Old Nov 03, 2012, 05:42 PM
gearwolf is offline
Find More Posts by gearwolf
Joined Apr 2012
Question
Alternator that outputs 12V to recharge a 3s inflight
So I was wondering if there was an alternator that would spin off of a gasser that would go in parallel with a 3s battery (~12V) so that the backup battery wouldn't discharge as much or could be recharged inflight? If there isn't, how would I go about making this? Also is this bad for the battery?
gearwolf is offline Find More Posts by gearwolf
Old Nov 03, 2012, 08:11 PM
rmteo is offline
Find More Posts by rmteo
User
Colorado
Take a look at Sullivan Products
rmteo is offline Find More Posts by rmteo
Old Nov 03, 2012, 09:46 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
The idea of gasser recharging/generating inflight has been brought up many times, and normally comes to the conclusion that adding a gas tank, alternator, and engine is bulkier, messier, and heavier than simply adding more battery.
As long as you keep voltage/current within the LiPo's limits, it shouldn't be very bad for the battery. You might need a charge controller in there to manage the lipo charging.
acetech09 is offline Find More Posts by acetech09
Old Nov 03, 2012, 10:04 PM
gearwolf is offline
Joined Apr 2012
Yah I've looked at those. I guess if I broke down a small charge station it would work. This actually won't be for a gasser. I was trying to simplify it a bit. The objective is getting power from an autogyro back into the system for longer duration flights.
Old Nov 06, 2012, 12:34 PM
Acetronics is offline
Find More Posts by Acetronics
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi,
A friend of mine used a brushless motor as a generator ... aboard a ~ 2m / twin engine RIVA boat model !
riva lagaffe (2 min 5 sec)
but the purpose is to power the electrical systems of the boat ( and spare the dedicated battery ) ... but the gassers are mainly used for propulsion !
Alain
Acetronics is offline Find More Posts by Acetronics
Old Nov 06, 2012, 07:56 PM
john dee is offline
Find More Posts by john dee
john dee's Avatar
New Zealand
Joined Aug 2006
Sounds like an experiment to check that the 2nd law of thermodynamics still holds.
john dee is offline Find More Posts by john dee
Old Nov 06, 2012, 08:22 PM
gearwolf is offline
Joined Apr 2012
Lol yah physics is a p.i.t.a. It gets in the way of everything. You're right but I don't want it to be right. Well anyway I'm still looking for a way to try this. A way to get a generator to act as a parallel battery to my main flight pack. I have seen 12v regulators and maybe I should add that after the converter from three phase to two. Does this sound right?
Old Nov 08, 2012, 04:41 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
I'm not suggesting this is going to get you to your goal of improving flight times, but you could look into this generator that is used on gasser helis (usually for AP, and not as popular now with the proliferation of LiPo receiver batteries). This system puts out 5.4 volts, but that is just because they have selected a 5.4v regulator to use with radio systems. You could probably do something similar with a 12v regulator...
http://mysite.verizon.net/vze49gsg/
aaronredbaron is offline Find More Posts by aaronredbaron
Old Nov 08, 2012, 05:11 PM
gearwolf is offline
Joined Apr 2012
I understand, this was wishful thinking for me. I remember seeing that and probably got deterred by the price but then again hopefully you get what you paid for. I will contact that person. Thank you for helping me find a system. If anything it will make a funny video.
For Sale 12v 700w HP Server PSU dual 4mm output dasrustler Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 02, 2012 01:43 AM
Discussion Need a good, low noize 12v output regulator... SpeedMaster FPV Talk 6 Aug 24, 2012 02:29 AM
Sold 12V @ 700W x 2 w/4 outputs each or 24V @ 1400W shipped Priority USA LowWatts Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jul 29, 2012 11:26 AM
Discussion Cannot get 12v DC output from Delta DPS-700EB brightfan Batteries and Chargers 5 Apr 01, 2012 12:06 AM
Question how can i make a 3s lipo to 9v output voltage regulator? kicekilla FPV Talk 5 Mar 09, 2012 10:01 PM
