Old Nov 04, 2012, 10:07 AM
LowlyElevated is offline
Find More Posts by LowlyElevated
Because I was INVERTED
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
What is it????
I have this plane that a fellow clubmember gave me, and I want to know what it is. I believe it to be a Herr Little Extra but I have never seen one before so I can't be certain.
The engine is also unidentified. This model was owned by a guy in england, so I believe it is of british design
On one side it says AP and on the other side it says 9. It has a throttle carb on it, with two needly valves. It has a muffler attached to it, a interesting design that sits right behind the engine (Rear exhaust???) and is not the shape of a modern muffler.
LowlyElevated is offline Find More Posts by LowlyElevated
Old Nov 04, 2012, 10:13 AM
Joined Sep 2012
Update I have confirmed it to be a herr little extra, but still unknown on the engine????
Old Nov 04, 2012, 10:42 AM
skaliwag is offline
Find More Posts by skaliwag
The engine is an AP. .09 or .15. What size prop?
skaliwag is offline Find More Posts by skaliwag
Old Nov 04, 2012, 10:49 AM
surfer_kris is offline
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
Judging by the head it is an AP 09 engine.
surfer_kris is offline Find More Posts by surfer_kris
Old Nov 04, 2012, 02:00 PM
Joined Sep 2012
AP 09 would make sese. It says AP one one side, 9 on the other.
Old Nov 04, 2012, 02:06 PM
Joined Sep 2012
How long have these things been around? Mine seems to be an older specimen and is gommed up a bit. How should I clean it?
Old Nov 05, 2012, 12:26 PM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
Well, if a plane is really filthy with grease and dirt, I will take rubbing alcahol and cotton balls and clean it with that, but I only do that when I need it, because it smells bad. I use 409 to clean up from everyday flying.
Kyler1 is offline Find More Posts by Kyler1
Old Nov 05, 2012, 09:06 PM
Joined Sep 2012
Sorry I didn't make myself clear, I mean the engine. I have had to clean a few planes here and there
Old Nov 05, 2012, 09:48 PM
Sweden
The inside will clean itself while running. For the outside, just leave it as it is, a little patina just shows that it has lived.
Old Nov 05, 2012, 10:27 PM
Joined Sep 2012
The way it is now, It will never run. It is incredibly stiff, to stiff to even attempt starting.
And, what kind of fuel should I use? I have never had anything smaller than a .40 so I have no clue
Old Nov 06, 2012, 06:50 AM
Sweden
Fead it some glow fuel and turn it over, that's usually enough. If not then take it appart and clean in glow fuel.
These engines are no different from a .40 engine, any fuel with about 20% oil and 5-10% nitro will do.
Old Nov 08, 2012, 12:17 PM
OkiThumper is offline
Find More Posts by OkiThumper
Closed Account
Joined Feb 2006
Originally Posted by Waffleman View Post
The way it is now, It will never run. It is incredibly stiff, to stiff to even attempt starting. And, what kind of fuel should I use? I have never had anything smaller than a .40 so I have no clue
This is how I do it. YMMV. I disassemble it and soak it in a volatile solvent like acetone. Since I am out of acetone, I used automotive lacquer thinner.
I am careful during disassembly to not destroy any gaskets so I can reuse them. Otherwise, I end up replacing or manufacturing my own. Recently I used Permatex Ultra Gray RTV caulk to replace an OS Max .10 back plate gasket. Not saying to do that, I'm experimenting the gasketless solutions.
Don't soak the gaskets and above all the neoprene O-rings om solvent, good way to damage or destroy them.
Wear gloves. Use something like an old toothbrush to remove grime after softened. Fine steel wool or Scotchbrite pad will help to clean the upper combustion chamber. Go easy on the aluminum parts.
I compressed air if available to blow out the solvent from parts. If not available, then I make sure the crud particles are washed out by swishing in solvent before removing. After drying and during reassembly, I put a drop or two on all bearing surfaces and wipe the cylinder bore with motor oil or 3-in-1.
Your .40 sized fuel should be okay if you have some nitro content. I found this recommendation in the AP Wasp .061 Instructions, which seems to be good advice on having at least some Castor oil content in the fuel:
AP Instructions: Note: We do not recommend using fuels that contain only synthetic lubricants. Synthetic lubricants have a much lower flash point than Castor Oil lubricants. The Flash point is the point at which the lubricant suspended in the fuel begins to actually burn and loses itís lubricating qualities. Using fuels containing a blend of Castor Oil and synthetic lubricants results in an engine that runs cooler and lasts longer. One lean run using a fuel containing only synthetic lubricants can cause severe engine wear and eventual failure in a short period of time. Using fuels with a Castor Oil and synthetic blend of lubricants greatly reduces this chance. Please also keep in mind that the higher percentage of nitro in the fuel will produce more power, yet it will also cause the engine to run hotter and to wear more quickly. This is just one more reason to use a fuel containing a Castor Oil and synthetic lubricant blend.
OkiThumper is offline Find More Posts by OkiThumper
Old Nov 08, 2012, 03:06 PM
Joined Sep 2012
I got it freed up by putting some fuel through it and letting it sit for a few minutes. Still has good compression.
My fuel is 10% nitro with a 18% oil blend of castor and synthetic. Sounds like the perfect fuel for it, So i'm going to try to start it up today.
Old Nov 08, 2012, 05:08 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
It is a nice running motor, and a good simple design. You will likely find it a good match for that plane.
aspeed is offline Find More Posts by aspeed
Old Nov 08, 2012, 07:33 PM
Joined Sep 2012
I got it fired up today. Needed 5 clicks richer and it was singinn dixie
Question sport, pylon, f3a.. what are all the catagories and what do they mean? flybybob Beginner Training Area (Fuel) 3 Jun 30, 2012 10:10 PM
Discussion what could cause a belt to get lose and what can i do wc_wickedclown Electric Heli Talk 6 Jun 23, 2012 03:01 AM
Discussion What plane? What to use my Sbach 342 guts in ? phranticness Scratchbuilt Indoor and Micro Models 9 Jun 05, 2012 01:42 PM
Question What motor to what speed control? Free Scratchbuilt Indoor and Micro Models 1 Mar 29, 2012 10:14 PM
