Old Nov 26, 2012, 02:40 PM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Originally Posted by earlwb View Post
Well the classic air leak problem is usually through the carburettor somehow...
Earl,
More often an air-leak results from excessive clearance between the crankshaft journal; and the front of the crankcase in which it spins (whether through the bearing, or the bronze bushing).
Some people who encounter this condition within a ball-bearing engine, try to blame the front bearing's seal for the leak... This is nonsensical, since some engines use open front bearings that have no such seal (Webra and Fox, to name a couple).
The seal is actually formed between the crankshaft journal; and the front of the crankcase in which it spins, aided by fuel-borne oil; and it is this seal which prevents air from leaking into the the (average) vacuum within the crankcase.
Excessive clearance can result from wear, or from mediocre production quality.
A contact-sealed bearing (2RS or similar) can reduce the leak somewhat; possible making throttle shutdown doable.
DarZeelon is offline Find More Posts by DarZeelon
Old Dec 17, 2012, 01:53 PM
hsukaria is offline
Find More Posts by hsukaria
United States, MI, Dearborn
Joined Jan 2010
I had a similar problem with my Irvine 40 a couple of years ago. What caused it was that I had replaced the o-ring seal at the base of the carb with a thicker o-ring. It did not seal well. I went back to the original-sized o-ring and pushed down the carb hard onto the crankcase while tightening the carb hold-down bolt. That solved the problem for my engine.
hsukaria is offline Find More Posts by hsukaria
Old Dec 17, 2012, 11:17 PM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
The front end of a two cycle glow engine is sealed by the crankshaft to crankcase fit. Nothing else. Most engines just use a metal shield that keeps crap out of the bearing or a rubber seal that doesn't seal against pressure. All that rubber seal does is keep grease in the bearing.Many engines actually have no seal or shield on the front bearing. Super Tigre is one of them.
datsunguy is offline Find More Posts by datsunguy
Old Dec 18, 2012, 01:25 AM
DarZeelon's Avatar
Joined Nov 2003
Actually, DatsunGuy, the seal is between the crankshaft and the crankcase, behind the carburettor.
That 'leak' from the carburettor socket forward can feed oil to the front bearing, but if a double sealed bearing is used it is not really necessary.
If the seal between the crankshaft and the crankcase behind the carburettor, is good (i.e. quality parts machining); no excessive discharge of oil will happen ('runny nose' syndrome).
Old Dec 18, 2012, 06:25 AM
Cougar429 is online now
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
We all seem to be circling the same issue, what I posted originally as a bad fit between the crank and case, caused by low QC or bad or worn bearings. It all comes back to air and fuel getting into the main case through the nose. With some engines the ONLY solution is sealing the front bearing as you cannot likely refit the crank to bore.
The horse is dead!
Cougar429 is online now Find More Posts by Cougar429
Old Dec 18, 2012, 06:27 AM
DarZeelon's Avatar
Joined Nov 2003
The horse is dead!
I would never disagree with that, Cougar.
Discussion my speed controller keeps shutting off flyingryanfpv Multirotor Talk 1 May 20, 2012 02:41 AM
Discussion Blade MCX2 barely lifts and wont shut off Bladecpnitro Coaxial Helicopters 3 Feb 14, 2012 09:43 AM
Help! Engine shuts off after 5 min HELP!!! mr.Q Off-road Cars 6 Nov 07, 2007 07:40 PM
Discussion MSL Left side motor wont shut off moody07747 Micro Ready-to-Fly 4 Sep 18, 2007 10:59 AM
Discussion Engine wont shut off xray328 Fuel Plane Talk 1 Mar 23, 2006 06:45 PM
