Old Jan 28, 2013, 03:12 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
Originally Posted by vincent123 View Post
Which holes do you mean, the control wire holes?
That's the ones.
Re the wing loading,I haven't the knowledge to advise on that.If you don't get a response from one of the more experienced guys,try a search on here.
Just type in loading- show posts.(don't enter wing loading)
Stupot46 is offline Find More Posts by Stupot46
Old Jan 28, 2013, 08:09 PM
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
Therefore, i need your opinions here: is a flying wing of 13.2 oz/ft3 cubic wing loading and 21 oz/ft2 wing loading, considered as a heavy wing, normal wing or in between ?
What's your wingspan? For any aircraft, my personal rule of thumb is 10g/dm^2 per meter of wing = light. So a 2m sailplane should have a wing loading of 20g/dm^2 while a 10 inch indoor floater should have a wing loading of 2.5g/dm^2 (approx 25cm).
Your wing is roughly 64 g/dm^2 so it's light for a 6.4m wing, medium for a 3m wing and heavy for a 1m wing.
slebetman is offline Find More Posts by slebetman
Old Jan 29, 2013, 11:17 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
It's a 1.1m span, 24dm2 area, 1400-1500 gr depending on finishing method.
vincent123 is offline Find More Posts by vincent123
Old Feb 04, 2013, 02:46 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
FZ3 build: fuselage
Fuselage with retract and motor mount fitted.
Still fiddling with the bay door, not yet satisfied ..., too fragile, need to make it more solid: it will be catching a deal of air..
Door servo not yet in place.
Old Feb 04, 2013, 02:56 PM
Stupot46's Avatar
Joined Sep 2011
Coming together nicely.
One point I've picked up while reading on here is the effect the retract will have on the cg.It's going to move it back when deployed,you'll need to work a way round that for take of and landing.
Stuart.
Old Feb 04, 2013, 03:07 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Yes indeed !
The wheel itself is not heavy, I calculated that when the retract is out (landing) the cog will shift backwards with 5mm: should be acceptable!?
Should be also good for taking off: less nose heavy.
Old Feb 09, 2013, 12:56 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Today busy re-making the front gear door thingy.
Connected the 2 hinges for torsional stiffness.
Old Feb 10, 2013, 07:14 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Finally managed to make a video footage !
Flying wing with landing gear (0 min 23 sec)
Old Feb 10, 2013, 07:38 AM
Stupot46's Avatar
Joined Sep 2011
Nice smooth action!
Old Feb 10, 2013, 09:55 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Originally Posted by Stupot46 View Post
Nice smooth action!
I have no clue whatsoever, if the door or wheel and mount is strong enough during flight
First time i'm making this kind of stuff.
Thinking to do maiden with wheel out till landing, then check it all and if all ok, retract it during the next flight
Old Feb 10, 2013, 11:15 AM
Stupot46's Avatar
Joined Sep 2011
The take off,and particularly landing,are going to put a lot of stress on the gear mounting.
If you haven't already,can you find a way to tie this area into the central spine.
Old Feb 10, 2013, 01:04 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
I'ts glued onto the central rib, which is reinfored with 2 metal strips.
Let's hope this is enough
Old Feb 17, 2013, 02:37 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Hi there,
finished the fuselage today.
Motor and ESC locked in place, both catching a good deal of air for good cooling.
Next step will be the fences, the winglets, painting, ...
Vincent
Old Feb 17, 2013, 02:56 PM
Stupot46's Avatar
Joined Sep 2011
Very nice.Bit of a cliche,but it's a shame to cover that neat woodwork
Old Feb 24, 2013, 02:20 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Fences ready, located at about 1/2 and 2/3 of half wing span.
First one aligned with flap/aileron split.
Fences higher compared to the 2 fences on the FZ3-PT, in order to be sure they have a functional fence effect.
Later some better pictures ...
Discussion Flying wing with landing gear vincent123 Flying Wings 24 Feb 04, 2013 02:18 AM
Discussion 47" WS Flying Wing with Landing Gear villapilote Flying Wings 10 Oct 20, 2012 04:28 PM
Discussion Scratch build flying wing with landing gear vincent123 Flying Wings 3 Aug 22, 2012 12:27 PM
For Sale Flying Robot 550 frame with pan landing gear + multiwii Warthox board. airbagit13 Aircraft - Electric - Multirotor (FS/W) 7 Apr 18, 2012 01:47 PM
