Old Nov 05, 2012, 12:55 PM
Forced_Inducti is offline
Find More Posts by Forced_Inducti
Joined Dec 2008
2m vs 3m decisions decisions
Hello all.
I recently posted a short thread on comparing the chrysalis and the spectra/spirit. I like the ability with both to use the same wing, and switch between electric and pure glider.
I was talking to a guy at my club this weekend, and he threw another option into the mix. He recommended the bird of time and converting itto electric.
Wouldn't have any problems with the build, and this option is really starting to appeal to me. I like also the full flying tail on the bot. It seems that the kit benefits from swapping out some of the wood as it seems very heavy. Just an observation from other build threads.
Any opinions?
Forced_Inducti is offline Find More Posts by Forced_Inducti
Old Nov 05, 2012, 02:34 PM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
3m usually flies better then 2m.
If you are looking at the BOT, there are other options verses the dynocrunch ironwood replacement process.
Some old Marks Models BOT kits come up now n then for around $125.00.
Or you can by plans and scratch build.
Also, almost any plane can have it's fixed stab converted to full flying.
Just thoughts to consider.
Jared
jcstalls is offline Find More Posts by jcstalls
Old Nov 05, 2012, 03:07 PM
Joined Dec 2008
dynocrunch ironwood?
Old Nov 05, 2012, 04:46 PM
Don Stackhouse is offline
Find More Posts by Don Stackhouse
Don Stackhouse's Avatar
United States, OH, Bradford
Joined Jun 2005
The wood quality and "die crushing" quality on those kits is reported by many to be disappointing.
Be careful about switching to an all-flying tail. Since the primary structure is now a moving part, the structure tends to be heavier, and more difficult to make slop-free than a 2-element tail.
The so-called "trim drag" of a slightly deflected elevator is not that much different from that of an all-flying stabilator set to make the same amount of tail lift.
If the size of the tail is dictated by control authority requirements, an all-flying tail needs to be bigger than the equivalent stabilizer+elevator. When you deflect a stabilator, all you change is its angle of attack. When you deflect an elevator, you change the tail's angle of attack AND its camber, so it can make the same tail force from a smaller area.
Don Stackhouse is offline Find More Posts by Don Stackhouse
Old Nov 05, 2012, 06:51 PM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
I guess I always assumed the opposite all these years. Your explanation is much appreciated. Iím going to be thinking about this for a while.
Piper J3
Piper J3 is offline Find More Posts by Piper J3
Old Nov 05, 2012, 08:32 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
2M tends to be more maneuverable. 3M tends to have more performance, as the Reynolds numbers are better, although you can trade in some of the Reynolds number advantage to get a higher aspect ratio.
If you're thinking of this larger size, there are lots of other models to consider, depending on what you're going after. For instance, there are several versions and sizes of the Olympic from Skybench, as well as a series of gliders similar to the BOT, though I forget the exact names. And the 3 meter Scooter. And the Paragon....
Then there's the Mirage from Isthmus models, the Scepter 100 (100 inch, ie. a bit more than 2.5 meters) from Mountain Models, the Marauder and the Oculus from MM Glider Tech, and on and on.
I suspect the most fun for the least effort would be the Chrysalis, but I don't know that. And it depends on what you like.
lincoln is offline Find More Posts by lincoln
Old Nov 05, 2012, 08:50 PM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
I thought this post would be appropriate here as it is from a World Champion and something I had never thought of before, it was thinking out of the box.
http://www.rcgroups.com/forums/showp...9&postcount=15
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Nov 08, 2012, 11:23 PM
Joined Dec 2008
I have come across the skybench aerotech big bird. has the same cool looking wing as the BOT, but more modern by the looks of it. it might be in the future, but atm, ive decided on an electric chrysalis. I am looking forward to being able to compare the difference between a 2m and a 3m bird in the future, but for now it will be a 2m.
itll also be easier to build, transport, and store the wing in 1 piece being only 2m long =P
Old Nov 09, 2012, 07:02 AM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Friends don't let friends fly Two Meters ...
tkallev is offline Find More Posts by tkallev
Old Nov 11, 2012, 12:50 AM
Joined Dec 2008
whats wrong with 2 meters?
Old Nov 11, 2012, 01:02 AM
jswain is offline
Find More Posts by jswain
Gasbags & Gussets
jswain's Avatar
Riverside, Ca
Joined Feb 2009
2m vs 3m
Nothing is really wrong - just some leg pulling.
That said see post #2 above, first line.
3m will thermal easier,faster,blah,blah compared to a 2m most of the time flying in the same circumstances.
Even the difference between 2.5m vs. 2m is noticable.
As so many advertisements say, size matters
Just make the best choice you can and enjoy what you got, there is always another model lurking in your future
js
jswain is offline Find More Posts by jswain
Old Nov 11, 2012, 01:08 AM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
2 meter planes are the best ever...until you've tried sumpin bigger.
You can get a 100" (or bigger) higher and still see it well. This allows hunting at an altitude where the thermals are (sometimes) stronger. Also, up to the point where you have to buy better servos etc, the gear for a 2 meter can go into the bigger plane. This allows for possible lower wing loading. Then there is the "mines bigger than yours " factor. ;-)
ozmo01 is offline Find More Posts by ozmo01
Old Nov 11, 2012, 10:32 AM
Joined Jun 2005
Except that the Chrysalis 2-meter has a bigger chord than many open class ships. Chord is more important than span when it comes to visibility.
We can make an excellent-performing sailplane with a high aspect ratio and higher-lift airfoil (such as our Spectre series), or from a low aspect ratio and a "racing" airfoil.
In the case of the Chrysalis series, beginners (and others) often need some help in the visibility department, so we used that second approach.
Old Nov 11, 2012, 06:16 PM
GliderJim is online now
Find More Posts by GliderJim
GliderJim's Avatar
Michigan, USA
Joined Jul 2006
I've got a whole gaggle of 2 meter planes. I like 'em!
GliderJim is online now Find More Posts by GliderJim
Old Nov 11, 2012, 07:15 PM
Joined Dec 2008
I figured it was just a bit of ribbing =). I have placed an order for a Chrysalis 2m electric. Its getting shipped to canada, and technically its my fiances christmas gift to me, so shes not letting me open it until christmas. so i wont get started on it until the new year, but Im looking forward to building it very much. as far as servos, my plan was to use hitec 5065MGs. im assembling an arf for a buddy and he wanted them, i have to say, they center EXTREMELY well in my opinion. i think those might be on the small side for a 3m tho.
Sold 2m 3m Art Hobby local pickup only onefield Aircraft - Sailplanes (FS/W) 19 Jul 08, 2012 07:31 AM
Question Need a little help picking a 2m - 3m floaty thermal glider muchalucha Thermal 37 Apr 28, 2012 02:38 PM
2M vs. Standard vs. 3m etc johnsocj Sailplane Talk 12 Aug 03, 2004 02:32 AM
Gnome 3m vs Scooter 3m vs Sagitta 900 Superman Thermal 3 May 05, 2003 11:47 AM
