Old Nov 11, 2012, 01:10 AM
gupi is online now
Find More Posts by gupi
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Steve,
I plan to use a 2s 600mAh battery which will probably add 38 grams. Let's see if i can make it without additional weight (but it sounds like that will be difficult).
Yours, gupi
gupi is online now Find More Posts by gupi
Old Nov 11, 2012, 08:24 AM
davidterrell80 is offline
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
Though I think it may be a Hurricane, I thought you might enjoy this.
David
davidterrell80 is offline Find More Posts by davidterrell80
Latest blog entry: General Aircraft Skyfarer
Old Nov 11, 2012, 11:32 PM
gupi is online now
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
David
Thanks! Yes i think it's not a Spitfire.
Old Nov 11, 2012, 11:50 PM
gupi is online now
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
More work on the fuselage: i started with slimming down the keels and formers with my mini-tool. After that the fuse got down to 8 grams (from 14 grams). Nice!
I added some of the L pieces and first stringers, too.
Old Nov 12, 2012, 02:45 AM
gjap is offline
Find More Posts by gjap
Joined Jun 2010
Nice work, I have an old guillows stearman all framed up Ive been thinking about making it rc. Do you know what are you going to cover it with?
gjap is offline Find More Posts by gjap
Old Nov 12, 2012, 04:06 AM
gupi is online now
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
I'll use classic tissue and dope. I've not decided yet how i will color it though.
Old Nov 12, 2012, 06:14 AM
glewis is offline
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Nice work! You really removed a lot of unnecessary weight. One suggestion, add a 1/16 Strip across the formers. This will give it some crush resistance when you handle the model.
Glenn
glewis is offline Find More Posts by glewis
Old Nov 12, 2012, 11:46 PM
gupi is online now
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
I've slimmed down the tail surfaces to 4 grams (loosing 1 gram).
Old Nov 14, 2012, 08:11 AM
Spitfire1954 is offline
Find More Posts by Spitfire1954
Spitfire1954's Avatar
United Kingdom, England, East Riding of Yorkshire
Joined Jan 2011
Hi Gupi – your electrics are virtually the same as mine, so hopefully we are thinking along the right lines – great work so far!
Best
Charles
Spitfire1954 is offline Find More Posts by Spitfire1954
Old Nov 14, 2012, 09:23 AM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
I'm afraid you're going to have a lot of trouble where you've weakened the tail feathers by making all those cross-grain "pillars" where the ribs meet the frames. Had you lightened it before assembly, the ribs could have had 100% of the grain running the long way.
loNslo is offline Find More Posts by loNslo
Old Nov 14, 2012, 09:32 AM
Balsabird is online now
Find More Posts by Balsabird
Balsadustus Producerus
Escondido, CA USA
Joined Jan 2001
A quick soaking with thin CA glue would fix that
Balsabird is online now Find More Posts by Balsabird
Old Nov 14, 2012, 11:16 AM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Thus negating all the weight saved by the slimming down process.
I would think laminated outlines would be the lightest and strongest solution.
Glenn
Old Nov 14, 2012, 12:33 PM
loNslo is offline
wood is good
loNslo's Avatar
Joined Jun 2012
Originally Posted by balsabird View Post
a quick soaking with thin ca glue would fix that
Ha!
Old Nov 14, 2012, 01:24 PM
gupi is online now
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Guys, i think you're right. And yes, laminating the outlines would be best.
Nevertheless i'm a bit lazy so i might just take what i've got now and see how it works out. In my experience the covering adds enough stability even if the grain runs suboptimal in planes this small. I wouldn't trust it in larger planes.
I'll think about it a bit more.
Old Nov 20, 2012, 12:17 AM
conrad907 is offline
Find More Posts by conrad907
conrad907's Avatar
China, Guangdong, Shenzhen
Joined Feb 2012
gupi,
You have a nice touch with the grinder, maybe you were a dentist in a previous life! I have one of these kits collecting dust, got me thinking about it now.
conrad
conrad907 is offline Find More Posts by conrad907
Build Log BBCC 3 Guillow's B-29 Superfortress Conversion Smokin' Beaver Smokin' Beaver Scale Kit/Scratch Built 189 Apr 04, 2014 06:06 PM
Build Log #9 West wings Topaz Free Flight to RC Flight Kitbash Contest >>3DDFHobbies<< Keenan smith Balsa Builders 5 Feb 13, 2013 01:26 AM
Contest Free Flight to RC Flight Kitbash Contest >> Starts 17 Nov Murocflyer Balsa Builders 153 Dec 06, 2012 08:49 AM
Build Log #2 Free Flight to RC Flight Kitbash Contest >> AndyKunz << AndyKunz Balsa Builders 0 Oct 24, 2012 11:17 AM
