Nov 17, 2012, 10:48 PM
Canada, ON, Windsor
Joined Apr 2008
Only thing left is what I described about the oil return passage behind the front bearing. Don't forget that to run a 2-stroke motor must get fuel AND air into the crankcase, to then be fed through the porting to the combustion chamber. If you sealed the rear cover and carb effectively there really is no other location for it to enter.
On that note, if there is play in the bearings, especially the front which on the GMS and TT clones were smaller than most other motors I've seen in that class, any eccentricity translates to wear in the casting bore, (and perhaps scoring of the crank itself, visible when you rotate the crank and look through the carb throat) and a corresponding increase in any air leak. Unfortunately that is one that is not curable, but a sealed rather than shielded front bearing is about the only option at that point. Before the bearing is installed remove the inboard seal with a straight pin or other sharp pointy tool to allow some lube to get at the rollers.
Having said all that there is one location that is not common, but can still create some problems. A loose fit between the carb housing and barrel can allow some air to leak through from the throttle arm side and draw in fuel along the way.
