Old Nov 05, 2012, 10:18 PM
Joe Malinchak is offline
Find More Posts by Joe Malinchak
Carbondale PA
Joined Aug 2005
1/72 scale A-10.
I started thinking about the design for my new 1/72 scale A-10 after last years JR indoor event. http://www.jriefestival.com/ The 3 channel model has a scale outline, and weighs 10 grams RTF with a 30 LiPo cell. It has a 9.4 inch wingspan, and was designed around Kevon Ritter's (bimRC Ducted Fan Line) 18mm fan unit. The model uses two 6mm motors from the Ares Nano Micro stick RTF plane. http://www.ares-rc.com/nanomicrostick75.html I did a review of the model for my Micro Flying column in Model Aviation, and I noticed that the motor was putting out some good power. I then did some tests with the 18mm and 20mm fan units that Kevon designed. I found the the 18mm fans worked well with the motor and were very close in scale size for the A-10.
The plane is constructed out of Durobatics foam and balsa, and uses the DT Rx 42 receiver for guidance. The wonderful DT 2.4 GHz line of receivers put out good power to the actuators. I used 3 Plantraco NanoActs on this model. Two for the ailerons, and one for the elevator. I was not sure if they would have enough power to control this 10 gram plane, but they ended up working great.
I put in over 40 hours last week to try and complete the model in time for the JR event. Luckily, I was on vacation. I was really worried that the model would not have the power to fly as I was only getting 4.5 grams of static thrust with the nacelles built up. I had her RTF on Halloween, and I needed to test fly her before going to JR. The weather was really bad in Pa all week with hurricane Sandy, so I called a friend who's wife works in the YMCA in town, and asked if I could use the gym for 5 -10 minutes to put in a test flight. She said that I could so I went down to give her a try. Some kids were playing basketball and I had to wait until they took a break. Then I gave her a toss and to my surprise, the model flew beautifully on the first flight! The kids and I were amazed when when we saw her fly!
I had to add the rest of the little details after test flying the model. I added a new machine gun light set that Sergio Zigras made for me that he calls the Blinker. The light set weighs only 400 mgs with a flashing machine gun strobe, and the nav lights. I was running out of time so I just added the machine gun light! All of the details and the light set added 3/4 of a gram to the models overall weight. I was hoping that it would not have that much affect on the models performance.
I ended up putting in over 20 flights at the JR event, and the model ending up winning the ward for the Best Jet. I want to thank Kevon Ritter for his help with the fan units.
The model flies great but could use a little more power. I am thinking that two single phase brushless motors with Chris T's new controller would be the answer!
Joe.
1/72 scale micro R/C 3 channel A-10! (0 min 47 sec)
1/72 Scale 9.4 inch wingspan micro R/C A-10. (1 min 0 sec)
Joe Malinchak is offline Find More Posts by Joe Malinchak
Old Nov 06, 2012, 05:26 AM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Per usual,very very impressive Joe!
Always nice to see what you have up your sleeve....
Take care and keep em comin'.................Chris
Hover or die is offline Find More Posts by Hover or die
Old Nov 06, 2012, 05:31 AM
Joined Mar 2011
Joe,
Have you rolled her yet....?
I would think with the availible power that she would certainly do so...........
Also,absolutely loved the hand catches....great lookin' model!
Old Nov 06, 2012, 12:36 PM
Carbondale PA
Joined Aug 2005
I have not tried to roll her yet. I was playing it safe at JR. I will give it a try when I get some good weather!
I also forgot to mention that I used counter rotating fans in the model.
Joe.
Old Nov 06, 2012, 03:29 PM
AJWoods is online now
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Awesome, awesome work Joe.
-A
AJWoods is online now Find More Posts by AJWoods
Old Nov 06, 2012, 09:16 PM
Groovechampion is online now
Find More Posts by Groovechampion
Micro enthusiast
Groovechampion's Avatar
Australia, SA, Adelaide
Joined Aug 2011
Wow!! That is beautiful work Joe.
She looks fantastic, I was a fan of the MIG 15 you made when I saw that in action.
Id love to see more video of the A-10!
Regards,
Nath.
Groovechampion is online now Find More Posts by Groovechampion
Old Nov 06, 2012, 09:36 PM
Keith43221 is offline
Find More Posts by Keith43221
Got H2? Fuel Cell R/C Car
Keith43221's Avatar
United States, TX, Del Rio
Joined Mar 2004
Joe it was great meeting you this weekend! I am the younger guy that came around late Sunday and filmed the A-10 fly.
Great to see it posted!!
Keith43221 is offline Find More Posts by Keith43221
Old Nov 06, 2012, 10:50 PM
Carbondale PA
Joined Aug 2005
Hi Keith,
You did a great job with the video's! Thanks for the help.
Joe.
Old Nov 07, 2012, 12:30 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Good job Joe. Looks like you are using the BIM 3 blade rotors too with the 18mm shroud, is this correct? I've got a new order in to try out some of Kev's newer offerings and see what I can come up with.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Nov 07, 2012, 10:45 PM
Carbondale PA
Joined Aug 2005
Yes, I am using two of BIM 3 blade rotors with the 18mm shrouds. They seem to work the best with the 6mm motors.
Joe.
Old Nov 08, 2012, 01:50 AM
Ivan2280 is offline
Find More Posts by Ivan2280
ITALY
Joined Sep 2004
Hello Joe.How many ohm measure the 6mm motor from ares micro stick?Thanks
Ivan2280 is offline Find More Posts by Ivan2280
Old Nov 08, 2012, 11:46 AM
Carbondale PA
Joined Aug 2005
The Ares 6mm is a 4.5 ohm motor, and weighs only 1.1 grams. It is a short can motor with the same power or more than the longer can 4.5 ohm 6mm motor. http://www.ares-rc.com/nanomicrostick75.html
Joe.
Old Nov 08, 2012, 11:52 AM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
Wow, just wow!
kelberts is offline Find More Posts by kelberts
Old Nov 08, 2012, 03:48 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Very nice Joe.
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 16, 2012, 11:37 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
That's just plain sweet!
Joe 1320 is offline Find More Posts by Joe 1320
Wanted 1/10 or 1/8 scale revo tires need badly Conquest Cars - Trucks and Parts (FS/W) 2 Sep 13, 2014 01:25 PM
Discussion Home/ Electric RC On-Road/ 1/10 RC Electric On-Road/ HSP 1/10 Scale 2.4GHz RTR Brushl lancaster1945 Car Talk 1 Mar 24, 2013 01:47 PM
Discussion Scale Brass Propellers for Revell 1/72 Type VII C redboat219 Submarines 23 Jun 24, 2012 08:50 PM
Sold 1/5 Scale 72" Pica Waco YMF Model Airplane Kit LCS Aircraft - Fuel - Airplanes (FS/W) 2 May 15, 2012 09:16 PM
For Sale 1:72 scale Vosper Fast Patrol boat Perkasa nero1156 Boats (FS/W) 0 Mar 12, 2012 06:12 PM
