Joined Apr 2012
Well? 22F with 10mph winds is just a bit too chilly for my tastes but I was sorely tempted to give it a go when I could see and feel the warm air rising from the local roads and parking lots. It's supposed to be 35F with light winds from the right direction tomorrow so I'm hopeful that I can find out if my new flying field is good for winter soaring. If not? I think I might move the new 3D ship ahead of the new gliders on my wish list since I can fly it by making a quick nip across the street instead of having to stand out in the cold for a while.
Terre Haute, Indiana, USA
Joined Aug 2004
No doubt that thermaling in winter can be pretty good. The main limitation is the low angle of the sun and the resulting lack of intense heating of the ground. I have found (at least around here) that thermals tend to be pretty anemic within 3 weeks or so of the winter solstice (Dec. 21), unless the atmosphere is very unstable and "thermalific". Another practical limitation is one's ability to withstand the cold air!
FF Quote:
Joined Apr 2012
I would probably add a week or two on that "dead stretch" here in Minnesota, FF, but I have high hopes for my new field. It's just a couple-hundred yards from a freeway and the rising air blows right to me if the wind is coming from the Eastern hemisphere. All those cars should heat up the pavement even if there isn't much solar heating going on. I'll have to depend on that solar heating if the wind is anywhere from the West.
yorkshire UK
Joined Oct 2007
The low angle of the sun is definintely the problem here for generating thrermals, I am finding that IF it is very calm lol, 7 till 9 am gets me "light" air and my throws last can last 1:30 to 1:45, then the air goes heavy and 1:20 is the bench mark, then around 1:30pm there is another period where an little thermal activity is present but not enough to climb but a 2 or 3 min flight may be possible if I'm lucky, after 2:30 then there is just heavy air again.
But it's normally windy so unless the winds are coming up the hill which is rare then my flights are 1min or so with lots of turbulance and no lift. I only go down when it's calm now, roll on spring! Got my turnigy beetle working my my new car pistol gt2c controls working, had to strip the controls down and put some wd40 into the pots though-cheap components I guess-had to the same thing to my dx6i but only after a few years use. |
Joined Apr 2012
It should have been a good day here in Minnesota but things didn't go so well. First, my brand new prop broke on my first launch, then I just couldn't find any lift after I switched props. Oh well, it was still a nice day to fly the 3D Yak.
BTW. If you have a plastic 11X6 prop from HK? Check out this thread. I'm just trying to get a warning out. http://www.rcgroups.com/forums/showthread.php?t=1779139 Cheers! |
yorkshire UK
Joined Oct 2007
Managed a short session this after just b4 it got dark the winds calmed down enough for a bit of a fly, tomoz is supposed to be flyable too so will have a play with dlg and probably the spitfire and maybe the minimoa if I can stand the rather cold -1c and 7mph northerly winds for long enough. |
chickenwing
Glider/plane: Radian 2m Thermal or Slope: Thermal Date and Time of Flight: 2012/11/30 10:00AM Motor Run: 30 sec Duration of flight: 6:50 Max. Altitude: 702 feet Location: Ninety Six, SC Not a great time, but there it is. I didn't find a thermal until my third launch, and that one was kind of weak and I lost it quickly. The funny part of the story is, as soon as I had packed up and started to leave, a dozen or so turkey vultures appeared and started circling. I guess timing is everything...
yorkshire UK
Joined Oct 2007
Well winds were coming form west again yesterday though only light 7 to 12mph and there was no lift again on my little hill between fields so I went to the park and tried all round the park dodging the trees carefully but still no good, I went out to some farmers field which was frozen mud with some stumps of crop left and tried there but that was no better so I went back to my field, best I managed was 2 mins, so I had some lunch and took my spitfire down and had 4 good flights with that instead!
I will have a ride on my bike I think and see if I can find any west facing hills about as winds are always coming from that direction these days. |
Joined Apr 2012
New contest thread is up here:
http://www.rcgroups.com/forums/showt...1#post23415261 I suspect that submissions from the northern hemisphere will dwindle so I'm hoping our friends from the "nether regions" will pick up some of the slack. |
| Thread Tools | |
| Contest The October big sky international soaring contest | peterlngh | Electric Sailplanes | 66 | Nov 02, 2012 05:12 AM |
| Contest The September big sky international soaring contest | peterlngh | Electric Sailplanes | 68 | Oct 02, 2012 06:04 PM |
| Contest The august big sky international soaring contest | JumpySticks | Electric Sailplanes | 53 | Sep 04, 2012 06:42 PM |
| Contest The april big sky international electric sailplane contest | JumpySticks | Electric Sailplanes | 62 | May 04, 2012 10:14 AM |
| Contest The march big sky international electric soaring contest | JumpySticks | Electric Sailplanes | 63 | Apr 01, 2012 09:05 AM |
