Old Nov 05, 2012, 03:01 AM
DaveTheKiwi is offline
Find More Posts by DaveTheKiwi
New Zealand, Wellington, Lower Hutt
Joined Sep 2011
Help!
Quick q: how do you cut carbon strips?
Any tips? If I had a bandsaw, I'd use that, but alas I do not.
Hacksaw? Knife?
Tips for a clean cut?
Thanks.
DaveTheKiwi is offline Find More Posts by DaveTheKiwi
Old Nov 05, 2012, 06:10 AM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
Definitely not a knife, you will split the fibers. Best thing is a cutoff wheel on a dremel or a razor saw. Standard hacksaw blades are often to rough.
As always, wear a proper mask. Carbon dust is worse then almost any other type of dust. So play safe.
SB7 is offline Find More Posts by SB7
Old Nov 05, 2012, 06:26 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Wrap the cut area in masking tape,makes a cleaner cut.Razor saw cuts well,doesn't raise as much dust.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Nov 06, 2012, 07:46 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Stuart
Yep; this is what I do. Works really well.
rcav8r2 is offline Find More Posts by rcav8r2
Old Nov 06, 2012, 01:25 PM
Joined Sep 2011
So doesn't seem to be a good way with hand tools?
Old Nov 06, 2012, 01:27 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
See posts 3 & 4.
Old Nov 06, 2012, 01:50 PM
Dean Church is online now
Find More Posts by Dean Church
United States, CA, Rio Vista
Joined Feb 2012
On carbon fiber strips I had good luck with wire cutters, but I use a cut off wheel for tubes and solid rods.
Dean Church is online now Find More Posts by Dean Church
Old Nov 06, 2012, 01:56 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
All you need.Personally I avoid power tools with carbon.
Stuart
Old Nov 06, 2012, 02:51 PM
Joined Sep 2011
Sorry thought a razor saw was a powered one
Thanks all.
Old Nov 10, 2012, 11:54 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Razor saw over a wet paper towel to catch the dust. Nasty stuff, not to be trifled with.
Carbon tube can be cut neatly using a tubing cutter, which doesn't make anything like as much dust.
leccyflyer is offline Find More Posts by leccyflyer
Old Nov 10, 2012, 12:14 PM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
This may interest you:
http://www.rcgroups.com/forums/showt...3#post10986133
I use a Master Airscrew Balsa Stripper as some unidirectional carbon fiber isn't really perfectly unidirectional. So if you start to strip a piece and pull full length as in the link above it'll change width.
http://masterairscrew.com/balsastripper.aspx
So I run this stripper once or twice down the carbon fiber, then carefully pull it apart and take a pair of scissors and cut the strands that weren't unidirectional.
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Nov 11, 2012, 06:07 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I tried a bandsaw with a metal cutting blade. It rounded off the teeth in a matter of seconds making the blade useless. Much like a grinder on the teeth. I use a mini hacksaw.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Discussion how do you cut and glue sintra? BOZINATOR Scale Boats 28 Nov 16, 2012 01:46 PM
Discussion How do you cap a rib with a carbon fiber strip? How much strength does it add? Accu157 Thermal 93 May 07, 2011 11:27 AM
Discussion How do you use carbon fiber strips to reinforce a wing?! Smokescreen38 Parkflyers 15 Feb 23, 2007 01:51 PM
how do you cut carbon rods? robw Micro Helis 15 Dec 30, 2002 10:13 AM
How do you cut carbon fiber rod? JamesD Beginner Training Area (Aircraft-Electric) 6 Oct 17, 2001 10:15 AM
