Old Nov 03, 2012, 11:52 AM
amxen is offline
Find More Posts by amxen
United Kingdom, England, Keighley
Joined Nov 2009
fowler flap hings
hi there im building a TF 62" p-47 and want to do the flap hing scale. dose any one make a fowler hing thank will work with this kit . not the robart ones
thanks Mick
amxen is offline Find More Posts by amxen
Old Nov 03, 2012, 12:18 PM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
As you're aware,Fowler flaps increase wing area,as well as lift/drag.
I recently built a Lockheed Constellation ,and at 1/11th scale,they moved approximately 4 inches.
I don't know of any flap hinges that replicate the Fowlers exactly...but some folks are using a hinge set-up that locates the hinge pin far below the lower surface of the wing.It looks kinda,sorta scale,but leaves a lot to be desired.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: "Everything OLD is New...
Old Nov 03, 2012, 01:21 PM
amxen is offline
Joined Nov 2009
yer not really what im after. a nice scale look and movement is what im after. i think i may have to make my own
Old Nov 03, 2012, 01:59 PM
epoxyearl's Avatar
Joined Oct 2011
I may be able to find my drawings,but I'm not familiar with the Jug's design...Don't be in a hurry-I'm sure someone will come through with what you need..
We need to find scale drawings first....do you have a Squadron/Signal book ? That's your first need-they'll have scale drawings to work from.
Old Nov 03, 2012, 02:26 PM
amxen is offline
Joined Nov 2009
dont think im in any hurry its taken 2 months to do the vertical stab and the ruder. scale takes alot of time lol
Old Nov 03, 2012, 02:28 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
How about this video -
Fowler Flaps Meister scale P47 Test (0 min 14 sec)
eflightray is offline Find More Posts by eflightray
Old Nov 03, 2012, 02:31 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Or even - Robart Fowler Flap Hinge 1/5 Scale
A Google on P-47 Fowler Flaps pulls up quite a lot of information, full size and models.
Old Nov 03, 2012, 02:52 PM
amxen is offline
Joined Nov 2009
Originally Posted by eflightray View Post
this look interesting just need to try and get hold of him
Old Nov 06, 2012, 03:45 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
If it is scale you're after, then Fowler flaps are not appropriate to the P-47. It used Slotted flaps, not Fowlers. That's good news for you, because the Slotted flap mechanism is simple: an opening hinge on the underside allowing an arc deployment. I don't know the TF ARF, but it is probably set up as a simple flap. You can easily modify this to a semi-slotted design by (1) modifying the LE of the flap so that it resembles the LE of a wing and (2) adding a thin strip across the top of the wing TE so that it shields the flap when closed. When open, it creates the slot which directs air up and over the flap.
This type of flap is the second most efficient after fowlers for creating lift (as noted, the fowler actually adds wing area). The Slotted increases lift coefficient 100% in the area of the wing it is located, as compared to 80% for Split flaps and 60% for plain flaps. Slotted flaps require maximum deflection for highest lift of 40deg. - efficiency drop beyond that. Optimal flap size is 25-30% of chord. The slot is most efficient at no more than 5% of flap chord. This last requirement is important: a bigger gap will cause the wing to lose substantial lift.
TTRotary is offline Find More Posts by TTRotary
Old Nov 06, 2012, 03:59 PM
epoxyearl's Avatar
Joined Oct 2011
You come here for information,you'll get it...TTrotary-thank you for the information you've supplied...
A question has been cleared up(in my case at least)..
Old Nov 07, 2012, 12:34 AM
TTRotary is offline
Joined Mar 2010
Always glad to share what I've learned
Old Nov 07, 2012, 09:35 PM
CurtissP40 is offline
Find More Posts by CurtissP40
Bona Fide Cub Nut
CurtissP40's Avatar
Northwest Oregon
Joined Jan 2006
Originally Posted by TTRotary View Post
... Slotted flaps ...
TT:
I am not familiar with slotted flaps. Since I'm very much a visual / pictures kind of guy, any chance you could post a drawing or photo?
TIA
CurtissP40 is offline Find More Posts by CurtissP40
Old Nov 07, 2012, 11:22 PM
Chad Veich is online now
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
You got your work cut out for you, particularly at 1/8 scale.
Chad Veich is online now Find More Posts by Chad Veich
Old Nov 08, 2012, 03:21 PM
TTRotary is offline
Joined Mar 2010
Originally Posted by CurtissP40 View Post
TT:
TIA
You probably are: every jetliner has them. Chad's pics are a perfect illustration. If you're not as concerned with scale, hatch hinges make this work very well.
Old Nov 10, 2012, 05:07 AM
amxen is offline
Joined Nov 2009
You have restored my enthusiasm for doing this now. As I was told the Fowler flap is plagued. With slop problems. As it's not a fowler flap I'm sure it's workable
Sold Control Horns & Flap Hinges iflytailies Aircraft - General - Miscellaneous (FS/W) 0 May 05, 2012 11:04 PM
Question Missing flaps hinges in fun cub kit spencer1 Parkflyers 6 Apr 30, 2012 09:11 PM
Question Bottom Hinging Flaps RCTodd The Builders Workshop 19 Apr 14, 2012 03:09 PM
Wanted Wanted - Hobby Lobby - Fowler Flap Hinges mrmach5 Aircraft - General - Miscellaneous (FS/W) 4 Jan 14, 2012 09:35 PM
Fowler hinges dumbdidgits Non R/C Items (FS/W) 5 Dec 10, 2009 09:57 PM
