Old Dec 09, 2012, 03:08 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
I have this working however, I am unable to set the right PPM order. Any suggestions?
rimshotcopter is online now Find More Posts by rimshotcopter
Old Dec 09, 2012, 03:24 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
I don't think it's possible with this converter since it just repeats the channels as the Rx outputs them. Is it possible to change the PPM ordering in your FC?
brontide is offline Find More Posts by brontide
Old Dec 09, 2012, 03:31 PM
Joined Aug 2009
I am trying to do that now. I also tried moving the pins around on the RX and that did not work.
Old Dec 09, 2012, 03:41 PM
Joined Aug 2009
Worked it out with the following patch to the MWC RX.ino file and this PPM order.
http://www.multiwii.com/forum/viewto...M+order#p27568
Code:
#define SERIAL_SUM_PPM POLL,THROTTLE,PITCH,YAW,AUX1,AUX2,AUX3,AUX4
Old Dec 09, 2012, 03:42 PM
brontide is offline
Joined Sep 2012
If you are using the KK2, be careful since some versions of the firmware the CPPM editor is wrong! Two of the labels are reversed.
Old Dec 09, 2012, 03:51 PM
Joined Aug 2009
Thank you Brontide.
Old Dec 09, 2012, 04:24 PM
danger_mouse is offline
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
With the std Turnigy 9x v2 radios, it seems that some of the v2 6ch rx's have ppm sum on bat port.
danger_mouse is offline Find More Posts by danger_mouse
Old Dec 09, 2012, 04:30 PM
Joined Aug 2009
They SURE DID, but I purchased three recently and they no longer have the PPM on the Battery. WTH!!!
Old Dec 09, 2012, 07:13 PM
Joined Jan 2007
Progress lol.
I need to check mine, must have 5 or 6 of the 6 ch rx's that I've had for a year or more. Might come in very handy for a project.
With your PPM converter did you manage a way to implement a failsafe?
Old Dec 09, 2012, 07:17 PM
Joined Aug 2009
Progress lol.
Preliminary testing shows the signal stops outputting and the throttle goes to 1ms. For my copters, this is fair enough for testing however, I would love to get a better failsafe working. In fact, I am looking over the code at present, trying to gain a better understanding of how it works.
Very clever program I have to say.
It just came to me, to get the WMC's failsafe to kick in, all that is required is to turn off pin 7. That should be fairly easy to do if there is no signal from X amount of time.
Old Dec 19, 2012, 10:04 AM
Joined Aug 2009
Please forgive my OLD oscilloscope here.
Here is the problem that I am having, the attached photos show the PPM output using the current unmodified firmware. When the transmitter is turned off, there is still a PPM stream and because of this, the MWC failsafe will not engage. The RX is a Turnigy 9xBC version 2.
Old Dec 19, 2012, 02:23 PM
Joined Aug 2009
Found the freaking problem, on the Turnigy 9xBC version 2, when the RX looses signal, Channels Four and Channels five STILL output a signal. 1400-1500 Channel 4 and 1000-1024 Channel 5.
Old Dec 26, 2012, 05:12 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
What you describe is particular for 9X RF system, and is one of his main weakness, but the general behavior of ALL 2.4Ghz systems is to output something on ALL channels when Tx is off.
There are two cases:
- hold last command
- programmable positions = failsafe.
renatoa is online now Find More Posts by renatoa
Old Dec 26, 2012, 08:40 PM
Joined Aug 2009
Yea, the 9XBC is really aggravating because unlike the Flysky 6 channel version(without the PPM on the battery pin), channels 4 and 5 still outputs upon signal lost where as the 6 channels shuts down completely. Makes it really easy for a PWM to PPM encoding. I am in the process of adding a Mask to the code now, just wish I understood more about Interrupts routines on the arduino. I have set this project aside for a moment and used one of the six channels RXs I have on-hand to get the VTOL flying. Will return to this later because I will need the additional channels.
Old Sep 28, 2013, 08:05 PM
doughboy is offline
Find More Posts by doughboy
Joined Jul 2012
used this for almost a year now with no problems.
really make use of all 8 channels on any atmeg328 based board instead of limiting yourself to 6 channels.
just got a neo6m, price is so low now compared to last year. I am combining the i2c_nav_gps program with my ppmsum program on a pro mini.
to answer some of the earlier questions, you can connect all 8 channels to the atmega328 (or pro mini) in any order. The software does not care about the pin position, it simply multiplex the pulse coming in from any of the 8 channels to the output pin. You only need to make sure the ppmsum definition on multiwii config.h matches your turnigy transmitter setting.
doughboy is offline Find More Posts by doughboy
Mini-HowTo DIY Servo Signal (PWM) to PPM Converter rich smith DIY Electronics 179 Dec 05, 2012 12:40 PM
Sold Serializer PWM-PPM converter -8 channel -$30 shipped CONUS Mactadpole Aircraft - Electric - Multirotor (FS/W) 2 Mar 18, 2012 11:38 AM
Mini-HowTo PIC 10f202 pwm to ppm converter (BL-converter) Cesco DIY Electronics 15 Apr 01, 2011 04:29 AM
Mini-HowTo Motor PWM to PPM impulse converter quax DIY Electronics 27 Jun 16, 2008 11:38 PM
