Old Nov 01, 2012, 09:14 AM
Darkenor is offline
Find More Posts by Darkenor
Joined Nov 2012
What happens if you put a .90 2-stroke in a 60 size plane?
I've always wondered when looking at the .60 2-stroke or .91 4-stroke engine requirements on various planes if you could just say "whatever!" and put a .91 2-stroke in it and grunt like Tim Allen. Does anyone do that?
Darkenor is offline Find More Posts by Darkenor
Old Nov 01, 2012, 09:30 AM
rmsingh is offline
Find More Posts by rmsingh
RC Addict
rmsingh's Avatar
Ontario, Canada
Joined Mar 2010
More Power!!
rmsingh is offline Find More Posts by rmsingh
Old Nov 01, 2012, 10:15 AM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Everyone does it. Sometimes I have seen pilots waiting for the tank to run dry because the idle isn't low enough, and more than one wing fold up because of the extra speed/weight.
aspeed is offline Find More Posts by aspeed
Old Nov 01, 2012, 10:19 AM
downunder is offline
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
My son ended up swapping out the .40 engine in his Rite Flyer 40 trainer for a 1.08 but had to set it back about 3" to keep the balance correct. It flew beautifully . I might add that airspeed didn't change because he used a prop pitch (6") that didn't allow high airspeed so there was no problem with overstressing the airframe.
downunder is offline Find More Posts by downunder
Old Nov 01, 2012, 10:21 AM
Darkenor is offline
Joined Nov 2012
Neat!
That shouldn't make me laugh, or smile, but it kind of does. Thanks for the info.
Old Nov 01, 2012, 10:44 AM
706jim is online now
Find More Posts by 706jim
Canada, ON, Thunder Bay
Besides the higher idle airspeed, a nose heavy aircraft is harder to flair on landing.
706jim is online now Find More Posts by 706jim
Old Nov 01, 2012, 10:56 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well you get more power that is for sure.
But you may have to make changes to get the CG to come out OK.
Also propeller clearance can be a issue if the engine needs to turn a large diameter prop, as some planes don't have enough ground clearance.
Some planes could be affected by the additional power and larger prop causing more torque roll to the left too.
earlwb is offline Find More Posts by earlwb
Old Nov 01, 2012, 11:01 AM
SrTelemaster is offline
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
I always try to select an engine that is heavy enough to balance the CG W/O adding ballst in the nose.
That usually means MORE POWER!
SrTelemaster is offline Find More Posts by SrTelemaster
Old Nov 01, 2012, 11:44 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
I can say this! "the 61fx is within a couple oz's of the 91fx" they are physicaly the same size!
whiskykid is offline Find More Posts by whiskykid
Old Nov 01, 2012, 01:07 PM
I HATE GLOW PLUGS!
Joined Feb 2012
Then a 180 Saito 4-stoke seems in order!
Old Nov 01, 2012, 02:36 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I should mention that there are practical limits to how large of a engine one can use. The wing loading can go up considerably turning a plane into something more like trying to fly a brick or the Space Shuttle. Having to take off and land with air speeds over 100 mph for a RC model airplane might be more than a flyer might want to do.
But for modern .60 (10cc) engine size planes, usually one can go up to a 1.20 or 20cc engine OK as people have been putting up to 1.20 size four stroke engines in their planes for a long time without much hassle. Thus a .91 size or 15cc size engine is not a problem. But if the .60 size plane is a old design from many years ago before Schnuerle engines became popular, it can be a problem as the early .60 size planes weren't all that big but more like .45 size planes are today.
Old Nov 01, 2012, 03:13 PM
Alorek is offline
Find More Posts by Alorek
Alorek's Avatar
United States, CA, Rosamond
Joined Jul 2008
I sent you a PM.
Alorek is offline Find More Posts by Alorek
Old Nov 01, 2012, 03:47 PM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
YES!!!
OS 91FX in the space reserved for a 65AX = Superb fun
TimBle is offline Find More Posts by TimBle
Old Nov 01, 2012, 07:39 PM
the pope is offline
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
No probs . Infact this should be regarded as normal practice . Cheers the pope
the pope is offline Find More Posts by the pope
Reply With Quote  (Disabled)
Old Nov 01, 2012, 09:07 PM
I HATE GLOW PLUGS!
Joined Feb 2012
My take is that if ballast is eliminated by a larger engine, the net weight of the aircraft is still the same as W/the smaller engine Wballast.
As long as the structural factor of the airframe is not exceeded there is no negative affect.
Question Hypothetical question - what happens if you run an EDF with the duct removed? LMF5000 Power Systems 9 Apr 18, 2014 03:38 PM
Careful! Wanna See What Happens if you burst a LiPo in a RPG ? BigTradioman Auto Gyros 13 May 18, 2012 10:29 AM
Discussion If you had an extra Fox .45, servos, receiver, etc., what would you put them in? NeveSSL Fuel Plane Talk 8 Apr 18, 2012 09:18 PM
Question What is the best budget 2 stroke 60-61 and 90-91 size engine snowwolf Engines 16 Apr 19, 2007 08:59 AM
what if you v tailed an 60 or electron? what would happen? kwhite Dynamic Soaring 1 Mar 01, 2004 11:05 AM
