Old Nov 03, 2012, 06:01 AM
vincent123 is offline
Find More Posts by vincent123
InceCreations
vincent123's Avatar
Joined Jul 2009
Flying wing with landing gear
Finished the prototype: http://www.rcgroups.com/forums/member.php?u=271334
Before building the FZ3, i decided to build a prototype first, as there will be a few differences with the FZ2.
The PT is build from 3mm depron, glas covered and painted wih "RC colors", 4w HET motor, 3cell. Sizing of the PT is made as such, so that the cubic wing loading is the same as for the original FZ3. Aileron and flap are resized in order to have a representative flying experience as would be with the FZ3.
I simplyfied the front wheel, it's more like a skid, not streerable, just to find out if it is possile to take off with this odd setup (cg in the center of the 3 "feet" and the winglets-feet being far behind the cg).
I made some attempts to make the skid a retract with a servo, but the forces are huge during takeoff, the frontskid itself and also the servo broke on several occasions. Decided to have a front skid without retract. This turned out fine, the wing has to make a nice speed, before it's able to takeoff. This is due to the odd setup, the wing cannot be tilted to catch more air. The skids are designed to have the wing at an angle of attack of 6° during takeoff.
Having 30° of sweep, with winglets upside down, showed me that the wing is stall prone at low speeds, especially during landing: the ailerons lack authority at low speed. In order to keep the design clean, I decided not to add top winglets, but installed fences instead. These should be a able to limit the spanwise crossflow, which induces the stall behavior. Yet to see if this change turns out as expected.
vincent123 is offline Find More Posts by vincent123
Old Nov 03, 2012, 10:04 PM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
Seems to me that the winglets could be shorter, or moved upwards, so that the AOA on takeoff would be increased.
Also, some washout on the wing would slow down the stall speed.
djacob7 is offline Find More Posts by djacob7
Old Nov 04, 2012, 01:52 AM
InceCreations
vincent123's Avatar
Joined Jul 2009
Yes, first i tried to have less clearance between prop and gras, but then i had a fast lawnmower
So now the clearance is 30mm.
I ll try washout the next time
Vincent
Old Nov 04, 2012, 06:02 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
How about trying C shaped wire skids.The spring in the wire may save the servo,and they shouldn't effect the handling?Washout sounds a good idea.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Nov 04, 2012, 08:03 AM
Murman is online now
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Other than having something different, why do you want landing gear on your wing? Without a rudder, you have no way to steer the wing while taking off. I've had many wings over the years, and the only reason I could see for landing gear is when I didn't have a clear, smooth place to land other than pavement which would damage the wing. I have attached small skids to some of my wings so I can land on pavement without damaging the motor, or the wing itself.
Murman is online now Find More Posts by Murman
Old Nov 04, 2012, 12:46 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
The plane runs in a fair straight line before taking off, although it indeed tends to bend to the left, but that's ok.
The PT is a Prototype for the wing i'm planning to build, the FZ3.
It'll be double the weight and tripple the power, it will be hard to hand throw it, so that's why, and besides that, it's just cool to takeoff from a runway
Old Nov 06, 2012, 12:36 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Looking great! I'd probably try to keep the gear smaller, can it fold in?
PHMX is offline Find More Posts by PHMX
Old Nov 06, 2012, 10:08 AM
Remko is offline
Find More Posts by Remko
New in the game
Remko's Avatar
Nederland, ZH, Capelle aan den IJssel
Joined Feb 2011
Look at the first picture...!!!
Remko is offline Find More Posts by Remko
Old Nov 06, 2012, 01:46 PM
PHMX is offline
Joined Feb 2011
My bad, overlooked that one. Definitely a neat solution.
Old Nov 09, 2012, 11:26 AM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
very clever. This could be a great way to do fpv takeoffs with my wing, so I don't have to take off the goggles, throw it, climb, then put them on again.
baconflyer is offline Find More Posts by baconflyer
Old Nov 12, 2012, 02:36 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Finally, some footage of a takeoff.
Flying Wing With Landing Gear (1 min 48 sec)
Old Dec 29, 2012, 03:25 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
Starting the FZ3 build
Based on the FZ3-Prototype experience, the time has come to start the real thing.
Old Dec 29, 2012, 03:27 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
FZ3 build
Wing spars glued
Wing cut in 3 pieces for webbing spars.
Old Dec 29, 2012, 03:28 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
FZ3 build
Webbing spar leading and trailing edges.
Old Dec 29, 2012, 03:29 PM
InceCreations
vincent123's Avatar
Joined Jul 2009
FZ3 build
One wing-half ready for sheeting.
Wing will be sheeted with 1mm balsa and glassed (instead of only glassing).
V-Bat Flying Wing- Needs Landing Gear Ideas babenson Flying Wings 5 Nov 13, 2012 04:31 PM
Discussion 47" WS Flying Wing with Landing Gear villapilote Flying Wings 10 Oct 20, 2012 04:28 PM
Discussion Scratch build flying wing with landing gear vincent123 Flying Wings 3 Aug 22, 2012 12:27 PM
For Sale Flying Robot 550 frame with pan landing gear + multiwii Warthox board. airbagit13 Aircraft - Electric - Multirotor (FS/W) 7 Apr 18, 2012 01:47 PM
