Old Jan 19, 2013, 12:55 PM
vincent123 is online now
Find More Posts by vincent123
InceCreations
vincent123's Avatar
Joined Jul 2009
Bye bye reciever
Topside sheeted.
Reciever and battery alarm put inside the wing.
vincent123 is online now Find More Posts by vincent123
Old Jan 19, 2013, 03:25 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Neat work!Quite a lot of wiring-not my favourite job
Stuart A is offline Find More Posts by Stuart A
Old Jan 20, 2013, 02:12 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
You are not alone, got 9 servo leads, and they weight up, also.
Old Jan 21, 2013, 12:15 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
FZ3 build: top and bottom view
Ready for the ailerons and flaps to cut out.
Plastic window for the battery alarm readout.
Reciever bind connector button can still be pressed
Old Jan 22, 2013, 01:31 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Nice work on the planking!
You may find it easier to bend the sheeting over the l/e if you make the sheeting run parallel to the wing out line and have a tapered fillet between them.The first pic is a sheet I made up for the plank,you can see what I mean better on the other one.
Stuart
Old Jan 22, 2013, 02:16 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Hey, that's a nice tip!
This time i had no problems with the bending, as the balsa is only 1mm thick.
I indeed had some difficulties with the FZ2 planking back then.
Any tips for covering my wing?
My first idea was to glass it with 25gr/m2, but this will add another 100grams to it. Since i'm aiming at 12.5 oz/ft3 cubic wing loading, i'm turning towards blue transparant oracover. Lighter and leaves the wood grain visible ....
My power setup is a 6cell, het rc 2w-30, 80amp: good for 1800gr push for 1450gr plane.
Old Jan 22, 2013, 02:34 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
I'm probably not the best to ask about covering,a tissue and dope kinda guy
If nobody else comes in on here,post a Q on balsa builders and/ or builders workshop.I'm sure they'll have lots of advice to offer.
Old Jan 27, 2013, 02:53 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
FZ3 build: Flaps and Ailerons
The flaps and ailerons took longer than I thought.
The horns, which I made for the first time out of wood, in order to keep the top face of the wing clean, took a while !
All in all, pretty happy with the result.
The bottom gap/split is only 1mm, my best yet.
Old Jan 27, 2013, 03:19 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Nice clean work,looks really good.Ply horns?
Old Jan 27, 2013, 04:21 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Yes, ply 2mm thick.
Old Jan 27, 2013, 05:18 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Originally Posted by vincent123 View Post
Yes, ply 2mm thick.
A drop of thin c/a in the holes will harden the ply,reduce any chance of wear.
Old Jan 27, 2013, 06:31 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Beautiful bird; it's a flying wing, made of wood, and it can ROG (I love the way you integrated the tips as landing gear)!
Fly Wheel is offline Find More Posts by Fly Wheel
Old Jan 28, 2013, 11:42 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Yeah, it requires a nice fast ground speed, before i takes off
Old Jan 28, 2013, 11:43 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Which holes do you mean, the control wire holes?
Old Jan 28, 2013, 01:25 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Another question, the plane is getting heavier than i first calculated.
Therefore, i need your opinions here: is a flying wing of 13.2 oz/ft3 cubic wing loading and 21 oz/ft2 wing loading, considered as a heavy wing, normal wing or in between ?
I still have one choice here, or epoxy sheeting and painting for superior finish adding 120-150gr (resulting in 13,2 cubic) or oracovering good for 24 gr (resulting in 12,2cubic)
Power/weight ratio is 1.17.
Discussion Flying wing with landing gear vincent123 Flying Wings 24 Feb 04, 2013 02:18 AM
Discussion 47" WS Flying Wing with Landing Gear villapilote Flying Wings 10 Oct 20, 2012 04:28 PM
Discussion Scratch build flying wing with landing gear vincent123 Flying Wings 3 Aug 22, 2012 12:27 PM
For Sale Flying Robot 550 frame with pan landing gear + multiwii Warthox board. airbagit13 Aircraft - Electric - Multirotor (FS/W) 7 Apr 18, 2012 01:47 PM
