Old Nov 03, 2012, 12:08 AM
doughboy is offline
Find More Posts by doughboy
Joined Jul 2012
Mini-HowTo
Convert your PWM RX to PPM
I needed to use all 8 channels on my Turnigy RX but my 328 based FC can accept only 6 channels, so I added a circuit to convert the 8 channel PWM into a Serial Sum PPM signal.
The circuit consists only of an atMega328 chip with a simple 20 line program. Chip is running using internal oscillator at 8mhz. I added the FTDI header so I can reprogram if needed and also serves as servo connector to FC PPM input. You can buy atmega328 on ebay for $3.33.
The atmega328 chip/prototype board attaches to the side of the RX
This is the logic analyzer capture for 4 channels. I used a pulse width of 300us (this screen shot still shows 200us)
Works great. Now I have 5 extra pins on my FC.
This is the program. 20 lines long not counting comments. Compiles to 566 bytes.
Code:
#define PPMHI PORTD |= _BV(7);
#define PPMLO PORTD &= ~_BV(7);
//written by doughboy @RCGroups and @multiwii.com
//8 channel Serial Sum PPM using atmega328 minimal circuit running on 8mhz internal oscillator
//wiring
//connect RX pins 0-7 to atmega PortB pins 0-7, chip pins 14 to 19, 10 and 11
//ppm output on digital pin 7, atmega chip pin 13
//            PC6  1|    |28  PC5
//            PD0  2|    |27  PC4
//            PD1  3|    |26  PC3
//            PD2  4|    |25  PC2
//            PD3  5|    |24  PC1
//            PD4  6|    |23  PC0
//      +5v-> VCC  7|    |22  GND  <-Gnd
//      Gnd-> GND  8|    |21  AREF
//      RX6-> PB6  9|    |20  AVCC <-+5v
//      RX7-> PB7 10|    |19  PB5 <-RX5
//            PD5 11|    |18  PB4 <-RX4
//            PD6 12|    |17  PB3 <-RX3
//   PPMSUM<- PD7 13|    |16  PB2 <-RX2
//      RX0-> PB0 14|    |15  PB1 <-RX1
//this code will run only on minimal 8mhz atmega328.
//you must modify the code and move PB6 and PB7 to another port if you use a setup with oscillator
void setup() {
  PCICR |= (1<<PCIE0); //Pin Change Interrupt 0
  PCMSK0 = 0xFF; //all 8 pins
  TCCR2A = 0;
  TCCR2B |= (1<<CS22) | (1<<CS20); //div 128 prescaler
  TIMSK2 |=(1<<OCIE2B);
  DDRD |= _BV(7);  //digital pin 7 output
void loop() {
ISR(PCINT0_vect) {
    PPMHI;
    TCNT2=0;
    OCR2B=19; //300us PPM pulse
ISR(TIMER2_COMPB_vect) {
  PPMLO;
doughboy is offline Find More Posts by doughboy
Old Nov 03, 2012, 06:45 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Don't work for any receiver, most brand digital RC systems pulses two or even more channels simultaneously.
A hint to make wiring even streamline, but only for receivers having no channel delimiter strips, and same vertical and horizontal spacing between pins: use servo leads to get 3 channels signals in a single plug/cable. With three servo leads you can get 7 channels, one of them plugged normal to get power for your board, and another two plugged twisted at 90 degrees, to get signals only.
renatoa is online now Find More Posts by renatoa
Old Nov 03, 2012, 10:49 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Have you put a trace on the Rx board, with the pwm broken out so nicely I wonder if its on the board somewhere.
brontide is offline Find More Posts by brontide
Old Nov 03, 2012, 01:57 PM
doughboy is offline
Joined Jul 2012
thanks. I would think most receivers would make the pwm pulse one right after another. Or is that not the normal case? That was my understanding of the PWM frame specs. 20ms frame divide by 8 channels gives you a max pulse of 2500us per channel.
