Multi4 with NiZn -> bad cell count
Thanks, I missed the point to load the settings from the file menu. I was just looking in the presets drop-down section.
since my pack does not have balancing taps, I turned balancing off and also tried to set the cell count to 3 or auto. all I get is a "bad cell count error". do I have to add taps or is there something else I missed? (bat has 5.3V) thanks again in advance ingo |
Turning off the balancers in the preset does not preclude the charger from running the normal safety check which is to verify that the sum of the individual cell voltages equals the total. It knows that the pack is < 2s which is the maximum number of cells of this chemistry that the charger will charge unbalanced. Yes, if you want to use the Multi4, you will need to install a balance connector to the pack(s). This one: http://www.usastore.revolectrix.com/...-10-5-Position If you need to know how to wire it up, use this document and find the diagram for the configuration which matches the cell count of your battery pack: http://revolectrix.com/support_docs/item_1315.pdf Tim Marks |
Not sure what you mean. Can you illustrate with a screen capture or something? Tim Marks |
I had an unbalanced NiZn pack and would have liked to check the single cell voltages as I do with LiPo packs. since I added taps to the pack I was able to charge all cells one by one and the pack is now properly balanced but I don't understand why I can't use this screen feature with NiZn packs but on LiPo's? I hope the screen shots clarified what I meant. |
Not sure about that one. Why don't you go back to the default preset from the library that has balancing now that you have the balance connector added to you pack. I don't think you should get that error then?? Tim Marks |
| Thread Tools | |
| Discussion Cellpro Multi4: set Charge Voltage to 4.3 - 4.35v for LiIo | petekol | FMA Direct | 10 | Nov 17, 2012 02:34 AM |
| Sold Cellpro multi4 new in box | java8297 | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Sep 17, 2012 12:41 PM |
| Wanted FMA Charger, CellPro or Multi4 | Louierc | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Mar 29, 2012 10:06 PM |
| Discussion Help - Settings for NiMh batteries charging on Cellpro Multi4 | demiluk | Batteries and Chargers | 0 | Oct 28, 2011 03:55 PM |
| Discussion Cellpro Multi4 Battery pigtail | J3Flyer | Batteries and Chargers | 3 | Jan 18, 2010 12:29 PM |
