Old Nov 03, 2012, 05:00 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
THERMALS: what do you know?
this is for beginners or experts alike:
if we are in this forum, what do you know about them?
their shape; how they are generated, how they evolve; if they turn;
and if so, if they turn in certain direction (left, right);
how do you get into them;
how do you detect them;
links;
your experience;
examples of how you get into them.
please bring only polite and positive comments.
phil alvirez is offline Find More Posts by phil alvirez
Old Nov 03, 2012, 05:02 AM
Joined Jul 2007
shape of thermals
an example:
have you wondered what shape a thermal has? a bubble? a cylinder?
i found an article in a model airplane's magazine (american modeler-august 1961-page 42), where the author (Bill Winter) provides a link on the thermals shape and behaviour, from an article from Soaring magazine, by Clarence Cone, issues april/may/june 1961.
this is the link: http://soaringweb.org/Soaring_Index/...61_Apr_08.html page 8.
edit: somehow the link does not work anymore. will try to bring it back.
Old Nov 03, 2012, 06:27 AM
Wylie Shaw is offline
Find More Posts by Wylie Shaw
Clearlake, CA. USA
Joined Jun 2000
They go up!!!!!!
Wylie Shaw is offline Find More Posts by Wylie Shaw
Old Nov 03, 2012, 08:15 AM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Thermals can be shaped like bubbles, smoke rings, tornadic (dust devils) ... the only way to tell is to get into it and fly in the rising air.
tkallev is offline Find More Posts by tkallev
Old Nov 03, 2012, 11:30 AM
ciurpita is offline
Find More Posts by ciurpita
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
the sun heats the ground which heats the air near the ground. Darker ground cover heats more quickly.
eventually the heated air breaks from the ground and rises.
as it rises it cools, but continues to rise as long as the surrounding air is cooler than the rising air. see lapse rate and soaring weather forecast.
See Lee Murrays article in the September '99 issue of RCSD.
When thermals rise, air flows under them to fill the vacuum they form. Should you fly with or against a sudden breeze formed by a thermal?
when/if the air cools to the dew point of the surrounding air, the water condenses and forms clouds.
clouds with flat or concave bottoms are good indicators of thermals. multiple thermals may join under a single cloud.
ciurpita is offline Find More Posts by ciurpita
Old Nov 03, 2012, 02:37 PM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
Many thermals are in the shape of sea weed in that they sway with the wind and often feed from the ground. Its actually more likely than the bubble example often used .
Sink will often be found around the perimeter but more likely around the base.
Flying full size has taught me that there really is no consistent shape from one thermal to the other Thermals come in many shapes, sizes and textures. Some thermals are too small to circle in, while others can be so huge that you have to try to find your way out of them. Some are just strong enough to maintain your altitude, while others take you up so fast it can be disconcerting.
DLGjunkyard is online now Find More Posts by DLGjunkyard
Old Nov 03, 2012, 04:17 PM
seanpcola is offline
Find More Posts by seanpcola
ein flugel schplinterizer
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
If only I was up-to-date with my cell phone I could have made some awesome videos of thermals a couple of weeks ago. Had to drive over to a farming community. They're in a serious drought and the ground is extremely dry and dusty. You could watch them start small, build, move down wind, etc., even break loose and climb. Would have been a great tutorial.
seanpcola is offline Find More Posts by seanpcola
Old Nov 03, 2012, 04:21 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
For small thermals, you could probably release dust, milkweed seeds, soap bubbles, etc. into them and get some idea of the shape. Or just wait for a dust devil, but they might not be typical. Thornburg recommends, among other things, making little parachutes out of dry cleaner bags and releasing those to visualize what lift is doing.
If you see a flock of small birds randomly flying around in a small area, a good distance off the ground (say, 50 feet or more), they are probably eating bugs carried upwards by a thermal. You can also find thermals by watching for larger birds circling further up (as long as they aren't flapping). I've done this many times. Also, if you find a thermal, they'll often come to you.
A quick wind shift often means the thermal is close, a slower shift means further away, or perhaps just larger. Obviously a wind shift that feels warm is better than one that feels cold. The prevailing wind affects the perceived vs. real direction of a thermal. The thermal may be a bit downwind (by the prevailing wind) of where the shift points to. Also, the top of a thermal is often downwind of the bottom of it, since the wind gets stronger aloft.
Mostly I find thermals by noticing that the glider gets lively.
I think the turning direction is fairly random, and there seems to be some advantage, sometimes, circling in one direction instead of the other, presumably against the direction the thermal is spinning, so you don't have to bank as much.
lincoln is offline Find More Posts by lincoln
Old Nov 03, 2012, 04:27 PM
War is Peace is offline
Find More Posts by War is Peace
Enemy of the State
War is Peace's Avatar
Joined Mar 2012
From many years of flying I have learned the following thermal facts:
The best lift is always directly in the sun where you can't see the model.
The best thermal of the day happens shortly after you put your glider in the car.
Birds always show the location of a thermal when you are too low to get there.
The winch always breaks down when its your turn to launch into the "hat sucker" everyone is flying away in.
And..... when you finally catch the ultimate monster thermal, your transmitter will be running low on batteries and you will have to pull out and land.
I do know this: thermals are invisible, they move, and they usually evade us. But it takes only one good thermal to hook you for life.
War is Peace is offline Find More Posts by War is Peace
Old Nov 03, 2012, 04:34 PM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
Enough said. Scott is 100% on every comment here.
Old Nov 03, 2012, 07:01 PM
LVsoaring is offline
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
That, my friends, is absolutely true, and is the common glue that binds us here all together. There's not a one of us here who can forget hooking that first one, and when you landed, wanted nothing more than to do it again.
LVsoaring is offline Find More Posts by LVsoaring
Old Nov 04, 2012, 09:32 AM
Tappet is offline
Find More Posts by Tappet
Crestview, Florida
Joined Dec 2005
Search "Joe Wurts" on YouTube and watch the first video that comes up.
Almost an hour long.
Tappet is offline Find More Posts by Tappet
Old Nov 04, 2012, 11:01 AM
Joined Apr 2010
Joe Wurts on soaring (1 hr 22 min 27 sec)
Old Nov 04, 2012, 05:16 PM
jetmaven is offline
Find More Posts by jetmaven
What I know about thermals is that they were few and far between in my part of central Florida today
jetmaven is offline Find More Posts by jetmaven
Old Nov 04, 2012, 05:30 PM
Soarmark is online now
Find More Posts by Soarmark
Mark LSF # 3792
United States, TX, Garland
Joined Nov 2008
Well there were many here in Texas today! And I can say each one was different. Doughnuts, cylinders, broad fields you name it.
BTW, Jimmy Mac made his two hour for LSF today. As soon as I decided to start a two hour clock 46 minutes into a flight I fell out of the sky.
Still had a great time with temps in the 70's and multiple low level saves with my Perfect. I love this hobby, better than golf or fishing and probably more challenging.
Soarmark is online now Find More Posts by Soarmark
Discussion Do you know what airplane is this and who made it? mashca The Builders Workshop 5 Sep 11, 2012 07:05 PM
Question How do you know what part is bad? j2591 Micro Helis 5 Aug 13, 2012 07:39 PM
Discussion Do you know what this is? jaizon Thermal 3 Jul 22, 2012 02:09 PM
Wanted do you know what plane this is ? streetbikegod4 Aircraft - Electric - Airplanes (FS/W) 5 Mar 18, 2012 08:41 AM
Discussion Catching a thermal, whats it like, how do you know? what should you do? GreenAce92 Thermal 25 Mar 11, 2009 05:21 PM
