Old Nov 05, 2012, 03:05 PM
Mortimer's Avatar
Joined Apr 2010
T-Motor MT2814-10 770KV and 10 propellers - Efficiency test
Thanks to FPV Model to have made this test possible with his offer to provide four free motors to testers.
T-Motor MT2814-10 770KV 260W 25A motor working on 3S and 4S,
10 propellers: APC 10x4.7, 11x4.7, 12x3.8, 12x4.7 and 13x4.7, GemFan 10x4.5, 10x4.5 CF and 11x4.7, Graupner 10x5 and 11x5.
Test made with:
Turnigy Nano 3S 4000mAh 35-70C,
Hobbywing Pentium 30A, middle timing mode,
Turnigy Servo Tester and Micro Tacho, GWS Servo Tester MT-1,
Junsi PowerLog 6S Wattmeter - Soehnle scale - LogView software,
Friction free test bench, right angle 200mm arms.
Two levels:
- Mid throttle, 50%, usually used to hover
- WOT, 100%, maximum power and thrust
Turnigy Servo Tester offers mid throttle (1.5ms pulse width) and full throttle (2ms) positions.
Test results are below.
Best performing prop with this motor for hover is APC 12x3.8.
This combo seems perfectly suited to a 2kg quad, a 3kg hexa or a 4kg octo.
Pro: This motor is well made, balanced, silent and efficient. It should be durable.
Good efficiency means long running time.
Con: Somewhat heavy (135g with cables and prop adapter) and not cheap.
4S battery doesn't seem suitable, max power allowed being quickly exceeded.
To compare props' efficiency data with other motors, see my previous tests:
- Three motors tested: http://www.rcgroups.com/forums/showt...1388583&page=3
- Five motors tested: http://www.rcgroups.com/forums/showt...1388583&page=4
- Park480 and five propellers: http://www.rcgroups.com/forums/showthread.php?t=1557506
- DT700 and 24 propellers: http://www.rcgroups.com/forums/showthread.php?t=1594904
- Park450, Park480 and 10 propellers: http://www.rcgroups.com/forums/showt...388583&page=11
- DT750 and 7 propellers: http://www.rcgroups.com/forums/showthread.php?t=1708731
Mortimer is offline Find More Posts by Mortimer
Old Nov 05, 2012, 03:24 PM
fajar's Avatar
sydney, downunder
Joined Jan 2011
I always love this kind of thread. Thank you for posting the results here .
fajar is offline Find More Posts by fajar
Old Nov 05, 2012, 03:26 PM
Hawaii
Joined Feb 2003
Thanks for continual effort in testing. These are the good information that we can use.
Especially when your results validate what I find in real life use.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Nov 06, 2012, 12:13 AM
Joined Jul 2012
hi Mortimer:
can you assemble the motor and make flying test, thanks
fpvmodels is offline Find More Posts by fpvmodels
Site Sponsor
Old Nov 06, 2012, 02:21 AM
South Africa, GP, Johannesburg
Joined Sep 2010
I really like the way you have presented your tests.
Are you also testing the MT2814-11 and the MT2216-11?
robone is offline Find More Posts by robone
Old Nov 06, 2012, 03:04 AM
Joined Sep 2012
is mt2814 and axi 2814 the same thing?
WonderKing is offline Find More Posts by WonderKing
Old Nov 06, 2012, 04:02 AM
Russian Federation, MO, Podolsk
Joined Dec 2010
^ +1..i vote for MT4006
rinatka7 is online now Find More Posts by rinatka7
Old Mar 03, 2013, 10:55 AM
Joined Mar 2012
hexacopter I want to do will weigh about 2500 g.
I take the recommended mt2216 or mt2814??
radial, from motor to motor 650mm
cronalex is offline Find More Posts by cronalex
Old Mar 03, 2013, 02:40 PM
EddieWeeks's Avatar
Baton Rouge, LA, USA
Joined Dec 2001
EddieWeeks is offline Find More Posts by EddieWeeks
Old Mar 03, 2013, 04:41 PM
Mortimer's Avatar
Joined Apr 2010
MT2216 should be suitable: http://www.flybrushless.com/motor/view/616
cronalex is looking for combos giving 420g thrust (2500g/6) or more at 50% throttle for his hexa.
Efficiency graphs of 4006 and 4822 are nice but don't seem to be the answer he is waiting for.
Old Mar 04, 2013, 04:57 AM
Joined Mar 2012
ultimately what do you advise me to take mt2814 or mt2216. with a weight of 3000kg(hexa +gimbalgopro
Old Mar 04, 2013, 05:02 AM
Joined Mar 2012
I forgot 4s battery propellers from 10 or 11 engines which do you recommend.
I would like to put two batteries in parallel 4s
Old Mar 04, 2013, 08:09 AM
Mortimer's Avatar
Joined Apr 2010
2500 or 3000g, MT2814 or MT2216, 10 or 11 turns, 3S or 4S, and after which props?
Play with eCalc, it will help you to make up your mind.
Hover throttle must be between 45 and 50%.
Battery capacity has a direct influence on flight time.
http://www.ecalc.ch/xcoptercalc_e.asp
Example:
Old Mar 04, 2013, 12:07 PM
Joined Mar 2012
throttle linear 30% is too low? either is fine ... for now my exa weighs 2500g
Old Apr 29, 2013, 12:09 AM
Joined Oct 2012
Hello I am suffering here with my multi-rotor initially my setup was a octocopter with MT 2814-10 770 kv + 4S 5000mAh 20-30c + + ESCs hobbywings flyfun 30A controller WK-M. All was seemingly well until a bug in the controller and had several falls from inesplicáveis ​​.. Now after losing an engine, built a hexacopter with what's left. I need to carry a Canon 5D Mark II, but not consifo fly more than 1.5 minutes and the hexa down alone .... evo give this my setup? Could you help me?
thanks , and sorry for my english precarious ...
AeroCine is offline Find More Posts by AeroCine
Data DT750 and 7 propellers - Efficiency test Mortimer Multirotor Talk 5 Mar 26, 2013 10:57 AM
Sold Tiger Motors mt2814-10 770kv pmp80 Aircraft - Electric - Multirotor (FS/W) 4 Oct 20, 2012 07:57 AM
Sold NEW PRICE ! ONLY 4 LEFT Mt2814-10 770kv pmp80 Aircraft - Electric - Multirotor (FS/W) 2 Oct 04, 2012 08:47 AM
Question Tiger Motor MT2814 770kv squigg Multirotor Talk 0 May 08, 2012 08:51 AM
Sold NEW 9 x MT2814 770KV motors tdmaros Aircraft - Electric - Multirotor (FS/W) 2 Dec 16, 2011 04:41 AM
