Old Nov 05, 2012, 09:10 AM
2400RDR is online now
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
Thermals are where you find them
Or did someone already say that?
Rick
2400RDR is online now Find More Posts by 2400RDR
Old Nov 06, 2012, 06:05 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
on shape of thermals
i found this, providing data regarding the shape of thermals:
http://www.xcmag.com/2007/07/thermal...rt-1-thermals/
which looks very much the way cumulus nimbus behave
phil alvirez is offline Find More Posts by phil alvirez
Old Nov 06, 2012, 12:41 PM
jimmm3 is offline
Find More Posts by jimmm3
LSF IV
jimmm3's Avatar
USA, TX, Corinth
Joined Jan 2009
Originally Posted by DLGjunkyard View Post
Anyone know what kind of glider Joe is using in this video?
JimmyMac in Dallas
jimmm3 is offline Find More Posts by jimmm3
Old Nov 09, 2012, 06:31 AM
Joined Jul 2007
thermals and computer science
anything goes?
could it be that there is already technology to find out the shape of thermals, just as there is to track down storms in 3 dimensions? like by detecting small variations in temp or wind flow. just to learn for sure how they look.
sometimes comps do things that are beyond our wildest dreams, but others they don't some that look easy for us.
the other day i watched a documentary where a scientist in japan deviced a way to track down the shape of volcanos deep underground by using some sort of space radiation. so, why not?
for instance, i got a telemetry system that sends data from my plane about the voltage in the battery, that weighs 16 grams, and costs $50. i could not dream about anything like it.
the future is here, and we live beyond science-fiction.
Old Nov 09, 2012, 06:35 AM
Joined Jul 2007
shape?
Originally Posted by seanpcola View Post
If only I was up-to-date with my cell phone I could have made some awesome videos of thermals a couple of weeks ago. Had to drive over to a farming community. They're in a serious drought and the ground is extremely dry and dusty. You could watch them start small, build, move down wind, etc., even break loose and climb. Would have been a great tutorial.
ok, so we count on your description of them: could you see their shape? how it evolved? how they started? anything!
Old Nov 09, 2012, 06:51 AM
seanpcola is offline
Find More Posts by seanpcola
ein flugel schplinterizer
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
Oh yeah. Watching the ones in the plowed fields was simple and clearly defined.
First there was a small area of "disturbance", sort of a dust cloud maybe 5' high. As it fed you could see the dust being sucked into it and a circular pattern develop. .All the time it's moving downwind, gathering more warm air and the rotational speed picked up slowly Very defined tornado shape, IOWs as it gained height the upper part spread making the funnel. It looked like the circular speed was slower the higher it went but that was probably more a function of the larger diameter since the dust was actually moving a greater distance. As the funnel encountered a tree line it would break loose and continue to climb. On this particular day the thermals hit a certain altitude and obtain equilibrium. When that happened the rotation slowed or maybe stopped while the dust cloud continued downwind until either the air finally lost energy or went out of my line of sight.
Nothing unexpected just awesome to see in person.
seanpcola is offline Find More Posts by seanpcola
Old Nov 09, 2012, 07:20 AM
ronrange is offline
Find More Posts by ronrange
Joined Jan 2003
Unusual thermal
A rather unusual event involving thermals several years ago. A friend, Al Clark was flying a S Tee equipped with a drop mechnism at the Redstone Arsenal. He had rigged a small plastic Rhino with a simple parachute to drop. When he dropped it from the plane it was caught in a thermal taking it upward and moving towards the SE. We watched in total amazement for quite a while as it moved off. It later reappeared coming back in a North Westerly direction and finally landing on the field some 20 minutes later.
We later went to the Glider field about a mile away where the pilots were complaining about the lack of thermal. You figure that one!
If I had not witnessed this myself I would have doubts, but it is absolutely true.
Sworn to by:
Ron
Al told me I was off on the time and that it was actually 32 minutes. I will allow that his memory is better than mine.
ronrange is offline Find More Posts by ronrange
Old Nov 09, 2012, 08:03 AM
glidermang is online now
Find More Posts by glidermang
What I know about thermals could hardly fill a bottle cap.
