Old Nov 11, 2012, 10:27 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
They use a pumper carb, so they do not use muffler pressure like they do with glow engines.
If the pump is working pretty good, you can place the fuel quite a ways away from the engine and it'll still work. Yeah that Torquemaster 1.80 should be able to do it, but I never tried one myself yet. I use a good pair of gloves, more to prevent the prop from cutting my hand and also to help take some of the sting out of a prop strike.
earlwb is offline Find More Posts by earlwb
Old Nov 11, 2012, 10:38 PM
Daravon is offline
Find More Posts by Daravon
TRB
United States, TX, Richardson
Joined Oct 2005
The Shindaiwa T2510 has a 4-cycle engine that runs on pre-mixed fuel. Nobody is probably going to gut a $400 weedeater for the motor, but it's interesting.
Daravon is offline Find More Posts by Daravon
Old Nov 12, 2012, 06:49 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I've been using a paint roller recently. Seems to work pretty good. I know it saved my fingers working on a rcgf20cc last week. I have a carb problem with it and got several back fires that would have hurt. Its next in line for the work bench.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Nov 12, 2012, 07:07 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Using a paint roller as a chicken stick is a pretty good idea.
Thanks for sharing that tip.
Actually when they started advertising that Fuji four stroke RC engine for $895, it does make it attractive to take apart a Shindaiwa to convert it for RC use. Even the Saito gas engines aren't all that inexpensive either. The Kolm and Rotomotor four strokes aren't inexpensive either. The Rotomotor four stroke is going for $775 at this time.
Old Nov 20, 2012, 09:07 PM
Nastagol is offline
Find More Posts by Nastagol
United States, TX, Haltom City
Joined Nov 2012
what plane fit with them
hey, actually my engine was really bad , it didn't even want to start so i cleaned the carb and put new gas lines and diaphragm, and adjust it, the hardest part was to adjust low rate and high rate screws, because they are pacman style, but i took a metal saw to make lines on them so i can adjust them with a flat screwdriver, anyway. but now i wonder, and i have seen that some people got the engine so light that they could even do 3d and aerobatic.. so what can i remove on that? , would it be wiser to remove the exhaust and put an rc one ? the other issue with it is , i would need a big prop because the engine is so big that it will hide most of wind created.. ..
questions:
can i remove enough weight so i could make aerobatic ?
if yes . what can i remove on it(look at picture) ?
would it be better to put a regular rc plane exhaust or tuned pipe?
Nastagol is offline Find More Posts by Nastagol
Old Nov 20, 2012, 10:28 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
One could probably strip off some more things, such as all that stuff around the carb, but it may not really reduce the weight much if any. The mufflers are primarily replaced with better ones that reduce the noise more, or increase the power more (such as tuned muffler or pipe systems). But if the muffler is steel and heavy, then going with a more lightweight muffler, maybe aluminum can help. There might be some extraneous protrusions or metal webbing on the crankcase that could be cut off too. But don't chop off the mounting tabs or mount points though.
Further weight reduction entails removing the flywheel and magneto and replacing them with a electronic CDI unit that is battery powered. But quite a few fellows prefer the magneto systems, even if they weigh more, for the simplicity of it all. More advanced is machining up a new crankcase for the engine to replace the stock heavier one.
The side piston port engines run pretty good, but the side port forces the engine designer to leave off a intake boost port into the cylinder. So the engine only has two side ports. The reed valve engines or rotary valve engines have the carb away from the side of the cylinder, so then they can put in a third intake port into the cylinder. Thus the reed valve or rotary valve engines develop more power and performance than the old style side port engines do. Thus your side port engine won't run as good as the other types of engines, and won't really develop that extra power that the 3D aerobatics crowd likes. But the engine is good for other types of model airplance flying of course.
