Old Nov 01, 2012, 06:23 AM
FPVing is offline
Find More Posts by FPVing
FPVing's Avatar
Australia, VIC, Melbourne
Joined Oct 2012
Experiences with CP Antenna's bought off eBay?
Hi folks,
Just wondering if any of you have any experiences good or bad with Circularly Polarised Antenna's bought off eBay. I bought myself a pair for 5.8Ghz for $40 from eBay just now and was wondering what to expect.
Cheers, Matt.
FPVing is offline Find More Posts by FPVing
Old Nov 01, 2012, 07:26 AM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
yes this guy http://search.ebay.com/?sass=omega-one944&ht=-1 makes good antennas .. ive been out 5km with just two of his SPW+CL on 500mw 2.4ghz
octane81 is offline Find More Posts by octane81
Old Nov 02, 2012, 01:22 AM
FPVing is offline
FPVing's Avatar
Joined Oct 2012
Great stuff. I bought mine from a guy closer to me.
Old Nov 02, 2012, 06:58 AM
octane81 is offline
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
they doesnt seem to be built correct ... the feedgap seems all to big .. especially for 5.8ghz..
Old Nov 02, 2012, 08:15 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
When buying these off of Ebay or searching for a bargain in general, be very careful to look at construction technique. You should be looking for a few things:
1. Sustainability of the build - Look for one that has strong solder joints. Solder to steel wire is weaker than soldering to copper. Many use pin point soldering that breaks very easily namely at the base.
2. Feedgap - A large feed gap throws off resonance, weaken the antenna, and shows lack of care for proper construction.
3. Round corners - Sharp corners cause spurious emissions and it also harms circularity.
4. Balancing - Look for antennas that have a balun at the base or ones that have consistent length. Stray currents due to skin effect run down the outside of the cable causing it to act like a dipole and harm the antenna's circularity.
5. Wire size - Many use thicker wire than what the antenna calls for which puts the antenna out of resonance.
When looking for a bargain, be sure to find one as the antenna is the critical link between your airplane and the ground. Generally you get what you pay for.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 02, 2012, 06:21 PM
FPVing is offline
FPVing's Avatar
Joined Oct 2012
Thanks for the tips Alex!
Discussion Cheap Cp antenna's Locko FPV Talk 87 Sep 15, 2012 07:47 AM
Sold immersionRc 5.8Ghz 600mW and 5.8Ghz FatShark Module + CP Antenna's Jessestr FPV Equipment (FS/W) 1 Sep 04, 2012 04:04 PM
Free CP Antenna's! 5.8Ghz! FirstPersonView Non R/C Items (FS/W) 3 Aug 18, 2012 03:15 AM
For Sale 5.8ghz DVR Tx\Rx CP antenna's 1.2ghz, MyVu Crystals, and other FPV gear Adidas4275 FPV Equipment (FS/W) 11 Aug 08, 2012 12:34 AM
