Old Nov 01, 2012, 08:47 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Not sure how well it would work on deans, but on large bullets I use a mini butane torch to heat things up:
http://www.radioshack.com/product/in...ductId=2062753
grimbeaver is offline Find More Posts by grimbeaver
Old Nov 01, 2012, 10:52 PM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
As someone said already, that is a big wire for a deans connector but with the right tools it is possible with a little practice. I got a soldering station off Ebay made by Xtronic - yes its made in China but the company is owned and operated in the US with GREAT customer service. About $110 so it won't break the bank. I use the hot air for many other things than soldering as well.
Harry
Harry H is offline Find More Posts by Harry H
Old Nov 01, 2012, 11:09 PM
hoghead5150 is offline
Find More Posts by hoghead5150
The wind caused that!!
hoghead5150's Avatar
United States, OK, Poteau
Joined Jul 2012
a tip on soldering Deans is to put BOTH connectors together. what i mean is you should have a male and female Deans connector. put them together and then solder on your battery wires. this way the male connector keeps the female side from deforming from the heat.
so as not to confuse, use a male Deans connector that is NOT attached to any wires!! just a spare one works great.
hoghead5150 is offline Find More Posts by hoghead5150
Old Nov 02, 2012, 05:14 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Big thing with the gun is to let the tip heat up till it smokes before you apply it to the wires/Deans. Tin both first, then hold the wire on the Deans, heat the tip till it smokes then put the tip to the wire first as it's going to absorb most of the heat. Push it down onto the Deans. When it gets hot enough it will melt the solder to the Deans. Yeah. Don't forget the heatshrink first.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Nov 02, 2012, 06:45 AM
dennisjm is offline
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
That just melts both connectors if you don't have enough heat and doesn't really do anything if you have enough heat to begin with.
dennisjm is offline Find More Posts by dennisjm
Old Nov 02, 2012, 06:57 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
That's right. It's just what you don't want, adding another heatsink. Big thing is to do it quick, on and off, with lots of heat with the gun/iron.
Gord.
Old Nov 02, 2012, 09:23 AM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
Originally Posted by bmstyle71 View Post
Like many other guys, the problem is probably from your equipment. I ended up buying a 45watt iron with a chisel tip and BAM...solved the problem instantly. Soldered all my dean connectors and I couldn't even pull them off with quite some force. I was so happy then i realized i forgot to slide the heat shrink tubing on...SON OF A...lol oh well, gave more more practice i suppose
Yes, but were you soldering 10 ga. wire?
tacx is offline Find More Posts by tacx
Old Nov 02, 2012, 10:22 AM
dennisjm is offline
Proud RC Addict
Joined Nov 2009
I"ve done some 10 gauge with my 50W iron. It's a little borderline though. I have to turn it all the way to it's max temp setting. I'm considering getting one of those Weller 85W irons for the occasional really big wire job.
Old Nov 02, 2012, 11:21 AM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
If your looking for a new soldering tool do yourself a favor and get one of this ones. A Weller WES51, it will take care of all your soldering problems and it will last for years, plus it has auto shut off. I have one and I use it to solder 8awg cables and 8mm bullets once I thinned everything it takes less than 45 seconds to get everything solder with a professional finish. There's plenty of stations around but with a Weller everything is replaceable and easy to find.
http://item.mobileweb.ebay.com/viewi...id=84693762108
Gamalier is offline Find More Posts by Gamalier
Old Nov 02, 2012, 01:05 PM
tacx is offline
tacx's Avatar
Joined Apr 2009
There is another method for those of you who are having trouble with the larger wire size. This method also produces a much cleaner joint.
Get some 6.5 mm bullet connectors Good for 13 to 8 ga.
http://www3.towerhobbies.com/cgi-bin...&I=LXTJJ0&P=ML
Use a dremel tool, or whatever you have, and cut a slot in the bullet big enough to accept the Deans tab.
Solder your wire into the bullet as you normally would, then slip the bullet slot, that you just cut, over the Deans tab and solder that.
This makes the soldering much easier and makes a nice smooth joint.
Oh yea, Don't forget the shrink tube. How many times have we done that!
Here is a little sketch.
Old Nov 02, 2012, 01:09 PM
United States, MN
Joined Feb 2011
So add $2 for the cost of the bullet, plus what you already paid for the deans, spend the time doing multiple solder joints... hum I think it's time one just moves on to a more user friendly connector type.
Old Nov 02, 2012, 01:37 PM
lrb75 is offline
Find More Posts by lrb75
United States, VA, Springfield
For 10ga and thicker just heavily tin the wire and cut the slot in the wire. Forget about the bullet. I use a weller soldering gun and can solder 8ga onto deans this way.
lrb75 is offline Find More Posts by lrb75
Old Nov 02, 2012, 01:50 PM
Joined Jul 2012
i use a hakko soldering station. works fantastic, and parts are easy to find if needed. had this one a year with no troubles. it'll solder pretty much anything you want (or need) to do!
http://www.amazon.com/Hakko-Solderin.../dp/B004M3U0VU
Old Nov 02, 2012, 03:35 PM
Lardog is online now
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Alternatively, on large guage wire, skip the bullet and after you tin the end of the wire, use the dremmel to cut the slot directly into the wire end. Works great.
Lardog is online now Find More Posts by Lardog
Old Nov 02, 2012, 05:07 PM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Or skip the Deans and just use bullets!
Harry
Help! How to Solder Micro Deans connectors wrathofkhan Batteries and Chargers 4 Jul 16, 2012 04:21 PM
Discussion Soldering a big fat wire to Dean connector photopilot Batteries and Chargers 17 Mar 13, 2012 10:01 AM
How to solder a Deans Ultra connector Andy W Power Systems 69 Jun 06, 2004 01:33 AM
Quick Question About Covering the Deans Connectors after Soldering... cincyfler Parkflyers 8 Jun 03, 2002 10:20 PM
How to properly solder servo leads to Deans Connector. GeorgeE Electric Sailplanes 7 Jul 27, 2001 04:48 PM
