Old Nov 03, 2012, 01:21 PM
KM.Racing is offline
Find More Posts by KM.Racing
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
Motor Amps
Ok this may be a stupid question but what is the Motor Amp
let's say a max current in 2000kv motor is 95A
what's the 95A in case the lipo 3s let's say is 5000mAh ?
KM.Racing is offline Find More Posts by KM.Racing
Old Nov 03, 2012, 04:12 PM
785boats is online now
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
The only stupid question is the one that is not asked.
The 'Max amps' rating on a motor is its max "efficient" amp rating. The motor will easily pull more amps than that if the prop is bigger & it is cooled.
By the time you get the right prop for thr best speed with acceptable temps on motor,ESC & batteries, that 95A motor will be pulling around 120A- 140A maybe more.
So you need to size the batteries (and ESC) to suit more than the Max amp rating of the motor
The output of a battery is determined by both the MAH & the C rating of the pack.
A 5000mah pack at 20C will only yield 100A. Not big enough for your 95A motor.
A 5000mah pack at 45C will yield 225A
Running packs in parallel will double the available current.
Cheers.
Paul.
785boats is online now Find More Posts by 785boats
Old Nov 03, 2012, 04:57 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
Originally Posted by 785boats View Post
Cheers.
Paul.
wow thank you very much Paul for these important information
so do you think I should increase the Amps in the ESC ?
in case I'm using 3674 2200kv max A is 90Amps ; ESC :Turnigy Marine 120 A ?
the battery I'm using are nano Tech Turnigy 25C-50C thank you again
Old Nov 03, 2012, 06:11 PM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi JAD,
The T-120 should be sufficient, my son runs the Aquacraft 2200Kv on 4S in his Arowana and uses a 200A 'marinised' Mystery ESC which barely gets handwarm after a 6 minute run.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Nov 03, 2012, 06:52 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
Originally Posted by pompebled View Post
Jan.
hey thank you Jan you've really relaxed me
Old Nov 04, 2012, 12:43 AM
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
It really depends on the size & type of boat, & also the size & type of prop you are running.
I've blown the caps on a 120A Turnigy ESC with a 3674 2200kv Leopard in my 31" Arowana, with a 440/3 blade prop. But a Himodel GX 200A ESC's ( similar to the Mystery one that Jan mentioned) has no problem with that set up.
What boat & prop are you using?
Old Nov 04, 2012, 09:11 AM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
I have a 29 inch Vee Hull 26 cm beam total weight is about 3kg a octura 442 prop
thanks
Old Nov 04, 2012, 09:35 AM
Sneek, Netherlands.
Joined May 2004
An extra caps bank on the T-120 wouldn't hurt.
Regards, Jan.
Old Nov 04, 2012, 03:40 PM
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Totally agree Jan. But yes that 120A ESC should be fine with that set up.
But JAD, make sure the timing is set to the lowest setting as it is a D wind motor, & they only like around 1 - 3 degrees of timing.
Cheers.
Paul.
Old Nov 04, 2012, 05:00 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
thank you guys for the advice
but please can you tell me what do you mean by the timing ?
I really feel far from you boaters :$
Old Nov 05, 2012, 02:56 AM
Sneek, Netherlands.
Joined May 2004
Hi JAD,
Out of the box, the T-120 is set on a timing of 15, which is fine for a Y wind, but too high for a D-wind.
Setting the timing lower is a piece of cake when you follow the instructions, or use a programming box.
I'm running my Turnigy 3674-B-1900Kv on a 7 timing and nothing gets warm.
Regards, Jan.
Old Nov 05, 2012, 12:48 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
Jan thanks buddy so the timing is about increasing the rpm of the motor yeah ?
as we increase timing as the motor spin more faster and the esc will get warm .
question how to program the turnigy marine 120 A to 7.5?
do you know a programer box compatible for this esc ?
Turnigy Marine
Programmable settings
Reverse
Low Voltage (none/2.8v/3v/3.2v/3.4v)
Brake: (none/soft/hard)
Timing (0.00/3.75/7.50/11.25/15.00/18.75/22.50/26.25)
again thank you very much !
Old Nov 05, 2012, 01:17 PM
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Hi JAD. Looks like Jan has taken time out to sleep.
Here's the programmer for your 120A ESC It also does the 180A when you get one.
Turnigy & Seaking are the same ESC's
http://www.offshoreelectrics.com/pro...-pcard&cat=136
Just follow the instructions that come with
Old Nov 05, 2012, 02:07 PM
Maritime
KM.Racing's Avatar
Turkey
Joined Apr 2012
thank youuuuuuuuuuuuuu
really rc boaters are nice people
Old Nov 05, 2012, 04:17 PM
brushman is offline
Find More Posts by brushman
Joined Oct 2007
hello,
be carefull with the nano's, 25c is not too much, do not over prop!
brushman is offline Find More Posts by brushman
Discussion Official Suppo Motor & ESC Discussion/Q&A Thread Garret H Power Systems 26 Sep 30, 2015 10:52 PM
Sold Kv760Brushless Motor & 30 amp ESC -- Brand New jeb6684 Aircraft - Electric - Power Systems (FS/W) 1 Jul 19, 2012 03:13 PM
Sold MK Octo2 Frame & Motors / 8x BL2.0 & Distribution Board / MKTR Sid3ways Aircraft - Electric - Multirotor (FS/W) 0 Apr 15, 2012 08:36 AM
For Sale Brushed Motors & Gear Motors, $5 shipped eboggs59 Aircraft - Electric - Power Systems (FS/W) 1 Mar 15, 2012 09:58 PM