Old Nov 23, 2012, 01:54 PM
Nastagol is offline
Joined Nov 2012
prop hub
thank you, i got another question , its about the prop hub , a made one but the thing is that i think the screw should be inveter , ( left hand) . but that part is on i could just buy one i found some of these, but i have to change the which i screw it in , what a mess , is there a place where i can buy a prop hub taht would fit ? , not to expensive? .
thank you
Old Nov 23, 2012, 01:56 PM
Nastagol is offline
Joined Nov 2012
the prop was getting of each time i was starting it with the drill .. it could of hurt somebody
Old Nov 24, 2012, 09:54 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I think your problem is that the prop hub needs to be a larger diameter to match the width of the propeller at its hub. You don't have enough surface area to grip the prop well, so it slips and comes loose on you. You should also cut in some grooves to grip the prop better. The prop washer should be larger in diameter to match the prop hub size too and more thick than a regular washer. Even a gas engine RC conversion develops too much power for using a couple of nuts with the prop in between them. The prop hub can have a wide end with a tapered or stepped smaller diameter rear part though.
You can see here where I made the prop hub adapter larger in diameter and used a big washer like spacer for the prop washer too.
Last edited by earlwb; Nov 24, 2012 at 09:56 PM. Reason: needed to add more information
Old Nov 24, 2012, 10:10 PM
Nastagol is offline
Joined Nov 2012
yes, i will look for bigger washers, thank you , would only bigger washer and cutting prop diameter to make more grip would be enough? and i know that i should change the screw, and i found some of theme, because when the drill spin to start the engine , it goes counter clock and it unscrew the screw which makes the prop getting off.
Old Nov 24, 2012, 10:12 PM
Nastagol is offline
Joined Nov 2012
like making the same prop hub as i took and just putting bigger washers and maybe more thick or more? i mean
Old Nov 25, 2012, 06:10 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
If you use a thick steel washer as big as the hub on the propeller and weld it onto the rear nut, it may work OK. Then use a thick front washer to match but don't weld it to the front nut. A 1/4 inch thick rear washer maybe even a little more thick, as you don't want it to flex back from the pressure from the nuts tightening down on it. Use a 1/8 to 1/4 inch thick front washer.
The reason the engines drive prop hub is so wide is to provide a larger surface area for friction to grip the propeller with and also to not flexof bow back from the pressure against it from the front prop nut when it is tightened down on it.
Old Nov 27, 2012, 03:30 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
It was stated above that piston ported engines can't have a third port as is typical of Schneurle ported engines. While true, some commercial grade two stroke lawn and garden engines use two ports per side, with the rear pair aimed rearward, giving the same result as having three ports at 90 from one another. Even more recent engines have a stratified air intake system using air passages in the piston and an additional carb barrel to provide air only. For model aircraft use it's probably not worth fooling with the extra weight and complexity.
As for Shindaiwa engines being too expensive, one can call around to the bigger landscaping businesses and see if they'll let go of the one they just ran over with their truck. Yes, it DOES happen! I'm a lawn and garden equipment mechanic, and I see it frequently.
GeoffinIN is offline Find More Posts by GeoffinIN
Old Nov 29, 2012, 09:48 AM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Got a brand new FS110 Stihl 4 stroke trimmer that way.The Amigos dropped it into an irrigation pond on the golf course,and the Superintendent threw it in the trash. Now I'm no dummy.......it flies a Great Planes Stearman just fine-not overly powerful,but adequate.
epoxyearl is online now Find More Posts by epoxyearl
Old Nov 29, 2012, 10:32 AM
FloridaFlyBob is online now
Find More Posts by FloridaFlyBob
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
Maybe I try slapping a Harley motor in my Hellcat, just not with a kickstart. lol
FloridaFlyBob is online now Find More Posts by FloridaFlyBob
Discussion I know nothing about Quadrocopters or AP, but I'm going to build one. Tommygunn Multirotor Talk 113 Nov 08, 2010 12:55 AM
Discussion idiots who know nothing about boats nick30head Racing Boats - Electric 48 Jun 08, 2010 02:23 PM
Lou Reed knows nothing about a perfect day salford Slope 0 Oct 17, 2005 01:28 AM
You guys have to help me out I know nothing about getting a plane Sgwyldechild12 Beginner Training Area (Aircraft-Electric) 17 Sep 01, 2004 11:29 AM
Corona Battery power low? I know nothing about batteries!! jrobgray Electric Heli Talk 1 Nov 19, 2003 02:05 AM
