Old Nov 05, 2012, 09:05 AM
diydave is offline
Find More Posts by diydave
UK
Joined Oct 2009
premier kites motor choice
Hi hoping someone can recomend an alternative to the stock motor on the premier gen 2 unite I want to use it on a premier delta box orange rush as a 2d unit or does anyone know the kv or size of the standard motor any help would be much appreciated thanks Dave
diydave is offline Find More Posts by diydave
Old Nov 05, 2012, 12:25 PM
flattermann is offline
Find More Posts by flattermann
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
Hi diydave,
the original motor has around 1800 kv, weighs 25grs.
A motor of the double weight with 1600 - 1700kv should work as an alternative.
flattermann is offline Find More Posts by flattermann
Old Nov 06, 2012, 02:37 AM
diydave is offline
UK
Joined Oct 2009
Hi Flattermann thanks for the reply I will check those out do you also have a recomendation for the size of prop,hopefully when I get all my bits I will attempt to do some sort of build log for the 2d unit thanks Dave
Old Nov 06, 2012, 08:22 AM
harrisdouma is online now
Find More Posts by harrisdouma
Beaver Dam.Wi.
Joined Jan 2003
Hi Diydave
I have the 9 ft. premier rc eagle that uses thePremier gen. 2 power unit.
In this gen 2 power unit I now have a micro dan 2510 970kv brushless moter
this moter was a drop in fit. and has more power . I use a 10X6 gws prop
The micro dan 2510 1300 would also be a good choice and uses a 8X4 prop
Both moters are drop in fit. and available at www.gobrushless.com
hope this is helpful
harrisdouma is online now Find More Posts by harrisdouma
Old Nov 07, 2012, 02:50 AM
diydave is offline
UK
Joined Oct 2009
motors
Hi flattermann just to verify when you mention adout the weight do you mean I can use a motor upto about 50 grams in weight ,being looking so many to choose from please could any one give me some idea about the dimensions of the standard motor is it about 25 mm wide,
Hi Harrisdouma thanks for the reply had a look at your link ,but was hoping to get my motor from some where in the uk as I dont want to prolong this buid any longer with postage times, thanks to all the people who are helping this project along Dave.
Old Nov 07, 2012, 01:16 PM
Germany
Joined Dec 2006
Hi Dave,
A motor of the double weight (around 50 grs.) with 1600 - 1700kv should work as an alternative, prop could be a GWS 8040 (like the original premierrc). When using a 3S LiPo, thrust could be as well around +- 800grs.
flattermann
Discussion Premier rc kite suppliers diydave RC Paragliders and Kites 2 Nov 01, 2012 04:02 AM
Sold New RC Premier Eagle kite RTF thunderbyte Aircraft - General - Miscellaneous (FS/W) 1 Oct 26, 2012 02:31 PM
New Product R/C Vector kites by Premier Designs STRINGFLY Parkflyers 16 Feb 01, 2011 07:47 AM
Discussion Premier RC Kites flimnar Parkflyers 7 Feb 01, 2011 07:02 AM
Discussion Premier RC powered kites ghoti Aerial Photography 2 Nov 19, 2010 02:56 PM
