Old Nov 04, 2012, 09:21 PM
taildragger1589 is online now
Find More Posts by taildragger1589
Lookin' up at the centerline
taildragger1589's Avatar
United States, GA, Lawrenceville
Joined Feb 2005
Return of The Scorpion powered Sig 1/4 Cub
Hi Gents!
I've been flying a Sig Clipped wing quarter scale Cub since the maiden in March of '09 with a Scorpion 4020-16 swinging a 15/8 prop.
I've got two 5000 mah, six cell lipos and a 100 amp scorpion esc.
I've got a question for any experts on big heavy motors...
The motor, as shown in the vid below, will swing the 15/8 light prop easily and does fine on the aborted landing test of going from full to idle the suddenly back to full throttle.
The second prop in the vid is a heavy 16/8 that runs just a well as the 15 and pulls an extra pound of thrust for only 2 more amps.
But!
After going to full idle, then suddenly back to full throttle, it squeals like a wounded pig and does not pick back up.
The ESC is set to auto select. Would manually setting it to a low setting like 5 degrees make a difference in acceleration, maybe setting it to a slow spool up like for a chopper?
Thanks for any advice.
Nick
Scopion prop test (1 min 14 sec)
taildragger1589 is online now Find More Posts by taildragger1589
Old Nov 04, 2012, 11:17 PM
Doug Bartley is online now
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Most of the Scorpions if not all run better on mid timing for me, which is somewhere around 12-16 degrees. It may need even more depending on how heavy the new prop is.
Make sure your esc is set on 8mhz frequency too as all Scorp's I've used are designed for it.
It the extra weight in the prop that causes this, quite common really, the motor has no problem spinning up the lighter prop, but loses sync trying to spin up a heavier one.
All the 40 series Scorps I've run have required med or high timing to prevent the stutter/ squealing, the setting is dependant on the prop size. I've run 4020-12, 4020-14, 4020-16 and 4025-12's to date. Doug B
Doug Bartley is online now Find More Posts by Doug Bartley
Old Nov 05, 2012, 10:41 AM
Joined Feb 2005
Thanks for the info!
I was completely backwards, I thought that the timing was like the distributor timing on a car.
Heavy prop squeal has had me baffled for a while.
Hopefully will be able to test your numbers soon.
Nick
Old Nov 05, 2012, 04:58 PM
Joined Oct 2008
Hi taildragger: The 4020-16's I've tested all required med timing, I have tested up to a 16/12/ 3blade Graupner 18/10 Apc e without issue (72a). I have two in my 14 lb 84" Buffalo on 12/8/ 3 blades, only 50a per motor.
You should also use normal or hard start, these motors like a good shunt of power to get them spinning and will not respond well to slow starts, esp with bigger props. fwiw Doug B
Old Nov 05, 2012, 06:19 PM
Joined Feb 2005
Ha!
I had the start up backwards too.
I tell ya, if fuel wasn't so expensive (and messy) I'd dig out my old OS 120 FS, (the first of the series) and put on a 16/6 MAS.
Plenty of power.
But then again, it sure is nice not having to wipe off the goo at the end of the day.
Can't even quote noise difference, since it sounds almost the same.
Can't wait to try the mods, had too many house chores today.
re buffalo: Wow! at 14lbs. she must really move out. My Cub is 13 lbs and though she only has about 30 feet of vertical from straight and level, she has a nice comfortable climb rate with only one pulling 45 amps (47 with the big prop) (search quartercub on youtube to see her fly.)
Nick
Old Nov 12, 2012, 12:12 PM
Joined Feb 2005
SUCCESS!!!
Thanks a bunch Doug.
turns out that 15 degrees made the big prop behave as well as the smaller.
Now all I need is calm day above sixty and we're airborne.
Nick
Wanted Sig 1/4 Cub for Sig 1/5 Cub Trade NIB only Ice Aircraft - Fuel - Airplanes (FS/W) 0 Sep 05, 2012 05:29 PM
Sold 1/4 scale Sig L-4 cub Bismarck007 Aircraft - Fuel - Airplanes (FS/W) 6 Aug 24, 2012 07:33 AM
Help! 1/4 sig clipped wing cub mercurypro Glow to Electric Conversions 2 Mar 25, 2012 10:21 PM
For Sale Sig 1/4 scale Piper Cub ARC with floats nero1156 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 26, 2012 04:28 PM
Discussion Sig 1/4 Scale Cub - Saito Powered - Video finally done! HelloScott Giant Scale Airplanes 3 Nov 03, 2009 08:20 AM
