Old Nov 04, 2012, 12:26 PM
Markx is offline
Find More Posts by Markx
Sussex,GB / Azores
Joined Apr 2008
Why Jib boom on Swing rig?
On swing rigs, why is the jib not tied directly to the front boom but has its own separate boom?
Markx is offline Find More Posts by Markx
Old Nov 04, 2012, 02:12 PM
hiljoball is online now
Find More Posts by hiljoball
hiljoball's Avatar
Canada, BC, Strathcona
Joined Jul 2011
I would think that it is to allow accurate control of the position of the clew, for draft control and for leach tension.
John
hiljoball is online now Find More Posts by hiljoball
Old Nov 04, 2012, 04:43 PM
Markx is offline
Sussex,GB / Azores
Joined Apr 2008
But wouldn't that be pretty spot on without the boom anyway?
It only needs a small gap.
I haven't tried it but I'm just wondering if there is any point on a non-racing boat, This one will be used for towing out fishing lines in less than favourable conditions so I want to keep it simple as it might be lost.
Old Nov 04, 2012, 04:55 PM
Dick L. is online now
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
IMHO.....
Without using the jib boom to "leverage" the forestay tension, the jib luff would have a tendency to fall off as winds increase. Fastening to the front fixed boom (to which the jib boom fastens) would result in having to manually adjust forestay tension. Using the moving boom, much like on a conventional rig, as you move the attachment point forward or aft, you increase/decrease luff wire tension. Also, using a jib boom allows you to install a leech line to control the leech of the jib.
Dick L. is online now Find More Posts by Dick L.
Old Nov 04, 2012, 06:32 PM
Gregg28 is online now
Find More Posts by Gregg28
Don't lie to my dog.
Gregg28's Avatar
United States, DE, Wilmington
Joined Jun 2005
Without a jib boom you would have no slot between the jib and the main. The sails would not work together as they would not have the correct relative position to each other.
Gregg28 is online now Find More Posts by Gregg28
Old Nov 05, 2012, 02:52 AM
Markx is offline
Sussex,GB / Azores
Joined Apr 2008
Thanks D+G, I sort of get the idea now.
Looking at the drawings, I still wonder if the "natural" gap it would form in practice wouldn't be fine anyway. Maybe I'll try it and see.
Finally got time to get on with the fishing line tug project and I've nearly finished a rough prototype plywood hull, see this old thread:
http://www.rcgroups.com/forums/showt...1436244&page=4
Old Nov 05, 2012, 05:12 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
When you are looking at the kind of performance that having a swing rig implies, you do need tight control over sail shape and the slot. Between the leech and luff lines, and the rigid boom there is a set triangle formed, giving full control over sail shape and slot giving you what you "want" and keeping it that way, rather than letting nature give you what you "deserve" with every change in wind speed and direction.
Note that on most rigs with a jib boom, the jib pivot is usually some way back from the forefoot, so that leech and luff lines can act together under tension to maintain sail shape.
mfr02 is offline Find More Posts by mfr02
Old Nov 05, 2012, 05:13 AM
Gregg28's Avatar
Joined Jun 2005
Look at any big boat. The sheeting angle for the jib is never on the center line (unless it has a jib boom).
Old Nov 05, 2012, 10:12 PM
m.g. is offline
Find More Posts by m.g.
Joined Sep 2009
What's a clew and what does it do? What is leach tension ? Newbie here trying to learn. Thanks Mike
m.g. is offline Find More Posts by m.g.
Old Nov 06, 2012, 07:43 AM
mfr02 is offline
Blackpool, Lancs
Joined Feb 2006
Almost any full size boat. Full size practice is generally to have a loose foot, so the forward most point of the foresail is on the centerline, thus the sail itself has to be one side or the other. I did see, in a "Classic Boats" several years ago, a full size swing rig, which closely followed model practice.
There will be differences in practice between real and model because the real thing has a crew, models need to work reliably and simply. Thats probably why genoa rigs are rare in working models - tacking is much simpler with a self tacking rig.
Old Nov 06, 2012, 09:54 AM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
..and on real boats you drop the Genoa and hoist a spinnaker when far enough off the wind. A jib boom gives you a decent compromise between the two sails. Self tacking for upwind work and the boom holds the clew out for down wind performance.
For MG - a triangular sail has three corners and three sides. The clew is the lower outer corner and the leech is the trailing edge. Clew tension/position effects sail draft and leech tension, both of which get set for the wind conditions.
Dave
boater_dave is offline Find More Posts by boater_dave
Old Nov 06, 2012, 01:47 PM
Markx is offline
Sussex,GB / Azores
Joined Apr 2008
So how about tying the jib leech to the mast at regular intervals?
That would control the gap somewhat positively!
Old Nov 06, 2012, 02:14 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Only for one point of sail. You would have to bring it ashore to make changes when on a different heading. Sailing upwind, perpendicular to wind, and away from wind all requires a different sail setting (both jib and main). Rather cumbersome to have to find a way to bring it back to shore to allow you to reset the sail - no ???
Old Nov 06, 2012, 04:22 PM
Markx is offline
Sussex,GB / Azores
Joined Apr 2008
No, on a swing rig the jib always stays at the same angle in relation to the mainsail, rather like a slit on a wing.
Tying it at regular intervals would provide rigid control of that gap all the way down the leech.
Old Nov 06, 2012, 04:27 PM
m.g. is offline
Joined Sep 2009
Thanks for the info Dave, very helpful.
Discussion on autorotate, tail swings right 90 degrees, why? finguz Electric Heli Talk 38 Oct 31, 2012 08:38 PM
Discussion Swing rig hulls xlaorta Sailboats 6 Apr 18, 2012 09:51 PM
Cool Naza quad boom comes loose and swings mid flight and survives!!!!!! Arxangel Multirotor Talk 8 Apr 13, 2012 09:52 AM
Question Attaching the jib boom to the deck of an RC sailboat John Bennett Sailboats 4 Mar 10, 2009 08:25 PM
Discussion Jib boom??? Speedo125 Sailboats 8 Jun 04, 2007 01:16 AM
