Old Dec 23, 2012, 10:41 AM
Steve85 is online now
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
very nice indeed. I especially like the adjustable motor thrust; filed away for future reference!
Steve
Steve85 is online now Find More Posts by Steve85
Old Dec 24, 2012, 09:15 AM
conrad907 is offline
Find More Posts by conrad907
conrad907's Avatar
China, Guangdong, Shenzhen
Joined Feb 2012
This Spit should fly very well with that weight! I am a big fan of tissue covering, are you going to dope it? I have some of the new water based tissue adhesive and finish, but have never tried it, my experience with tissue always involved the classic dope approach, love the smell of that stuff!
conrad907 is offline Find More Posts by conrad907
Old Dec 25, 2012, 08:03 AM
gupi is offline
Find More Posts by gupi
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Sure, classic dope. With the smell and all!
gupi is offline Find More Posts by gupi
Old Dec 31, 2012, 01:35 AM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
I decided to use magnets for wing attachment since that proved pretty useful in my Herr Bonanza conversion. It holds the wing quite firmly.
Then i built the wing fairings that are so typical for the Spitfire. It proved a bit more difficult than i thought. It would have been much easier if the wing wasn't removable. I think it'll look alright in the air.
Old Dec 31, 2012, 03:19 AM
RMCCOR7737 is offline
Find More Posts by RMCCOR7737
Heads up...
RMCCOR7737's Avatar
United States, VA, Stafford
Joined Jun 2009
The method I used on my Guillows P-51 was to attach the wing separated by wax paper and build as if the wings were attached. Your Spits looking very nice though.
RMCCOR7737 is offline Find More Posts by RMCCOR7737
Old Dec 31, 2012, 06:38 AM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Actually i thought about that - but after I glued the first balsa parts to the fuselage. Let's see how it turns out after covering.
Old Jan 07, 2013, 11:50 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
I've got the tail feathers hinged and covered. I used only small strips of CA hinge to keep the forces needed to move the control surfaces low.
After some thinking about the best way to color this bird i decided to cover in white tissue first and later use rattle can Tamiya colors to color her.
Old Jan 08, 2013, 07:02 AM
glewis is online now
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Looking good!
A suggestion, fill the area where the vertical fin attaches to the fuselage from the keel down to the next stringer with balsa, then sand to shape. It will give the tissue something to adhere to in that area. I usually fill the entire area from the vertical to horizontal stabilizers to get a nice smooth surface because covering never seems to go on smooth in that little wedge shaped area due to the compound curves.
Glenn
glewis is online now Find More Posts by glewis
Old Jan 08, 2013, 11:40 AM
conrad907's Avatar
Joined Feb 2012
Somethings never go out of style, like well executed tissue covering. Great choice Gupi.
Old Jan 08, 2013, 06:35 PM
Heads up...
RMCCOR7737's Avatar
Joined Jun 2009
Looking good. I really need to get back into tissue. I just love the way it looks when completed.
Old Jan 09, 2013, 08:51 AM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
Tissue and dope... and your Spit... beauty!
ARUP is offline Find More Posts by ARUP
Old Jan 14, 2013, 12:21 AM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
I covered the fuselage. I took my time and used at least two parts of tissue for each bay - one port side and one starboard side. It turned out very nicely i think.
Old Jan 14, 2013, 06:08 AM
Sopwith Mike is offline
Find More Posts by Sopwith Mike
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
Beautifully done gupi - makes me rather sad about the litespan on my TA152!
Sopwith Mike is offline Find More Posts by Sopwith Mike
Old Jan 14, 2013, 11:58 PM
gupi is offline
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Thanks guys!
Glenn: actually I tend to avoid sanding where I can because I hate it. So I tried to get away with the kits original wood. It worked better than expected I think.
Old Jan 16, 2013, 06:11 AM
rtcina is offline
Find More Posts by rtcina
Austria, Vienna
Joined Jan 2013
I've moved to Vienna and your build has inspired me to build the same plane. Your pictures are such a help. Can you tell me where I can buy this model in Vienna and also, where can you fly it?
rtcina is offline Find More Posts by rtcina
Build Log BBCC 3 Guillow's B-29 Superfortress Conversion Smokin' Beaver Smokin' Beaver Scale Kit/Scratch Built 189 Apr 04, 2014 06:06 PM
Build Log #9 West wings Topaz Free Flight to RC Flight Kitbash Contest >>3DDFHobbies<< Keenan smith Balsa Builders 5 Feb 13, 2013 01:26 AM
Contest Free Flight to RC Flight Kitbash Contest >> Starts 17 Nov Murocflyer Balsa Builders 153 Dec 06, 2012 08:49 AM
Build Log #2 Free Flight to RC Flight Kitbash Contest >> AndyKunz << AndyKunz Balsa Builders 0 Oct 24, 2012 11:17 AM
