Old Nov 03, 2012, 09:58 PM
Spamman127 is offline
Find More Posts by Spamman127
United States, OH, Troy
Wing Shear, Bending and Spar Spreadsheet
I've been wondering how to calculate the shear loading and bending moments of a canteliever wing for a while, so I decided to look it up. I found a good paper and a helpful wikipedia article. I decided to make a spreadsheet to do the calculations for me. It determines the Limit Shear and Bending moments using the Schrenk elliptical approximation, then on the next spreadsheet you can design an I-beam spar using the data. I also included several common building material strengths and had the spreadsheet determine if these materials were strong enough in bending moment for the spar at the given section points.
Its has some limitations mostly that you cannot tell what will happen when you use different materials for the spar caps and shear web. Also it doesn't determine if the spar is strong enough in shear, but it is my assumption that if it is strong enough in bending it should be strong enough in shear.
Use:
Place your aircraft information into the purple boxes. Go to the next spreadsheet and design your spar by changing the data in the purple boxes making sure the material you wish to build with can handle the stress.
Paper: http://www.lightaircraftassociation....roximation.pdf
Wikipedia: http://en.wikipedia.org/wiki/Second_...l_axis_theorem
Scott
Spamman127 is offline Find More Posts by Spamman127
Old Nov 09, 2012, 05:56 PM
Panoramix is online now
Find More Posts by Panoramix
Cheese eating monkey.
France, Bretagne, Rennes
Joined Jul 2011
Thank you for posting this, unfortunately, I am not used to imperial units so didn't really inderstand the nitty gritty of the spreadsheet but the paper looks clear and concise.
Panoramix is online now Find More Posts by Panoramix
Old Nov 09, 2012, 09:58 PM
ciurpita is offline
Find More Posts by ciurpita
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
collection of info on spar construction
http://ciurpita.tripod.com/rc/notes/compositeSpar.html
ciurpita is offline Find More Posts by ciurpita
Old Nov 21, 2012, 10:59 PM
mithrandir is offline
Find More Posts by mithrandir
TEAM FUTABA TEAM DURALITE
mithrandir's Avatar
Joined Nov 2004
I threw a little something t'gether a few years ago....
takes the planform, applies Schrenks, calculates the moment at multiple locations along the span, calculates the shear, calculates the shear web thickness based on material properties.. as well as spar cap thickness...
mithrandir is offline Find More Posts by mithrandir
Discussion Seagull MXS-R 91-120 wing tube bending. Nitro2Burn Fuel Plane Talk 37 May 08, 2015 07:30 PM
Question Bending foam wings muka Beginner Training Area (Aircraft-Electric) 4 Feb 29, 2012 01:16 AM
Discussion Engineering school- shear vrs bending moment FlyVA Multi Task F3X 8 Mar 01, 2011 07:13 AM
Discussion Wing bending - shear flow capricorn Modeling Science 28 May 25, 2010 01:55 PM
Question Is it a spar or is it a shear web? BillO Composites Fabrication 39 Nov 09, 2009 04:39 PM
