Old Nov 15, 2012, 02:18 PM
tburley is offline
Find More Posts by tburley
Bakersfield, CA
Joined Sep 2003
looks good Jeff, I know those uppers hatches on the Viper
where not really tight before.
tburley is offline Find More Posts by tburley
Old Nov 15, 2012, 09:46 PM
jefffassbinder is offline
Find More Posts by jefffassbinder
jefffassbinder's Avatar
United States, CA, Chino Hills
Joined Jan 2011
Well there is a need for a few of those BV tabs
Ya Todd, needs a few more tabs and maybe a re-adajustment to the tabs on the mid section to get a more snug fit. Well the wet sanding and then I hope to bring out the paint. I need to still make a former for the nose gear retract unit.
jefffassbinder is offline Find More Posts by jefffassbinder
Old Nov 17, 2012, 04:56 AM
Joined Jan 2011
Prep and Masking
Well getting a lot closer to bringing out the paint. Was sanding and doing some prep and masking. I hope the temps are a little higher tomorrow so I can paint.
Old Nov 17, 2012, 03:48 PM
Joined Jan 2011
Painting
Bring out some paint. Todd make it look easy. Well this should work for now. I have a few more things I need to attend to and then electronics.
Old Nov 18, 2012, 01:29 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Jeff,
Great job with your repair and repaint! Cant tell it was even damaged! Looking forward to seeing this with a 90mm in it!!!
pdawg is offline Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old Nov 18, 2012, 09:28 PM
Joined Jan 2011
Repairs
Hello pdawg, hey thanks for the cover on the F-22 I did receive that and will use. Well the Viper is coming along. I need to create a step to reduce the ducting to fit the fan face. Then figure out the battery mounting. I hope that I can use the same setup battery I'm running on my T-45 90mm as I'm able to fly for 5 minute on a 12s setup. I only fly around a 50-60% and gun it on the strafe. I hope that I'm able to use the same battery configuration in order to reduce battery weight. Reduced weight and lighter wing loading and maybe have a great combo, maybe.... Well only one way to find out and for me it is not on the bench. So time to get it done and ready for flight once again. My hope is better flight performance at a lighter AUW.
Old Nov 19, 2012, 03:12 PM
db_sonic is offline
Find More Posts by db_sonic
Joined Feb 2010
I see bottles of testors enamel. Is that what you are using and if so what do you use as a reducer? Looks good.
db_sonic is offline Find More Posts by db_sonic
Old Nov 19, 2012, 07:21 PM
RCSCALEGUY is offline
Find More Posts by RCSCALEGUY
Joined Mar 2007
paint thinner
1 to 1 works great.
RCSCALEGUY is offline Find More Posts by RCSCALEGUY
Old Nov 19, 2012, 08:10 PM
Joined Jan 2011
Reducing Paint
Paint Thinner is what I use to reduce the paint with enamels. Ratio for me depends on temperature.
Old Nov 23, 2012, 01:28 AM
Joined Jan 2011
Nose Gear in and doing a door
Well here is the unfinished part of the Viper. I have put a nose gear unit in and again stayed simple and as light as possible. I was going to just do a panel for the nose gear to pop through but instead said to myself why not just seal it up. So I made a door and then hinged and got the shape. Now glassing and will start the prep to paint this small area which was painted yellow previously. Then install my valve and also steering and valve servo. Then create a door mechanism to open and close via the wheel or strut.
Old Nov 24, 2012, 01:04 AM
Joined Jan 2011
Nose Section
Well I'm getting closer to getting this Viper back to flight status. I've glued in my tabs for the TJ 90mm and moved it way back from the front intakes in order to reduce sound. Also by using a 90mm fan I can use 12s 3300 thru 3700 mah packs. This should reduce weight. While still providing 5 minute flights.
I've also opted to create a functioning gear door on the nose wheel rather than a cut out. Mounted my steering servo and check the travel. Now I just need to create a mechanism for the door to close on retraction.
Last I've painted the bottom nose area Yellow as Todd had done to mimic a scheme he had done on one of Dino D. birds. Well I've continued with what he had previously done. Well it's not Todd super quality but should be good enough for me. Upstairs it should provide a little visibility while inverted turning right.
Old Nov 24, 2012, 09:44 AM
tburley is offline
Bakersfield, CA
Joined Sep 2003
I likey
Old Nov 26, 2012, 03:45 PM
Joined Jan 2011
Getting the electronics installed
Well it getting close to ROG. I made a intake extension to get the air moving back to the fan in it's new location. I will be finishing up the airlines and then it should be ready to go. Well thanks Todd, your paint scheme is really good and it good practice to try to learn what you did. Since I still have a big ME-262 hiding out. Which I would like to put together and fly. Rich's bird is a great flyer and at it size is very nice. Twins would be cool.
Old Nov 26, 2012, 08:15 PM
Pandissix is online now
Find More Posts by Pandissix
Pandissix's Avatar
United States, CA, Ladera Ranch
Joined May 2007
Jeff that paint scheme is almost too good. She is tough to see. Before I put her in I talked to Todd about putting some yellow on the bottom wing tips. Luftwaffe did this in th early years so not to far from accurate. Anyways. Something to consider.
Pandissix is online now Find More Posts by Pandissix
Old Nov 26, 2012, 08:18 PM
tburley is offline
Bakersfield, CA
Joined Sep 2003
agree, add some yellow as rich mentioned
Help! back of brushless motor came out! W.T.F help! willfly1929 Electric Power Cars 4 Aug 19, 2012 07:49 PM
Found BVM Viper or Aggressor Fanflyer Aircraft - Fuel - Jets (FS/W) 0 Aug 08, 2012 02:53 PM
Found BVM Viper or Aggressor Fanflyer Aircraft - Electric - Jets (FS/W) 0 Aug 08, 2012 02:31 PM
Yippee! Came back to Co-Pilot II... and couldn't be happier Mike_Then FMA Direct 0 Jul 24, 2012 03:30 PM
Discussion SAD...after 17 years..came back home with NO PLANE...Lost Plane... guyg Aerial Photography 19 Mar 23, 2008 01:30 PM
