined Jan 2012
Attached are a couple of pics showing how I hung the keel. Tape a string with a weight (plumb line) on the center line just forward of the keel, level the boat, and then sight from the bow. Align the keel to the plumb line and you will end up with a pretty good job.
As I think about this after the fact I wonder if the level should have been on the deck or on the bottom. I assumed that the deck was parallel to the bottom, but maybe that was a rash assumption. It probably makes more sense to use the bottom, just in case they are not the same.
Old Nov 06, 2012, 12:43 AM
Hircsailor is offline
Find More Posts by Hircsailor
Kimo
United States, HI, Honolulu
Joined Jun 2011
There were several threads about building a T37 and I started a thread about my building a T50. Fokker Ace had just finished building a T37 and thought that it would be great to have a thread that covered all of Tippecanoe boats so he started the Tippecanoe Thread hoping to get a lot more people to post their experences with the T class boats.
Talking to Will I understand that the T37 has a large following in the Northwest with several yacht clubs having larage fleets of T37s that they race. Even though I live in Honolulu I will
follow any thread that covers Tippecanoe boats hoping to pick up pointers on the T37, T50.
Before the Tippecanor thread was started I called Will to get his aproveal about a Tippecanoe thread and asked if he would send an email out to all Tippecanoe boat owners about the new thread and asking them to post on the site. Hopefully your thread called T37PNMYC will pull in more sailors in your area that will add their two cents worth in either thread.
Hircsailor is offline Find More Posts by Hircsailor
Old Nov 06, 2012, 12:08 PM
marter1229 is offline
Find More Posts by marter1229
marter1229's Avatar
United States, ID, CDA
Joined Aug 2005
marter1229 is offline Find More Posts by marter1229
Old Nov 11, 2012, 10:45 PM
Hot Tuna is offline
Hot Tuna's Avatar
Joined Jan 2012
D,
Attached are the pictures of the mail boom you wanted. There are a lot of ways to rig these, this is what I have done.
Old Nov 11, 2012, 10:49 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Don't want to take away from the T37/T50... Nice boats but being in the Great PNW, can you point me in any direction regarding the "Cascade 30" class? Local to SEATAC it seemed? Very interested.
Thanks.
Aerominded is offline Find More Posts by Aerominded
Old Nov 11, 2012, 10:52 PM
Hot Tuna is offline
Hot Tuna's Avatar
Joined Jan 2012
These are the jib
Old Nov 12, 2012, 09:14 PM
Hot Tuna is offline
Hot Tuna's Avatar
Joined Jan 2012
Bowsies
Here is the pic of Bowsies made from a circuit board. These seem to be just the right size. They are a bit difficult to cut but that just means that they will be nice and strong. The ones i made from the popsicle sticks were not strong enough last Saturday. I think this will solve the problem. An added benefit is that the ends of my fingers are nice and smooth from holding these and sanding all the sharp edges off .
I have sailed with these a few times now and they have worked great
Old Nov 13, 2012, 01:10 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Great idea using PC board. My only concern is how well they will hold up in sunlight. UV is a killer to many untreated plastics. I have tried some of that I-beam like formed PVC that model railroaders use and had it fail and under load on the water....not fun.
If you don't want to spend the time making them, At about 40 cents each, Midwest Model Yachting sells them with three different size holes for different size line and in stainless steel. http://www.midwestmodelyachting.com/RunningRigging.asp
I usually get the Pekabe version off eBay (toyboat00 is the seller - sister of the guy that runs Worth Marine), but they are out of them right now. The Midwest version are cheaper anyway.
Midwest also sells the SAILSetc gooseneck/vang for 1 meter size boats with round masts.http://www.midwestmodelyachting.com/Goosenecks.asp I have one on a US1M and it is a very professionally made fitting.
On my 1m racing version of the T37, I will probably make one from CF disks and various RC airplane parts - see picture below.
A nice looking hull deserves quality fittings.
FC
FoamCrusher is offline Find More Posts by FoamCrusher
Old Nov 21, 2012, 01:59 AM
Hot Tuna is offline
Hot Tuna's Avatar
Joined Jan 2012
Sail arm and attach point up under the aft starboard corner
Old Nov 21, 2012, 03:26 AM
Hot Tuna is offline
Hot Tuna's Avatar
Joined Jan 2012
There are lots of ways to do this but these are my current rig
Jib
Old Jan 21, 2013, 08:57 PM
Hot Tuna is offline
Hot Tuna's Avatar
Joined Jan 2012
Here are a few pictures going back to the beginning. I glued stop blocks inside the hull instead of pushing pins through the sides. Make sure to leave a little extra space so the sides end up proud of the deck and the bottom. If the sides end up below the surface of the deck, you will end up sanding through the veneer to make the deck flush.
Old Jan 22, 2013, 11:38 AM
Elk Grove, CA
Joined Sep 2002
Could someone weigh their boat and give me the AUW (all up weight - that is ready to put in the water)?
Thanks.
FC
Discussion Tippecanoe T37 suirendoujin Sailboats 12 Oct 04, 2015 12:54 PM
Mini-HowTo T37 building tips Bob DeMassi Sailboats 1 Jan 14, 2009 08:33 PM
Discussion Tippecanoe T37 video jpatters Sailboats 7 Oct 31, 2007 12:03 PM
T37 Vs Soling 1m budd Sailboats 1 May 29, 2004 06:16 PM
