Old Dec 07, 2003, 05:41 PM
Rodd Perrin is offline
Find More Posts by Rodd Perrin
Melbourne, Australia
Joined Sep 2002
Bengtson Fokker D.VII S400 Model
I thought that it was about time to make Kurt happy and start the thread on my build of Kurt's prototype of the rudder / elevator / aileron version of the aircraft.
A far as I know this is the second prototype of the model with the first one being a rudder / elevator model built by Sam Leonard.
Seeing this is a 'prototype' model, I thought that it would be good to do it in the colours of the D.VII prototype (Attached) - the best thing being it doesn't have any lozenge
More photos to follow
Rodd
Rodd Perrin is offline Find More Posts by Rodd Perrin
Old Dec 07, 2003, 05:45 PM
Joined Sep 2002
I thought that this scheme was a little better than the overdone Raben chicken schemes
Rodd
Old Dec 07, 2003, 05:49 PM
Joined Sep 2002
Fin
Starting with the easy stuff - the tail feathers.
The fin is nothing out of the ordinary. Most is covered by the laser cut balsa, with only a little bit of strip wood needed
Rodd
Old Dec 07, 2003, 05:50 PM
Joined Sep 2002
Rudder
The rudder is mostly from the laser cut sheet, again with strip wood supplied by the builder.
Rodd
Old Dec 07, 2003, 05:54 PM
Joined Sep 2002
Horizontal Tail
The horizontal tail is only slightly more complicated, but still fairly easy to put together.
I used slightly harder balsa for the trailing edge of the horizontal stabilizer as this would act as a bit of a spar. The leading edge of the elevators was from similar stuff
It wasn't until I had glued most of the bits together that I noticed that the elevator leading edges should have been cut for each elevator to allow for the curved trailing egde to come back to the leading edge.
I don't think that it matters doing what I did as a quick swipe with the sandpaper had all the bits looking like they should.
Rodd
Old Dec 07, 2003, 05:56 PM
Joined Sep 2002
Elevator Joiner
The plans show a dowel joiner between the two elevators, but I don't like this as I can never get it to blend in smoothly.
I used wire instead.
Rodd
Old Dec 07, 2003, 05:57 PM
Joined Sep 2002
Elevator Joiner
With the leading edge of the elevators recessed to accept the joiner, it all fits nice and neatly
Rodd
Old Dec 07, 2003, 05:59 PM
Joined Sep 2002
Elevator Horn
I intend to use a pull-pull system for the tail surfaces, so I cut out a horn and reinforced the region around the elevator where the horn will go (roughly in the scale position).
Rodd
Old Dec 07, 2003, 06:03 PM
Joined Sep 2002
Control Runs
Seeing the up elevator wires on the D.VII run through the tailplane, I needed to reinforce the tail where the wires pass throught with some aluminum tube. As fate would have it, where the holes had to be is not were there was balsa, so some little ears had to be added to support the Al. tube. Here are the ears, the tube has not been added yet.
More photos tomorrow
Rodd
PS If people are getting bored with such detailed threads, please let me know and I will cut down the level of detail and provide a summary of the build instead.
Old Dec 07, 2003, 06:39 PM
ZRS4 is offline
Find More Posts by ZRS4
Wisconsin
Joined Nov 2003
the level of detail is very good..and appreciated
thank you,
tim
ZRS4 is offline Find More Posts by ZRS4
Old Dec 07, 2003, 08:17 PM
Ian Easton is offline
Find More Posts by Ian Easton
Ian Easton's Avatar
United Kingdom, Scotland, Fife
Joined May 1999
Yup, I'm with Tim. I don't mind this level of detail at all. Keep it up Rodd.
Ian Easton is offline Find More Posts by Ian Easton
Old Dec 07, 2003, 08:26 PM
sshelge is offline
Find More Posts by sshelge
sshelge's Avatar
Santiago Chile
Joined Jul 2003
Go ahead Rodd, the more details, the more we learn.
Congratulations fro your fantastic job.
cheers,
Helge
sshelge is offline Find More Posts by sshelge
Old Dec 07, 2003, 08:57 PM
sshelge is offline
sshelge's Avatar
Santiago Chile
Joined Jul 2003
Rodd,
I rather first glue the wire joiner to the leading edge of the elevators, then cut away the part of the leading edge that separates the two elevators. If idonīt it's more dificult to align them afterwards.
cheers,
Helge
Old Dec 07, 2003, 09:06 PM
AerodromeRC is offline
Find More Posts by AerodromeRC
Designing on the edge
AerodromeRC's Avatar
United States, OR, Portland
Joined Mar 2001
Rodd,
I am delighted that you are posting the build. The mod with the elevators is one of the methods that I have used as well. I find that it takes a bit more effort to make the two elevator halves line up with the wire method. However, as the saying goes " to each, his own" . Good luck with the build.
Kurt
AerodromeRC is offline Find More Posts by AerodromeRC
Old Dec 08, 2003, 06:29 PM
Joined Sep 2002
Horizontal Tailplane
Here is a shot of the horizontal stabiliser with the aluminum tubes installed.
Slots for the hinges have been cut and hinges dry fitted.
The tail only needs final sanding before it is ready to cover.
Rodd
Fokker D-VII Micro Scale Gordon Johnson Scratchbuilt Indoor and Micro Models 40 Oct 22, 2002 11:08 AM
Herr Fokker D VII JFGrn Scale Kit/Scratch Built 12 Mar 29, 2002 08:08 PM
Blue Foam Fokker D-VII Al P Parkflyers 6 Mar 27, 2002 01:10 PM
Global Fokker D VII SMB Scale Kit/Scratch Built 2 Feb 07, 2002 08:18 PM
Dare Models Fokker D-VII J Bergsmith Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2001 06:57 AM