As for wiring, I leave that up to the user how to wire it. On Turnigy 9X, there is a plastic border betweeen channels 5 and 6 (see the picture above), so that defeats the purpose of using servo connectors. Using individual pins allow a little more flexibility, in case the TX cannot rearrange channels.
As to finding if there is a PPM signal inside the receiver, I thought of it but never actually got around to do it. The idea for using atmega328 is I plan to add a serial GPS to I2C converter and support for up to 5 ultrasonic sensors (front, left, right, rear and bottom) and output data via I2C.
Old Nov 03, 2012, 02:43 PM
jab is online now
jab
Find More Posts by jab
jab
Unregistered User
Joined Aug 2007
If only.. You will find pretty much any output sequence imaginable as you start testing different receivers and brands.
jab is online now Find More Posts by jab
Old Nov 03, 2012, 03:07 PM
doughboy is offline
Joined Jul 2012
Ok. My first program was actually detecting each pwm pulse then serializing it to ppm. This way, it does not matter how the pwm pulses arrive. However, there is very little documentation to tell me otherwise, and whatever little documentation I found tells me the pulses are aligned one after another. So I modified / simplified the program down to 20 lines of code to take advantage of that fact. If your receiver outputs pulses one on top of each other, then you will need to modify the program to work with your receiver.
My motivation for building this is to serve my own needs and I simply shared the information, and it is not my intent to make this into a product that works with every receiver out there and make money out of it.
Old Nov 04, 2012, 09:08 AM
caotri is offline
Find More Posts by caotri
Hochiminh City
Joined Mar 2004
THis is a very simple and good converter . I used them for my Mk, and other FC also
http://lea.hamradio.si/~s56wix/pwm2ppm/
caotri is offline Find More Posts by caotri
Old Nov 04, 2012, 06:59 PM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
If you want to save the building time and have one with proper external clock, you can consider the ppm board from www.multircshop.com.
dt8666 is offline Find More Posts by dt8666
Old Nov 04, 2012, 07:29 PM
danger_mouse is offline
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
Or you could upgrade your 9x TX module to Frsky. The 6gram D4R-II 4 channel rx's output 8 channels in CPPM mode. You only need one wire from the RX to FC. As a benefit you get failsafe on all channels (unlike the std 9x rx's with no failsafe) and other useful features.
danger_mouse is offline Find More Posts by danger_mouse
Old Nov 04, 2012, 08:26 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Where is the spirit of DIY or can that be purchased too?
rimshotcopter is online now Find More Posts by rimshotcopter
Old Nov 04, 2012, 10:40 PM
Joined Jan 2007
LOL. Diy is all well and good, but I just would hate someone to have a flyaway due to the std turnigy 9x module/rx's with no failsafe.
Old Nov 05, 2012, 05:14 AM
brontide is offline
Joined Sep 2012
Hey, with a few more lines of code the chip can signal loss of signal to the FC or provide limited fs capability itself.
Old Nov 05, 2012, 05:22 AM
Joined Jan 2007
True, that could be a possibility. As you were.
Old Nov 05, 2012, 06:03 AM
Joined Aug 2009
+1 and the it could made to handle XBee and other protocols for example: SPEKTRUM
Old Dec 09, 2012, 11:55 AM
Joined Aug 2009
Here is a picture of my PWM RX to PPM Build. Now I need to fully ground test it.
I added two more pins in addition to the PPM pin for future expansion.
Mini-HowTo DIY Servo Signal (PWM) to PPM Converter rich smith DIY Electronics 179 Dec 05, 2012 12:40 PM
Sold Serializer PWM-PPM converter -8 channel -$30 shipped CONUS Mactadpole Aircraft - Electric - Multirotor (FS/W) 2 Mar 18, 2012 11:38 AM
Mini-HowTo PIC 10f202 pwm to ppm converter (BL-converter) Cesco DIY Electronics 15 Apr 01, 2011 04:29 AM
Mini-HowTo Motor PWM to PPM impulse converter quax DIY Electronics 27 Jun 16, 2008 11:38 PM
