This thread is privately moderated by unclegeorge, who may elect to delete unwanted replies.
Old Nov 02, 2012, 03:48 PM
unclegeorge is online now
Find More Posts by unclegeorge
Trader Rating: 251
United States, FL, Sarasota
Joined Feb 2005
Trader Rating: 251
For Sale
Close out on short arms for Throttle and Choke arms for Gas Engine Carbs.
Close out deal. Only short arms left due to manufactures mistake!
If you have ever struggled with trying to make a new arm for your throttle or choke on your gas engine carborator out of nose gear steering arms---Here finally is a solution!
Note that there is a difference in the height of each are so they can pass each other without any interferrence.
They are CNC machine of 6061-T6 Aluminum so they can be taped for a 4-40 ball or you can use a nylon clevis if you like for hook up.
These arms are build to slide on to the brass shafts on your carborator and are held in place with 2 set screws. I recommend that you file a flat on the shaft after determning what angle is best for hook up and then use thread lock on the set screws.
Specs:
1. CNC machined 6061-T6 aluminum in a brilliant red anodized finish.
2. Perfect for all carbs using standard 3/16" (0.1875") throttle and choke shafts.
3. May be drilled out for larger carbs using 7/32" (0.2187") throttle or choke shafts.
4. The multiple 1/16" arm holes located at 1/2", 3/4" and 1" provide mounting flexibility and changes in mechanical advantage.
Sold in pairs only. Only short arms left. Includes 4mm set screws
I sell them for $12.00 a pair plus $2.00 S&H by first class. Priority mail is now $6.00. Buy two pair for $20.00 (4 @ $5.00 each) plus $2.00 shipping!!!
Please give me your mailing address and please refer to the item you are buying in the “Subject line” along with your mailing address in your Pay Pal purchase. My account in Pay Pal is under uncgeorge@comcast.net
Uncle George
unclegeorge is online now Find More Posts by unclegeorge
For Sale Close out!!!Throttle and Choke small arms only for Gas Engine Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 3 Oct 29, 2012 04:15 PM
Sold NEW! Throttle and Choke arms for Gas Engine Carbs. unclegeorge Aircraft - General - Radio Equipment (FS/W) 0 Apr 06, 2012 02:14 PM
Sold Throttle and Choke arms for Gas Engine Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 29, 2012 04:46 PM
Sold Throttle and Choke arms for Gas Engine Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Mar 26, 2012 12:47 PM
Sold Throttle and Choke arms for Gas Engine Carbs. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Mar 15, 2012 09:57 PM