What I have observed is this: thermals can be:
Either wide or narrow
Either "soft" (ill-defined, mushy) or "hard" (definite boundaries)
Either singular or multiple (several feeders to a larger, higher thermal)
Either low-starting or high starting (you have to be high to find the lift)
Either topping out low or topping out high
Either stationary or moving
Either stable or transitory
In my experience, a thermal that appears to be non-circular is usually part of a family of small, feeder thermals pushing a bigger one (usually higher - keep working to get into it).
On any given day, at any given field, my first flights are to gage the thermals (wide/soft/low/etc.) All subsequent flights are input for re-evaluation of what's going on (they seem to be getting higher, that sort of thing).
In all my RC soaring so far, I estimate that about 0.01% has been in conditions of flat thermal activity, without perceptible convection. Even if there is not lift to climb in, there are usually bumps and bubbles that can prolong flight.
I am always amazed at how tenascious many folks are at circling in sink. What I hear them say as they do so is usually something like "there was lift here yesterday! I remember! I just need to work it better!" Sorry, guys, but if your airplane is not climbing, you should leave the area.
Another post earlier hit about right: the best thermals come when your batteries are low, your airplane is in the car, the winch is broke, and you'd have to circle directly in the sun anyway.
Good luck!
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Nov 09, 2012, 08:39 AM
Joined Jul 2007
thermals: the making
terrific. thank you very much. this 1st hand input is a milestone and contributes largely to our learning on thermals. i wish i could watch it!
1 last question? do you remember which way was it turning? left or right?
regards
Old Nov 09, 2012, 04:50 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
My first thermal was when I was in Jr High (A.K.A. "middle") school. Not RC but paper airplanes (budget free flight? ). Anyway, our little club was in the "girl's field", which is a large asphalt area. I waited until the air was calm then threw my plane straight up for altitude. I knew nothing about the characteristics of thermals back then other than they were rising masses of warm air., But as soon as I saw that the slowly circling plane was not coming down, but going up I knew what I had. I had thrown it right into the core. With no imput from me (obviously) it just kept circling upwards, and slowly drifting southeast with the "bubble" until it was lost from sight.
I was on cloud nine the rest of the day.
Fly Wheel is offline Find More Posts by Fly Wheel
Old Nov 09, 2012, 06:36 PM
Joined Jul 2007
treasures...
great to have experiences like that. and you will bring those memories time and again.
and here i come again: do you remember which way was it turning?
am really curious about which way thermals turn.
Old Nov 09, 2012, 07:27 PM
StevenatorLTFO is offline
Find More Posts by StevenatorLTFO
AKA - The "Flywheel"
StevenatorLTFO's Avatar
SOAR Chicago!!!
Joined Jan 2005
A couple of years back, I was driving to work, it was early fall, and the farmers were harvesting corn. I saw a thermal start, as a dust devil, sucking up corn leaves, and soon, it grew to over a half mile wide, and the corn leaves were very high, easily a thousand feet or more. During this episode, a half dozen or so vultures ventured into the area, and they climbed out like they had rockets attached to them. It was the most awesome visual display I have ever seen, of a thermal, and its power.
Steve
StevenatorLTFO is offline Find More Posts by StevenatorLTFO
Old Nov 09, 2012, 08:00 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
Phil,
The thermals on the day that I described were turning counter-clockwise as viewed from above if that helps.
Old Nov 09, 2012, 08:11 PM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
A Whirlwind Hay Devil For Kids (2 min 39 sec)
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Nov 09, 2012, 08:12 PM
Joined Apr 2010
Tornado (Giant Dust Devil) Forming In The Middle Of Soccer Field (1 min 11 sec)
Discussion Do you know what airplane is this and who made it? mashca The Builders Workshop 5 Sep 11, 2012 07:05 PM
Question How do you know what part is bad? j2591 Micro Helis 5 Aug 13, 2012 07:39 PM
Discussion Do you know what this is? jaizon Thermal 3 Jul 22, 2012 02:09 PM
Wanted do you know what plane this is ? streetbikegod4 Aircraft - Electric - Airplanes (FS/W) 5 Mar 18, 2012 08:41 AM
Discussion Catching a thermal, whats it like, how do you know? what should you do? GreenAce92 Thermal 25 Mar 11, 2009 05:21 PM
