This thread is privately moderated by davidterrell80, who may elect to delete unwanted replies.
Old Nov 01, 2012, 07:58 PM
davidterrell80 is online now
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
Idea
Scaling up plans at home
Here's a round about way I just tried, successfully:
--Using a paper size scanner, scan the actual size, one section at a time. I was using a Peanut plan so, this was not too tough.
--In powerpoint, create a large slide (Design/page setup) the size of the original plan.
--Assemble the scanned pieces, without changing the actual size. You might have to set the white background to 'transparent' to get them to line up easily.
--Save the big picture as a PDF.
--Open the PDF in Adobe Reader X
--Print the file, Using the "Poster" setting and choose the tile scale of the desired scale up. I suggest adding the cut marks.
Hope this helps!
davidterrell80 is online now Find More Posts by davidterrell80
Latest blog entry: General Aircraft Skyfarer
Sold Plans, Plans, Plans, Plans, and More Plans! Scale, Classics, Pattern, & More! stevster Aircraft - General - Miscellaneous (FS/W) 31 Jul 17, 2016 07:56 PM
Question By what percentage would one blow up 1/12th scale plans to make them 1/10th scale Kcal Scale Boats 2 Sep 04, 2012 05:43 PM
Question Scaling up plans jfredmoran The Builders Workshop 57 May 12, 2012 09:48 PM
Discussion Printing plans at home? KMKAZE The Builders Workshop 8 Oct 05, 2009 05:04 PM
Went to pick up a new plane, came home with two at almost no extra cost! Zeroaltitude Sailplane Talk 6 May 23, 2004 04:31 PM
