Old Nov 03, 2012, 09:20 AM
billdad1 is offline
Find More Posts by billdad1
TOO MUCH FUN!!
billdad1's Avatar
USA, SC, CAMPOBELLO
Joined Jun 2002
All these tips are great and here is one more. Just get some of these!! They make the whole job very easy...
http://www.atlantahobby.com/Store/pc...idcategory=215
billdad1 is offline Find More Posts by billdad1
Old Nov 03, 2012, 11:59 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Or better yet ditch the deans and switch to APP's and don't solder anything:
http://www.powerwerx.com/anderson-po...owerpole-sets/
grimbeaver is offline Find More Posts by grimbeaver
Old Nov 03, 2012, 05:38 PM
john97618 is offline
Find More Posts by john97618
United States, IL, Aurora
Joined Oct 2012
Thanks everyone for your tips.
I went out and bought 10 gauge terminal connectors with flat ends at the hardware store. I was able to get nice fitting on the deans but it took me a lttile trial and error and trimming. I also bought 10 gauge shrink tubing. That worked just fine.
Thanks everone for all the tips and links. I am still going to order from Atlanta hobby shop the connectors that grimbeaver gave me the link to.
All of you have been great with your responses and recommendations. Thanks again.
john97618 is offline Find More Posts by john97618
Old Nov 03, 2012, 05:50 PM
raptor90 is offline
Find More Posts by raptor90
Raptor90
raptor90's Avatar
United States, FL, Fort Myers
Joined Jun 2008
First i'll give my advice on soldering. First, If you are into electric flight buy a good quality soldering station. I bought the TrakPower TK950 and love it. Discard the cheapie radio shack units. Second, use small diameter rosin core solder. Don't try to solder with the heavy duty roll used for creating wiring harnesses for car restoration. Third, use a good quality soldering paste, ALWAYS. And last, and the best advice i can give, buy some of these when soldering Deans Ultra Connectors. Use them once and i guarantee you will thank me for them.
http://www.heliproz.com/prodinfo.asp?number=745357
raptor90 is offline Find More Posts by raptor90
Old Nov 09, 2012, 06:05 AM
raptor90 is offline
Raptor90
raptor90's Avatar
Joined Jun 2008
I thought i would demonstrate how these things work. They are Maxx Products (MPI) item number 2818. They come in a pack of ten for $4.99 according to their web store. I got mine from the LHS.
Step 1 - solder one lead to the connector
Step 2 - solder connector to the Deans connector
Step 3 - connect other lead the same way
Step 4 - secure heat shrink tubing
That's it! They allow a secure solder joint completely around the connectors. I used them running 10S on a high end EDF pulling well over 100 amps and they have never failed. This battery will be used in an 11S setup. I like em'!
Old Nov 09, 2012, 06:22 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Originally Posted by tacx View Post
Soldering those heavy wires to deans is not easy. The problem you run into, no matter how hot of an iron you have, is that the amount of heat requierd to get the heavy wire hot enough, along with the soldering tab on the Deans, will deform the plastic body of the Deans.
I'm not saying it's impossible but it is not easy.
A decent BIG tip ... plenty of WATTS .... = no melted body, good joint.
I have a little addition to the good soldering advice in posts here ... with big diameter leads - I make sure the strands are neat and twisted ... then flatten the lead end, tin and solder ... so it lies on the Deans tab nicely.
Nigel
solentlife is offline Find More Posts by solentlife
Old Nov 09, 2012, 07:31 AM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Nigel
There's ways to avoid melting the plastic on the Deans.
1) You get everything ready (wires, shrink tubing, etc)
2) Thin the wire all around
3 Thin the Dean connector
4) Get the wire with pliers or just put something to shield the heat and grab it by hand. Balsa, a piece of fiberglass cloth a regular cloth or even a couple folds of napkin.
5) Re-thin the cable but keep the heat in it and put it in top of the Deans that way the connector solder melts fast.
6) Hold it until it get solid and shrink the tubing
I have done plenty of connections using this method and it never fails. I have a Weller WES51 and that's hot enough to get the job done.
See below the connector I solder into a Deans to charge my EDF jet packs. The connector has 8 awg gauge wires and 8 mm bullets. As you can see you can solder thicker wire into a Deans. Oh and I forgot to mention that the wire is straight into the connector not into some type EZ-Connector. I don't like those because they provide another point of failure if you get a bad solder point into it.
Gamalier is offline Find More Posts by Gamalier
Old Nov 09, 2012, 08:33 AM
raptor90 is offline
Raptor90
raptor90's Avatar
Joined Jun 2008
I'll agree that whether Deans connectors are the best connection to use can be debated but the OP asked for help in soldering those connectors. In my opinion the EZ connectors makes it much easier and as far as i am concerned provides a better joint due to the fact that you can solder the joint 360 degrees around the wire. As far as melting the plug, the EZ connectors are soldered to the wire first eliminating the chance of melting the plastic housing. The prongs provide a good physical joint to the Deans tab making it much easier to solder all the way around without moving and allowing you to solder with minimum heat application to the plug. Just my opinion.
Old Nov 15, 2012, 08:14 AM
Teddy Ong is offline
Find More Posts by Teddy Ong
Teddy Ong
Teddy Ong's Avatar
Joined Nov 2012
I accidentally bought a one cell Lipo with no connector! 3.7V. Should I be soldering deans to it? I know I can but would it be too little for Regular RCs like 2x the size of microfliers
Teddy Ong is offline Find More Posts by Teddy Ong
Old Nov 15, 2012, 08:26 AM
dedStik is online now
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Personally I use deans and convert anything I have to deans for the sake of simplicity. I'm probably going to rethink that and go with something a bit easier to remove.
I usually lay my plug flat on my work table I tend not to clamp it (I have tried with little success to solder a clamped deans and for me clamping is more of a hassle). I hit the connector with the solder tip for a few seconds to get the lead hot enough to hold solder, then I drop a bit of solder on the connector (called tinning). I then do the opposite connector as well as the wire leads that will attach to them NOTE: IF THIS IS A LIPO I NEVER EVER NEVER CUT OFF BOTH WIRES, you run the risk of shorting out the pack. ALWAYS DO ONE WIRE WHILE THE SECOND IS WRAPPED WITH ELECTRICAL TAPE TO PREVENT SHORTS
dedStik is online now Find More Posts by dedStik
Old Nov 15, 2012, 09:47 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Ted: try the Micro/Mini Deans for the smaller batts. I use them for single cells up to 3 cells and up to 800 ma. They work very well.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Nov 16, 2012, 01:37 PM
malden86 is offline
Find More Posts by malden86
malden86's Avatar
San Antonio, TX.
Joined Feb 2009
You could also make or buy a couple of adapters for your battery plugs.
http://www.headsuprc.com/servlet/the...ers/Categories
malden86 is offline Find More Posts by malden86
Help! How to Solder Micro Deans connectors wrathofkhan Batteries and Chargers 4 Jul 16, 2012 04:21 PM
Discussion Soldering a big fat wire to Dean connector photopilot Batteries and Chargers 17 Mar 13, 2012 10:01 AM
How to solder a Deans Ultra connector Andy W Power Systems 69 Jun 06, 2004 01:33 AM
Quick Question About Covering the Deans Connectors after Soldering... cincyfler Parkflyers 8 Jun 03, 2002 10:20 PM
How to properly solder servo leads to Deans Connector. GeorgeE Electric Sailplanes 7 Jul 27, 2001 04:48 PM
