Old Nov 04, 2012, 04:14 PM
gianni sanchez is offline
Find More Posts by gianni sanchez
Belgium, Walloon Region, Mons
Joined Jan 2012
Build Log
mig 29 jepe fast foam scale mods
hi there , got some time to spend for another build(and because weather is really crap for the moment to attempt flying) , jepe mig 29!!
the plan is to get this fulcrum as scale as i can get with this frame ,or closest
will run this on twin 90mm and 700-68-2100kv 6s to stay light and easy to use
don't want a fast one here, just something powered enough to move well
so because pics are better than words
here are the first pics...
first are ailerons and flaps
put some fiber hinges on ailerons and rods on flaps
balsa trailing edge and soon carbon rod on leading edge
by the way here's also another mig i build for a well known workshop here in europe
JEPE fast foam
this one will not fly but just be stuck on his workshop window so everything is glued fixed with no electronic in it
was a pain in the aaaaaa.....sss to do
i plan to do it on mine too ... hmmm
gianni sanchez is offline Find More Posts by gianni sanchez
Old Nov 05, 2012, 04:59 PM
Joined Jan 2012
some update here....
wings are done , servo's in pace and hidden with balsa plate
u may notice the servo' wire is next to it on its complete lenght
this is to prevent cutting the whole wing to replace an eventually dead servo ,the cut to replace will be pretty small , so not much work to hide it again then...
flap are in pretty good shape ,with some graupner hinges
retracts are already in place, those are old ones from my old stock and come from jepe (think same as hk but bigger hole /6mm)
template in the cockpit in place
top of fuselage already received on coat of epoxy HT-2 and 25gr fiberglass
this combination is really strong!!much better than fiber/PU
stabs are also ready fibered and reinforced with carbon rod on leading edge
and balsa trailing edge...carbon rod purpose is the avoid scratch or dents during transports, and it make them stronger anyway
tails are modified to look like the real deal ..
also some carbon rods to make them "unscratchable"
bottom duct part is already fiberglassed too
and sanded at the good shape ( at least thinner!!)then double glassed on edges
Old Nov 05, 2012, 05:20 PM
Joined Jan 2012
same deal for leading edge wings, carbon there
i've shape the LE thinner , the stock one is soooooooo thick!!
and finally glue wings in place ( yes ,those won't be removable, i have a big car )
carbon key is just glued in place with 15min epoxy , then, another layer of epoxy/micro ballon mixture to fill up the big hole
and finally some lightweight renoband for a smooth finish (still need to sand it )
u can see the nice housing i did for the carbon key with airtool and metal grinder ( i am an old'car builder by the way ...)easy and fast !
that's where i am so far on 3 days work
the final scheme should be the same as the one i do for fast foam workshop , pixel camo
as the last picture
Old Nov 06, 2012, 05:59 PM
Joined Jan 2012
so....i feel like talkin' to myself
but ok ... here's some more pics
i only got time to put light weight filler on wings today
others stuff like landing gear , motor and jet fan 90mm ,maybe try to mod the jet fan housing to put vasa rotor ( a bit bigger)
also plan to put much thicker rod into stabs , with brass tube to guide them on plastic brackets...
if anyone has some other good idea to get those stabs strong???
Old Nov 07, 2012, 12:56 AM
Graham d is offline
Find More Posts by Graham d
South Africa, GP, Pretoria
Joined Mar 2011
Gianni,
It is looking good.
I love full moving stabs but just dont have a lot of faith in them. I fixed my stabs on the Mig and cut in moving surfaces to have a strong setup. If you are going full scale, this will not be an option, but I hate spending time on a jet and losing it on something like this.....
The Mig does fly really well and you will enjoy her.
Graham
Graham d is offline Find More Posts by Graham d
Old Nov 07, 2012, 03:39 PM
Joined Jan 2012
thanks graham, in fact , this is my second one !
first one i v'e sold last year was stock , no jepe mods
that should be cool to find a easy and fast way to make those stab full move
as u said much time to spend here ....
Old Nov 18, 2012, 06:05 PM
Joined Jan 2012
finally found myself a way to get stabs works nice and strong enough to avoid "flueting"(don't know the exact words for it)
i glued a carbon rod into de stab and slip it into a brass tube witch is at the perfect size to get a tight movement
this brass tube is itself glues in the stock( but drilled )stab bracket
some screw or washer will avoid the rod to slip out the tube
don't have more time to spend on this build for the moment but i will keep on posting
here's pics
Old Nov 19, 2012, 12:43 AM
Graham d is offline
Joined Mar 2011
here's pics
Looking good. I would just reconsider the colour scheme. Think that the visibility could be an issue.
Old Nov 19, 2012, 03:00 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Nice build!
Where do you have the struts from?!
regards Martin
MaHö is offline Find More Posts by MaHö
Old Nov 19, 2012, 06:15 AM
GeorgeStyriaII is online now
Find More Posts by GeorgeStyriaII
Österreich, Stmk., Graz-Umgebung
Joined Sep 2011
Hi Gianni,
nice build!
What are the yello pices in the background??
Regards
George
GeorgeStyriaII is online now Find More Posts by GeorgeStyriaII
Old Nov 19, 2012, 04:30 PM
Joined Jan 2012
Thanks Graham! But i Think this is the price to pay to get this one not boring
And don t worry buddy i have some pretty efficient eyes!!
Those struts Come from jet power this year but i m pretty sure they come
From hk!
The yellow parts come from the tetris f-15 i bought at bukvorez. Ru, but i'm sure u already know it as u build yourself the mig 29 ( by the way nice and clever build!)
I Will create ā new thread soon for this f 15!!
Old Dec 09, 2012, 02:50 PM
Joined Jan 2012
cold here!!
so here's some updates
the show room mig 29 is almost done all the camo is done now
left some undercarriage paint and some details...
work in progress for the nose .....
Old Dec 10, 2012, 04:46 PM
Joined Jan 2012
the final touch for the mig nose!
and a lil' scale upgrade on the front
IR cam is the next on the nose
Old Dec 23, 2012, 06:10 PM
Joined Jan 2012
the "show room " mig 29 is finally done !
add some details upgrades, IFF antenna ,HUD in the cockpit,etc...
and weathering!!
check out !
Old Dec 24, 2012, 01:59 AM
Graham d is offline
Joined Mar 2011
and weathering!!
check out !
Gianni,
Great looking Mig!!!!! I still love flying my Mig.
Discussion Jepe "Fast Foam" Mirage Chris True Foamy EDFs 157 Jan 23, 2016 12:55 PM
Build Log Jepe Fast Foam BAE Hawk kelvin Foamy EDFs 385 May 17, 2014 01:45 PM
Sold Haoye - jepe fast foam f-18 hornet pajlotmato Aircraft - Electric - Jets (FS/W) 0 Mar 26, 2012 02:21 PM
For Sale RTF Mig 29 Fast and Fun dlewton Aircraft - Electric - Jets (FS/W) 4 Mar 15, 2012 01:03 PM
Discussion Jepe fast foam website jacojet Foamy EDFs 9 Jun 01, 2010 12:47 AM
